cloudInfo1 problem with MPI parallel run on reactingParcelFoam
Old   March 17, 2015, 10:22
Default cloudInfo1 problem with MPI parallel run on reactingParcelFoam
Juan David Rodriguez P
JuanRodriguez is on a distinguished road
Hello.
I stumbled on an error produced when I tried to run in parallel a case on reactingParcelFoam with the functionObject cloudInfo1 (http://foam.sourceforge.net/docs/cpp/a08773_source.html).
The error produced started like this:
An error occurred in MPI_Recv
After I turned off the cloudInfo1 function in controlDict it run flawlessly.
JuanRodriguez is offline   Reply With Quote
cloudinfo1, functionobject, lagrangian, mpi, reactingparcelfoam
Problem in parallel run with OpenFOAM Gitesh P OpenFOAM Running, Solving & CFD 2 June 1, 2014 06:05
Problem with cyclic bc when run on parallel Tek OpenFOAM 2 January 20, 2011 14:40
problem specifying alpha at inlet during a parallel run phsieh2005 OpenFOAM Running, Solving & CFD 2 August 13, 2009 08:23
Parallel run crashing matejfor OpenFOAM Running, Solving & CFD 3 May 11, 2009 02:18
PROBLEM IN PARALLEL PROGRAMMING WITH MPI Niavarani Main CFD Forum 1 April 20, 2004 06:51
