March 12, 2015, 10:16 |
Viewfactorgen - fp expception with baffles
Derek Mitchell
Rep Power: 13 |
View factorgen throws a floating point exception when used with thermal 3D baffles in more complex geometries.
in this case extending the length of a baffle by 20mm causes a failure. I attach two cases one where it works and another where the small change in the baffle sizes causes the exception. Changing the Viewfactorsdict appears to have no effect. This is with openfoam 2.3.1. with the newly updated facesAgglomerate from 2.3.x
A CHEERING BAND OF FRIENDLY ELVES CARRY THE CONQUERING ADVENTURER OFF INTO THE SUNSET |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 09:12 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
about modelling of baffles in Flow-3D | tecmia | FLOW-3D | 0 | September 24, 2012 09:27 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Rotary drum attached with baffles | nutow | CFX | 11 | November 12, 2010 14:36 |
