pimpleDyMFoam - strange pattern in velocity
Old   May 2, 2015, 09:50
Default pimpleDyMFoam - strange pattern in velocity
cStef is on a distinguished road
Hey
i'm trying to simulate a vertical axis wind turbine in openFoam. Therefore I use the pimpleDyMFoam solver (OpenFoam 2.3.0). Between the stator and the rotor i defined a cyclic AMI with the transform settings: noOrdering.
After it wasn't possible to run this case with an unstrctured mesh (it diverged every time) I made a new hex mesh.
Now everything is runing. But unforturnately my velocity looks really strange.
I tried so many different scheme and fvSolution, cyclic AMI settings but nothing helps. I also made a mesh refinement.
Have you ever seen this problem? I am getting a bit desperate
Thanks,
Conny
cStef is offline   Reply With Quote
Old   May 6, 2015, 08:26
Default Solved
By increasing the nOrthogonalCorrectors from 1 to 10 the pattern disappeared.
Velocity distribution function sampling issue in DSMC flotus1 Main CFD Forum 6 December 13, 2014 06:18
WSS and normal velocity gradient for the slanted pipe wanna88 FLUENT 2 October 1, 2012 22:34
Problem with time average tangential velocity in swirl flow. lakhi FLUENT 5 July 18, 2012 16:28
strange velocity contours at corners imoul FLUENT 0 November 8, 2010 18:18
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 06:10
