Any reports on the processorAgglomerator feature ? |
July 16, 2015, 05:31 |
Hello everyone,
I quickly tested the new feature of processorAgglomerator and thought I'd share what I found. The feature has been available for a while now as posted there: http://www.openfoam.org/version2.3.0/parallel.php but I haven't seen any mention of it in the forums here. I've tested very quickly (doing only ~25 timesteps) the masterCoarsest and procFaces options and have not found positive changes in the solution speed. On a 1.7M cell case with pimpleFoam without processorAgglomerator and 10 procs i get a rougly 3.5 times faster solution than on a single processor. I do get a change in the nIntFaces/nCells but not in the solution speed. With the nAgglomeratingCells 10500; I'll get Code:
nCells nFaces/nCells nInterfaces nIntFaces/nCells profile Level nProcs avg max avg max avg max avg max avg ----- ------ --- --- --- --- --- --- --- --- --- 0 10 172927 174538 3.023 3.043 6 9 0.03318 0.0408 7.906e+08 1 10 85177 86196 3.637 3.781 6 9 0.05571 0.06825 2.499e+08 2 10 41989 42612 4.396 4.641 6 9 0.08784 0.1086 8.005e+07 3 10 20395 20848 5.159 5.411 6 9 0.1379 0.1679 2.511e+07 4 5 20134 20426 5.589 5.795 3.6 4 0.1386 0.1686 1.699e+07 5 2 24366 29273 5.838 5.886 1 1 0.06463 0.07765 1.756e+07 6 1 23939 23939 5.927 5.927 0 0 0 0 1.297e+07 7 1 11572 11572 5.891 5.891 0 0 0 0 4.01e+06 8 1 5680 5680 5.901 5.901 0 0 0 0 1.184e+06 9 1 2763 2763 5.852 5.852 0 0 0 0 3.833e+05 10 1 1349 1349 5.894 5.894 0 0 0 0 1.18e+05 11 1 658 658 5.912 5.912 0 0 0 0 3.962e+04 12 1 320 320 5.822 5.822 0 0 0 0 1.269e+04 13 1 152 152 5.783 5.783 0 0 0 0 4327 Code:
processor agglomerator : noneGAMGProcAgglomeration nCells nFaces/nCells nInterfaces nIntFaces/nCells profile Level nProcs avg max avg max avg max avg max avg ----- ------ --- --- --- --- --- --- --- --- --- 0 10 172927 174538 3.023 3.043 6 9 0.03318 0.0408 7.906e+08 1 10 85177 86196 3.637 3.781 6 9 0.05571 0.06825 2.499e+08 2 10 41989 42612 4.396 4.641 6 9 0.08784 0.1086 8.005e+07 3 10 20395 20848 5.159 5.411 6 9 0.1379 0.1679 2.511e+07 4 10 10067 10306 5.556 5.833 6 9 0.2033 0.2487 7.405e+06 5 10 4873 5023 5.734 6.009 6 9 0.291 0.3532 2.21e+06 6 10 2393 2478 5.722 5.972 6 9 0.4096 0.509 5.955e+05 7 10 1157 1207 5.606 5.868 6 9 0.5675 0.7287 1.822e+05 8 10 568 592 5.497 5.773 6 9 0.8041 1.087 4.67e+04 9 10 276 287 5.289 5.543 6 9 1.122 1.543 1.492e+04 10 10 134 140 5.073 5.391 6 9 1.637 2.243 3757 11 10 65 68 4.754 5.179 6 9 2.311 3.288 1224 12 10 32 33 4.178 4.75 6 9 3.286 4.656 304 13 10 15 16 3.364 3.938 6 9 4.835 7.2 85.4 Regards, -Louis |
July 17, 2015, 06:19 |
Hi Louis,
When it came out we have also started to look into it. Like you we have not performed a complete benchmark. At least we have not noticed a slowdown, but I guess it is also case dependent. It seems like there is a small gain in scalability for some problems, but we should do a more complete benchmark for production runs. I would not expect a huge improvement however. Regards, Tom |
Automatically export all reports in batch | f-w | STAR-CCM+ | 9 | November 17, 2022 04:14 |
Fluent result reports | Jiricbeng | OpenFOAM Post-Processing | 3 | July 7, 2014 03:57 |
Net value reports in Fluent | arizwan | FLUENT | 1 | July 30, 2013 03:14 |
Restrict Access to LANL Reports due to 911? | Zi-Wei Chiou | Main CFD Forum | 3 | November 7, 2001 11:18 |
Heat Flux Calculation under REPORTS | Alberto Schroth | FLUENT | 0 | May 16, 2000 08:19 |
