decomposePar won't break case for 8 cores
Old   May 20, 2015, 16:48
Default decomposePar won't break case for 8 cores
António Soares
Outbound is on a distinguished road
Hi everyone, I have an i7 processor with 8 cores (I can view them in Ubuntu System Manager) but when I configure the decomposeParDict file to distribute it over 8 cores I get an error message that says it' an uneven distribution of cores. Right now I have it running as follows:
numberOfSubdomains 4;
method simple;
simpleCoeffs
n ( 2 2 1 );
delta 0.001;
If I try and put in 8 cores I configure it as such:
numberOfSubdomains 8;
method simple;
simpleCoeffs
n ( 4 4 1 );
delta 0.001;
but when decomposing the case to run it I get the following error message:
--> FOAM FATAL ERROR:
Wrong number of processor divisions in geomDecomp:
Number of domains : 8
Wanted decomposition : (4 4 1)
From function geomDecomp::geomDecomp(const dictionary& decompositionDict)
in file geomDecomp/geomDecomp.C at line 50.
FOAM exiting
I've also tried other distribution combinations such as 4 4 2 or 4 3 1 but to no avail.
Does anyone have any idea of what I might be doing wrong?
Thanks.
Outbound is offline   Reply With Quote
Old   May 20, 2015, 17:06
Jace
zhengzh5 is on a distinguished road
Thanks.
hey,
n (4 4 1) gives your 16 cores, not 8...(you basically tell OpenFOAM to decompose into 16 regions when you only have 8 cores in your disposal.)
you need to divide in as (2 2 2), or (2 4 1), etc...
zhengzh5 is offline   Reply With Quote
Old   May 20, 2015, 21:04
António Soares
Thanks for the reply.
I guess I didn't understand the decomposition process.
I thought each digit meant the number of cores assigned to each direction (x y z) independently, I didn't really understand how the decomposition was accomplished by creating the mesh regions.
I'll try this again once the current simulation stops.
Once again, my thanks.
decomposepar, openmpi, parallel, parallel compressible, sonicfoam
Pressure instabilities with interDyMFoam for the floatingObject case nbadano OpenFOAM Running, Solving & CFD 15 October 15, 2021 06:35
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 15:13
How to delay releasing the water column in dam break case? Pirlu OpenFOAM Running, Solving & CFD 3 June 4, 2014 23:04
Error reading new case montag dp FLUENT 5 September 15, 2011 06:00
Turbulent Flat Plate Validation Case Jonas Larsson Main CFD Forum 0 April 2, 2004 10:25
