K-OmegaSST boundary condtions for y+=1 Question
Old   April 18, 2015, 03:59
Default K-OmegaSST boundary condtions for y+=1 Question
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
Hello people,
I have been trying to use the kOmegaSST model implemented in OF 2.3.3, to simulate backward facing step. I have created three grids in order to do grid convergence study properly. However, I am a little bit confused about sitting boundary conditions for both k and omega properly. For instance, k and omega for examples in simpleFoam have been set up using wall function, and my feeling is that wall function does not work with y+=1 since it will not be resolving the boundary layer. I really would appreciate your help in this regard.
Following are the boundary conditions for my turbulent parameters :
k
|  \\    /   O peration     | Version:  2.3.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      k;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0.015;
boundaryField
    front
        type            slip;
    inlet
        type            fixedValue;
        value           uniform 0.015;
    top
        type            fixedValue;//kqRWallFunction;
        value           uniform 1e-10;//0.015;
    bottom
    back
        type            slip;
    outlet
        type            zeroGradient;
omega
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      omega;
dimensions      [0 0 -1 0 0 0 0];
internalField   uniform 4.1744;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 4.1744;
    outlet
        type            zeroGradient;
    top
        type            fixedValue;//omegaWallFunction;
        value           uniform 1e+10;//4.1744;
    bottom
    front
        type            slip;
    back
        type            slip;
p
FoamFile
    version     2.0;
    format      ascii;
    object      p;
internalField   uniform 0;
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           uniform 0;
    top
        type            zeroGradient;
    bottom
        type            zeroGradient;
    front
        type            slip;
    back
        type            slip;
U
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            fixedValue;
        value           uniform (1 0 0);
    outlet
        type            zeroGradient;
    top
        type            fixedValue;
        value           uniform (0 0 0);
    bottom
        type            fixedValue;
    front
        type            slip;
    back
        type            slip;
tareqkh is offline   Reply With Quote
Radiation interface hinca CFX 15 January 26, 2014 17:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Boundary Question chris85 ANSYS 0 November 17, 2011 15:29
Boundary Layer Question scottneh STAR-CCM+ 3 September 30, 2010 14:21
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
