Changing viscosity in interFoam
Like Tree2Likes
  • 2 Post By olivierG
Old   March 11, 2015, 04:14
Default Changing viscosity in interFoam
Thomas Vossel
ThomasV is on a distinguished road
Hi!
I want to use interFoam and change the viscosity depending on the temperature. I already included the temperature transport and a method for interpolating the respective viscosity values based on some actually measured data. I'm now struggling to get access to the viscosity field / understanding how all of this works...
1.)
The viscosity is calculated via the incompressibleTwoPhaseMixture model. There a volScalarField "nu_" is created but it's protected so I cannot change it via my solver's code...
2.)
I had a look at the velocity / pressure solver itself to see where the viscosity is passed on to the solver so I could like clone the internally calculated viscosity field in order to pass on an altered version to the actual velocity equations. I would have expected to see it in the momentum equation but for U there's just this:
    fvVectorMatrix UEqn
        fvm::ddt(rho, U)
      + fvm::div(rhoPhi, U)
      + turbulence->divDevRhoReff(rho, U)
    UEqn.relax();
    if (pimple.momentumPredictor())
        solve
            UEqn
            fvc::reconstruct
                    fvc::interpolate(interface.sigmaK())*fvc::snGrad(alpha1)
                  - ghf*fvc::snGrad(rho)
                  - fvc::snGrad(p_rgh)
                ) * mesh.magSf()
So at which point in the solver's code does the viscosity play a role and how can I get access to the viscosity field in order to change it?
ThomasV is offline   Reply With Quote
Old   March 11, 2015, 09:55
ali alkebsi
kebsiali is on a distinguished road
hello
I'm also interested in doing this ( I have to. )
I think, if you are not going to use any turbulence model (laminar case)
then you could just exchange the line
with one like in icoFoam
where you will have to go to createFields.H and create you nu1 nu2 and nu
and make it calculated like rho (averaging).
However it might prove not effective (its just an idea i came up with to try)
in case you find another solution i'm very interested in knowing how
and i think that the slover uses the nu as calculated in
incompressibleTwoPhaseMixture.C
by calling
twoPhaseProperties.correct();
kebsiali is offline   Reply With Quote
Old   March 11, 2015, 23:45
Yogesh Bapat
ybapat is on a distinguished road
Hello Thomas,
You can write your own viscosity model as in src/transportModels/viscosityModel. Here you can find different viscosity models are implemented.
Regards,
-Yogesh
ybapat is offline   Reply With Quote
Old   March 12, 2015, 02:47
Thomas Vossel
Hi!
Thanks for your suggestions. Writing a viscosity model of my own might be a solution but after quite a struggle to get a boundary condition of mine to work I want to avoid writing more template code plus it usually costs quite some time to understand how those models are supposed to work. But maybe I should have a look at this again - perhaps OpenFOAM surprises me for once by giving a straightforward process for integrating something new...
Right now I'm trying to implement a "dirty trick". I just copied the entire transport model sources to my solver in order to compile all of this as a custom library. I then added a function which passes on a pointer to the nu_ volScalarField. In my solver I know use the pointer to simply overwrite nu_ with a field of my own. This seems to work so far but recently I just did some tests without the U and p calculations so I still have to check that it won't become overwritten by something. There also seems to be a bug in my interpolation code I have to fix first...
If none of all this will work I guess I'll try kebsiali's approach. So the viscosity is implemented via the turbulence model?
Old   March 12, 2015, 04:45
Olivier
olivierG is on a distinguished road
hello,
This has already been done ...
check http://www.tfd.chalmers.se/~hani/kur...nFoam%20v2.pdf
Regards,
olivier
ThomasV and purnp2 like this.
olivierG is offline   Reply With Quote
Old   March 12, 2015, 06:43
Thomas Vossel
Thanks - that's a nice source. Way more easy than my approach...
InterFoam viscosity problem / possible bug pbryant OpenFOAM Running, Solving & CFD 24 March 30, 2020 04:25
Problem with divergence TDK FLUENT 13 December 14, 2018 06:00
[PyFoam] Problems with the new PyFoam release zfaraday OpenFOAM Community Contributions 13 December 9, 2014 18:58
[PyFoam] having problems with pyfoam Installation vitorspadetoventurin OpenFOAM Community Contributions 3 December 2, 2014 07:18
Viscosity interpolation in interFoam Jun Kwon Park OpenFOAM Running, Solving & CFD 0 October 9, 2009 08:29
