Using lcsMassFraction function object for icoUncoupledKinematicParcelFoam
Old   June 15, 2015, 11:01
Question Using lcsMassFraction function object for icoUncoupledKinematicParcelFoam
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
Before, I had used lcsMassFraction(cloudName) from swak4Foam function objects to convert lagrangian particle concentration into eulerian mass fraction. This was how I did that and it worked perfectly:
    mu
        type expressionField;
        expression "18.6";
    dimension [1 -1 -1 0 0 0 0];
        fieldName mu;
        autowrite true;
    rho
        expression "1.25";
    dimension [1 -3 0 0 0 0 0];
        fieldName rho;
        autowrite true;
    particles
        type evolveKinematicCloud;
        cloudName particleCloud;
        g "down" [0 1 -2 0 0 0 0] (0 -9.81 0 );
        rhoName rho;
        muName mu;
        UName U;
    massFractionKinematic
        autowrite true;
        expression "lcsMassFraction(particleCloud)";
        outputControl timeStep;
        outputInterval 1;
        fieldName massFraction;
However when I try to use it in solver icoUncoupledKinematicParcelFoam, like this:
        autowrite true;
        expression "lcsMassFraction(kinematicCloud)";
        outputInterval 1;
I get the following error:
swak4Foam: Setting default mesh
Available clouds in region0
                Name | Type
      kinematicCloud | Cloud<basicKinematicCollidingParcel>
Cloud kinematicCloud has type Cloud<basicKinematicCollidingParcel> typeid:N4Foam14CollidingCloudINS_14KinematicCloudINS_5CloudINS_15CollidingParcelINS_15KinematicParcelINS_8particleEEEEEEEEEEE
--> FOAM FATAL ERROR:
No matching cloud kinematicCloud found
Supported cloud types (typeid):
4
N4Foam13ReactingCloudINS_11ThermoCloudINS_14KinematicCloudINS_5CloudINS_14ReactingParcelINS_12ThermoParcelINS_15KinematicParcelINS_8particleEEEEEEEEEEEEEEE
N4Foam11ThermoCloudINS_14KinematicCloudINS_5CloudINS_12ThermoParcelINS_15KinematicParcelINS_8particleEEEEEEEEEEE
N4Foam14KinematicCloudINS_5CloudINS_15KinematicParcelINS_8particleEEEEEEE
N4Foam23ReactingMultiphaseCloudINS_13ReactingCloudINS_11ThermoCloudINS_14KinematicCloudINS_5CloudINS_24ReactingMultiphaseParcelINS_14ReactingParcelINS_12ThermoParcelINS_15KinematicParcelINS_8particleEEEEEEEEEEEEEEEEEEE
    From function Plugin function lcsMassFraction
    in file lcsMassFractionPluginFunction.C at line 102.
FOAM exiting
Any suggestions is appreciated.
Thanks.
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
Old   May 23, 2016, 01:57
Ping Chang
chpjz0391 is on a distinguished road
Originally Posted by Mojtaba.a View Post
    mu
        expression "18.6";
        fieldName mu;
        autowrite true;
    rho
        expression "1.25";
        fieldName rho;
        autowrite true;
    particles
        rhoName rho;
        muName mu;
        UName U;
        autowrite true;
        outputInterval 1;
        autowrite true;
        outputInterval 1;
                Name | Type
4
FOAM exiting
Thanks.
have you solved your problem?
chpjz0391 is offline   Reply With Quote
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
using METIS functions in fortran dokeun Main CFD Forum 7 January 29, 2013 04:06
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 06:59
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
