''unknown radialModelType type Gidaspow'' PROBLEM WITH THE BED TUTORIAL |
Andoni
Rep Power: 11 ![]() |
Hi
I am new using openFoam and I am trying to run a tutorial called Bed, everything seems alright but when I run my simulation it appears the FOAM FATAL ERROR that does not recognize the radialModelType Gidaspow, I do not know if is a problem with the software or the tutorial scripts. I hope anyone could help me in this. Code:
sparta@sparta-VirtualBox:/media/home/Sand_Pipe_Project/Test_Models/bed$ twoPhaseEulerFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0-b363e8d14789 Exec : twoPhaseEulerFoam Date : Mar 24 2015 Time : 13:00:21 Host : "sparta-VirtualBox" PID : 10982 Case : /media/home/Sand_Pipe_Project/Test_Models/bed nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g Reading transportProperties Calculating face flux field phi1 Calculating face flux field phi2 Reading field alpha1 Reading field p kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 -0.375; alphak 1; alphaEps 0.82142; alpha1k 1; alpha1Eps 0.76923; } wallFunctionCoeffs { kappa 0.4187; E 9; } Reading field k Reading field epsilon Calculating field nut2 Calculating field nuEff1 Calculating field nuEff2 Calculating field DDtU1 and DDtU2 Calculating field g.h Selecting dragModel for phase 1: GidaspowSchillerNaumann Selecting dragModel for phase 2: GidaspowSchillerNaumann dragPhase is 1 Selecting viscosityModel Syamlal Selecting conductivityModel HrenyaSinclair Selecting radialModel Gidaspow 3 ( CarnahanStarling LunSavage SinclairJackson ) --> FOAM FATAL ERROR: radialModel::New(const dictionary&) : unknown radialModelType type Gidaspow, constructor not in hash table Valid radialModelType types are : FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::error::abort() in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 Foam::kineticTheoryModels::radialModel::New(Foam::dictionary const&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libkineticTheoryModel.so" #3 Foam::kineticTheoryModel::kineticTheoryModel(Foam::phaseModel const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dragModel const&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libkineticTheoryModel.so" #4 in "/opt/openfoam220/platforms/linux64GccDPOpt/bin/twoPhaseEulerFoam" #5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #6 in "/opt/openfoam220/platforms/linux64GccDPOpt/bin/twoPhaseEulerFoam" Aborted (core dumped) sparta@sparta-VirtualBox:/media/home/Sand_Pipe_Project/Test_Models/bed$ Last edited by AndoniBM; March 27, 2015 at 14:17. |
Andoni
I solved it, it appears that the radialModel does not include the Gidaspow, but I can select between this:
-CarnahanStarling -LunSavage- -radialModel -SInclairJackson But I have another problem. Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0-b363e8d14789 Exec : twoPhaseEulerFoam Date : Mar 25 2015 Time : 09:01:31 Host : "sparta-VirtualBox" PID : 2662 Case : /media/home/Sand_Pipe_Project/Test_Models/bed nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g Reading transportProperties Calculating face flux field phi1 Calculating face flux field phi2 Reading field alpha1 Reading field p kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 -0.375; alphak 1; alphaEps 0.82142; alpha1k 1; alpha1Eps 0.76923; } wallFunctionCoeffs { kappa 0.4187; E 9; } Reading field k Reading field epsilon Calculating field nut2 Calculating field nuEff1 Calculating field nuEff2 Calculating field DDtU1 and DDtU2 Calculating field g.h Selecting dragModel for phase 1: GidaspowSchillerNaumann Selecting dragModel for phase 2: GidaspowSchillerNaumann dragPhase is 1 Selecting viscosityModel Syamlal Selecting conductivityModel HrenyaSinclair Selecting radialModel CarnahanStarling Selecting granularPressureModel Lun Selecting frictionalStressModel JohnsonJackson No MRF models present Courant Number mean: 0.00018 max: 0.0225 PIMPLE: Operating solver in PISO mode Starting time loop --> FOAM FATAL ERROR: Requested field Ua does not exist in the database From function Foam::fieldAverage::initialize() in file fieldAverage/fieldAverage/fieldAverage.C at line 104. FOAM exiting Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0-b363e8d14789 Exec : twoPhaseEulerFoam Date : Mar 25 2015 Time : 09:37:13 Host : "sparta-VirtualBox" PID : 3298 Case : /media/home/Sand_Pipe_Project/Original_FIles/bed nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g Reading transportProperties --> FOAM FATAL IO ERROR: keyword phase1 is undefined in dictionary "/media/home/Sand_Pipe_Project/Original_FIles/bed/constant/transportProperties" file: /media/home/Sand_Pipe_Project/Original_FIles/bed/constant/transportProperties from line 23 to line 39. From function dictionary::subDict(const word& keyword) const in file db/dictionary/dictionary.C at line 608. FOAM exiting And then another error happens: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0-b363e8d14789 Exec : twoPhaseEulerFoam Date : Mar 25 2015 Time : 16:52:08 Host : "sparta-VirtualBox" PID : 3530 Case : /media/home/Sand_Pipe_Project/Original_FIles/bed nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g Reading transportProperties --> FOAM FATAL IO ERROR: cannot find file file: /media/home/Sand_Pipe_Project/Original_FIles/bed/0/U1 at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting And then another error: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0-b363e8d14789 Exec : twoPhaseEulerFoam Date : Mar 25 2015 Time : 16:59:05 Host : "sparta-VirtualBox" PID : 3577 Case : /media/home/Sand_Pipe_Project/Original_FIles/bed nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g Reading transportProperties Calculating face flux field phi1 Calculating face flux field phi2 Reading field alpha1 --> FOAM FATAL IO ERROR: cannot find file file: /media/home/Sand_Pipe_Project/Original_FIles/bed/0/alpha1 at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting Another error appears... Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0-b363e8d14789 Exec : twoPhaseEulerFoam Date : Mar 25 2015 Time : 17:03:00 Host : "sparta-VirtualBox" PID : 3635 Case : /media/home/Sand_Pipe_Project/Original_FIles/bed nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g Reading transportProperties Calculating face flux field phi1 Calculating face flux field phi2 Reading field alpha1 Reading field p kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 -0.375; alphak 1; alphaEps 0.82142; alpha1k 1; alpha1Eps 0.76923; } wallFunctionCoeffs { kappa 0.4187; E 9; } Reading field k Reading field epsilon Calculating field nut2 Calculating field nuEff1 Calculating field nuEff2 Calculating field DDtU1 and DDtU2 --> FOAM FATAL IO ERROR: keyword div(phi1,U1) is undefined in dictionary "/media/home/Sand_Pipe_Project/Original_FIles/bed/system/fvSchemes.divSchemes" file: /media/home/Sand_Pipe_Project/Original_FIles/bed/system/fvSchemes.divSchemes from line 29 to line 38. From function dictionary::lookupEntry(const word&, bool, bool) const in file db/dictionary/dictionary.C at line 402. FOAM exiting -phia for phi1 -Ua for U1 -phib for phi2 -Ub for phi2 Again... Another error, this time in the drag model: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0-b363e8d14789 Exec : twoPhaseEulerFoam Date : Mar 25 2015 Time : 17:14:23 Host : "sparta-VirtualBox" PID : 3692 Case : /media/home/Sand_Pipe_Project/Original_FIles/bed nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g Reading transportProperties Calculating face flux field phi1 Calculating face flux field phi2 Reading field alpha1 Reading field p kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 -0.375; alphak 1; alphaEps 0.82142; alpha1k 1; alpha1Eps 0.76923; } wallFunctionCoeffs { kappa 0.4187; E 9; } Reading field k Reading field epsilon Calculating field nut2 Calculating field nuEff1 Calculating field nuEff2 Calculating field DDtU1 and DDtU2 Calculating field g.h --> FOAM FATAL IO ERROR: keyword dragModel1 is undefined in dictionary "/media/home/Sand_Pipe_Project/Original_FIles/bed/constant/interfacialProperties" file: /media/home/Sand_Pipe_Project/Original_FIles/bed/constant/interfacialProperties from line 17 to line 20. From function dictionary::lookupEntry(const word&, bool, bool) const in file db/dictionary/dictionary.C at line 402. FOAM exiting |
Andoni
From there I modified the script interfacialProperties and change dragPhase a for dragPhase "1" and dragModela and dragModelb for dragModel1 and dragModel2 respectively.
And I have the problem that is at the beginning of this Thread. Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0-b363e8d14789 Exec : twoPhaseEulerFoam Date : Mar 25 2015 Time : 17:31:17 Host : "sparta-VirtualBox" PID : 3771 Case : /media/home/Sand_Pipe_Project/Original_FIles/bed nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g Reading transportProperties Calculating face flux field phi1 Calculating face flux field phi2 Reading field alpha1 Reading field p kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 -0.375; alphak 1; alphaEps 0.82142; alpha1k 1; alpha1Eps 0.76923; } wallFunctionCoeffs { kappa 0.4187; E 9; } Reading field k Reading field epsilon Calculating field nut2 Calculating field nuEff1 Calculating field nuEff2 Calculating field DDtU1 and DDtU2 Calculating field g.h Selecting dragModel for phase 1: GidaspowSchillerNaumann Selecting dragModel for phase 2: GidaspowSchillerNaumann dragPhase is 1 Selecting viscosityModel Syamlal Selecting conductivityModel HrenyaSinclair Selecting radialModel Gidaspow 3 ( CarnahanStarling LunSavage SinclairJackson ) --> FOAM FATAL ERROR: radialModel::New(const dictionary&) : unknown radialModelType type Gidaspow, constructor not in hash table Valid radialModelType types are : FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::error::abort() in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 Foam::kineticTheoryModels::radialModel::New(Foam::dictionary const&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libkineticTheoryModel.so" #3 Foam::kineticTheoryModel::kineticTheoryModel(Foam::phaseModel const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dragModel const&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libkineticTheoryModel.so" #4 in "/opt/openfoam220/platforms/linux64GccDPOpt/bin/twoPhaseEulerFoam" #5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #6 in "/opt/openfoam220/platforms/linux64GccDPOpt/bin/twoPhaseEulerFoam" Aborted (core dumped) Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0-b363e8d14789 Exec : twoPhaseEulerFoam Date : Mar 25 2015 Time : 17:36:33 Host : "sparta-VirtualBox" PID : 3807 Case : /media/home/Sand_Pipe_Project/Original_FIles/bed nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g Reading transportProperties Calculating face flux field phi1 Calculating face flux field phi2 Reading field alpha1 Reading field p kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 -0.375; alphak 1; alphaEps 0.82142; alpha1k 1; alpha1Eps 0.76923; } wallFunctionCoeffs { kappa 0.4187; E 9; } Reading field k Reading field epsilon Calculating field nut2 Calculating field nuEff1 Calculating field nuEff2 Calculating field DDtU1 and DDtU2 Calculating field g.h Selecting dragModel for phase 1: GidaspowSchillerNaumann Selecting dragModel for phase 2: GidaspowSchillerNaumann dragPhase is 1 Selecting viscosityModel Syamlal Selecting conductivityModel HrenyaSinclair Selecting radialModel CarnahanStarling Selecting granularPressureModel Lun Selecting frictionalStressModel JohnsonJackson --> FOAM FATAL IO ERROR: keyword PIMPLE is undefined in dictionary "/media/home/Sand_Pipe_Project/Original_FIles/bed/system/fvSolution" file: /media/home/Sand_Pipe_Project/Original_FIles/bed/system/fvSolution from line 21 to line 93. From function dictionary::subDict(const word& keyword) const in file db/dictionary/dictionary.C at line 608. FOAM exiting Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0-b363e8d14789 Exec : twoPhaseEulerFoam Date : Mar 25 2015 Time : 17:41:43 Host : "sparta-VirtualBox" PID : 3838 Case : /media/home/Sand_Pipe_Project/Original_FIles/bed nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g Reading transportProperties Calculating face flux field phi1 Calculating face flux field phi2 Reading field alpha1 Reading field p kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 -0.375; alphak 1; alphaEps 0.82142; alpha1k 1; alpha1Eps 0.76923; } wallFunctionCoeffs { kappa 0.4187; E 9; } Reading field k Reading field epsilon Calculating field nut2 Calculating field nuEff1 Calculating field nuEff2 Calculating field DDtU1 and DDtU2 Calculating field g.h Selecting dragModel for phase 1: GidaspowSchillerNaumann Selecting dragModel for phase 2: GidaspowSchillerNaumann dragPhase is 1 Selecting viscosityModel Syamlal Selecting conductivityModel HrenyaSinclair Selecting radialModel CarnahanStarling Selecting granularPressureModel Lun Selecting frictionalStressModel JohnsonJackson No MRF models present Courant Number mean: 0.00018 max: 0.0225 PIMPLE: Operating solver in PISO mode Starting time loop --> FOAM FATAL ERROR: Requested field Ua does not exist in the database From function Foam::fieldAverage::initialize() in file fieldAverage/fieldAverage/fieldAverage.C at line 104. FOAM exiting Because the solver asks me Ua but I changed the name for U1 because the dictionary does no recognize it. I hope someone can help me. |
Why Menter's SST model low-Re issue has not been seriously investigated? | vkrastev | OpenFOAM | 58 | January 8, 2018 15:20 |
boundary conditions for simpleFoam calculation | foam_noob | OpenFOAM Running, Solving & CFD | 8 | July 1, 2015 08:07 |
[swak4Foam] Air Conditioned room groovyBC | Sebaj | OpenFOAM Community Contributions | 7 | October 31, 2012 14:16 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
