OpenFOAM remote cluster run error
Like Tree1Likes
  • 1 Post By alexeym
Old   June 21, 2015, 19:29
Default OpenFOAM remote cluster run error
krishh
krishtej23 is on a distinguished road
I am trying to run multiphaseInterFoam in remote cluster in parallel. I getting this error which I couldn't understand:
[1] #0  Foam::error::printStack(Foam::Ostream&) in "/users/krmedam/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #1  Foam::sigFpe::sigHandler(int) in "/users/krmedam/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #2  ? in "/lib64/libc.so.6"
[1] #3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/users/krmedam/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #4  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/users/krmedam/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libmultiphaseInterFoam.so"
[1] #5  Foam::multiphaseMixture::multiphaseMixture(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/users/krmedam/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libmultiphaseInterFoam.so"
[1] #6  ? in "/users/krmedam/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/bin/multiphaseInterFoam"
[1] #7  __libc_start_main in "/lib64/libc.so.6"
[1] #8  ? in "/users/krmedam/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/bin/multiphaseInterFoam"
[compute-01-29:29153] *** Process received signal ***
[compute-01-29:29153] Signal: Floating point exception (8)
[compute-01-29:29153] Signal code:  (-6)
[compute-01-29:29153] Failing at address: 0x2ef9000071e1
[compute-01-29:29153] [ 0] /lib64/libc.so.6[0x357f8326a0]
[compute-01-29:29153] [ 1] /lib64/libc.so.6(gsignal+0x35)[0x357f832625]
[compute-01-29:29153] [ 2] /lib64/libc.so.6[0x357f8326a0]
[compute-01-29:29153] [ 3] /users/krmedam/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam6divideERNS_5FieldIdEERKNS_5UListIdEES6_+0x125)[0x7f21eb89fec5]
[compute-01-29:29153] [ 4] /users/krmedam/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libmultiphaseInterFoam.so(_ZN4FoamdvINS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldIdT_T0_EEEERKS8_SA_+0x1ef)[0x7f21ef1bcadf]
[compute-01-29:29153] [ 5] /users/krmedam/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libmultiphaseInterFoam.so(_ZN4Foam17multiphaseMixtureC2ERKNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEERKNS1_IdNS_13fvsPatchFieldENS_11surfaceMeshEEE+0x5a3)[0x7f21ef198703]
[compute-01-29:29153] [ 6] multiphaseInterFoam[0x4672ba]
[compute-01-29:29153] [ 7] /lib64/libc.so.6(__libc_start_main+0xfd)[0x357f81ed5d]
[compute-01-29:29153] [ 8] multiphaseInterFoam[0x4251e9]
[compute-01-29:29153] *** End of error message ***
Please help me in this issue. Eagerly awaiting a reply.
Thanks in advance.
Regards,
Krishna.
krishtej23 is offline   Reply With Quote
Old   June 22, 2015, 06:19
Saideep
Saideep is on a distinguished road
Hi Krish;
I guess there is no problem running the case on the cluster but i guess there is some sort of problem with the code.
Maybe you edited the code and compiled it successfully however at some point while running the code you are hitting some function where you could be dividing with 0 thereby causing this error.
Maybe, the easiest way to start is just try a simple case without modification and it should work perfectly and later edit the code stepwise.
Hope this was useful;
Saideep
Saideep is offline   Reply With Quote
Old   June 22, 2015, 10:25
krishh
Originally Posted by Saideep View Post
Hi Krish;
Saideep
Hi Saideep,
Thanks for the reply.
I didn't messup anything with the functions of multiphaseInterFoam.
Sure, I'l try your suggestion and get back to you.
Thank you,
Krishna.
Old   June 22, 2015, 10:39
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
If we try to decipher the error message:
1. Error happened in multiphaseMixture::multiphaseMixture
2. The error was FPE, and it happened during division.
Let us check division operations in multiphaseMixture constructor:
nu_
    mu()/rho()
deltaN_
    "deltaN",
    1e-8/pow(average(mesh_.V()), 1.0/3.0)
So you problem can be caused by
1. zero average density
2. zero mesh volume (yet in this case, I think, the error would be in pow function not in division operator)
Provide checkMesh output, check you initial conditions.
alexeym is offline   Reply With Quote
Old   June 28, 2015, 14:12
krishh
Originally Posted by alexeym View Post
nu_
    mu()/rho()
deltaN_
    "deltaN",
Hi Alex,
Thank you for the reply and sorry for the delay in response.
I did check the output for checkMesh and everything says ok. Here is the output from checkMesh:
|  \\    /   O peration     | Version:  2.4.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.4.0-dcea1e13ff76
Exec   : checkMesh
Date   : Jun 28 2015
Time   : 14:00:25
Host   : "compute-01-30"
PID    : 17295
Case   : /auto/scratch/krmedam/drop3b_3phase_test
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    faces:            109700
    internal faces:   106300
    cells:            36000
    faces per cell:   6
    boundary patches: 3
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     36000
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
    Patch               Faces    Points   Surface topology
    bottom              900      921      ok (non-closed singly connected)
    atmosphere          900      921      ok (non-closed singly connected)
    walls               1600     1640     ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (-0.01542 0 -0.01542) (0.01542 0.018 0.01542)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Boundary openness (-1.50786e-17 -9.98796e-16 1.97989e-17) OK.
    Max cell openness = 2.13078e-16 OK.
    Max aspect ratio = 27.0443 OK.
    Minimum face area = 1.22963e-08. Maximum face area = 3.37664e-06.  Face area magnitudes OK.
    Min volume = 2.16696e-12. Max volume = 2.38919e-09.  Total volume = 1.33907e-05.  Cell volumes OK.
    Mesh non-orthogonality Max: 33.0423 average: 4.55378
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 0.623086 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
End
I also attached the case files and total output from the run in the zip file. Please have a look into it.
Thank you.
Old   June 28, 2015, 20:41
Alexey Matveichev
Maybe I did not get your idea right but atmosphere patch is something special: in every alpha (air, drop, and film) it has type inletOutlet (this is OK), inletValue is 0, and initial value is 0, i.e. there is no matter at this patch and it produces nothing in case of counter-flow So rho there is zero, and as a result you got division by zero FPE.
Since air is in contact with atmosphere initially, I have changed BC to:
    atmosphere
        type            inletOutlet;
        inletValue      uniform 1;
        value           uniform 1;
and the error disappeared.
krishtej23 likes this.
Old   June 29, 2015, 02:03
krishh
    atmosphere
        type            inletOutlet;
        value           uniform 1;
Thank you very much Alex. I corrected the mistake and it worked.
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
Mesquite - Adaptive mesh refinement / coarsening? philippose OpenFOAM Running, Solving & CFD 94 January 27, 2016 09:40
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
