parallel running openfoam error
Old   July 27, 2015, 09:00
Default parallel running openfoam error
rou
arough
rou is on a distinguished road
Hi all,
I have the following error when I run my case in parallel:
[0] #0 [3] #0 [2] #0 [1] #0 Foam::error:rintStack(Foam::Ostream&)Foam::error :rintStack(Foam::Ostream&)Foam::error:rintStac k(Foam::Ostream&)Foam::error:rintStack(Foam::Ost ream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[3] #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[3] #2 in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #2 in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #2 in "/lib/x86_64-linux-gnu/libc.so.6"
[3] #3 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #2 in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #3 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/lib/x86_64-linux-gnu/libc.so.6"
[1] #3 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[3] #4 Foam::GAMGSolver::solveCoarsestLevel(Foam::Field<d ouble>&, Foam::Field<double> const&) const in "/lib/x86_64-linux-gnu/libc.so.6"
[2] #3 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[3] #5 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #4 Foam::GAMGSolver::solveCoarsestLevel(Foam::Field<d ouble>&, Foam::Field<double> const&) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #4 Foam::GAMGSolver::solveCoarsestLevel(Foam::Field<d ouble>&, Foam::Field<double> const&) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #4 Foam::GAMGSolver::solveCoarsestLevel(Foam::Field<d ouble>&, Foam::Field<double> const&) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[3] #6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #5 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #5 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #5 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[3] #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
[2] #8 in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
[1] #8 in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
[3] #8 in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
[0] #8
[2] in "/home/OpenFOAM/2.1.1/platforms/linux64GccDPOpt/bin/copFoam"
[2] #9 __libc_start_main[0] in "/home/OpenFOAM/2.1.1/platforms/linux64GccDPOpt/bin/copFoam"
[0] #9 __libc_start_main[1] in "/home/OpenFOAM/2.1.1/platforms/linux64GccDPOpt/bin/copFoam"
[1] #9 __libc_start_main[3] in "/home/OpenFOAM/2.1.1/platforms/linux64GccDPOpt/bin/copFoam"
[3] #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[2] #10 in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #10 in "/lib/x86_64-linux-gnu/libc.so.6"
[1] #10
[3] #10
[PC:08116] *** Process received signal ***
[PC:08116] Signal: Floating point exception (8)
[PC:08116] Signal code: (-6)
[PC:08116] Failing at address: 0x3e800001fb4
[PC:08116] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7f6dc2f4f4a0]
[PC:08116] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7f6dc2f4f425]
[PC:08116] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7f6dc2f4f4a0]
[PC:08116] [ 3] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam3PCG5solveERNS_5FieldIdEER KS2_h+0xd0d) [0x7f6dc3f8159d]
[PC:08116] [ 4] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver18solveCoarses tLevelERNS_5FieldIdEERKS2_+0x4ab) [0x7f6dc3f90f5b]
[PC:08116] [ 5] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver6VcycleERKNS_7 PtrListINS_9lduMatrix8smootherEEERNS_5FieldIdEERKS 8_S9_S9_S9_RNS1_IS8_EESD_h+0xaaa) [0x7f6dc3f9279a]
[PC:08116] [ 6] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5solveERNS_5Fi eldIdEERKS2_h+0x4c3) [0x7f6dc3f93c23]
[PC:08116] [ 7] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE5solveERKNS _10dictionaryE+0x137) [0x7f6dc4b91307]
[PC:08116] [ 8] copFoam() [0x428e6a]
[PC:08116] [ 9] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f6dc2f3a76d]
[PC:08116] [10] copFoam() [0x42b45d]
[PC:08116] *** End of error message ***
[PC:08115] *** Process received signal ***
[PC:08115] Signal: Floating point exception (8)
[PC:08115] Signal code: (-6)
[PC:08115] Failing at address: 0x3e800001fb3
[PC:08117] *** Process received signal ***
[PC:08117] Signal: Floating point exception (8)
[PC:08117] Signal code: (-6)
[PC:08117] Failing at address: 0x3e800001fb5
[PC:08115] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7ff94f90a4a0]
[PC:08115] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7ff94f90a425]
[aPC:08115] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7ff94f90a4a0]
[PC:08115] [ 3] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam3PCG5solveERNS_5FieldIdEER KS2_h+0xd0d) [0x7ff95093c59d]
[PC:08115] [ 4] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver18solveCoarses tLevelERNS_5FieldIdEERKS2_+0x4ab) [0x7ff95094bf5b]
[PC:08115] [ 5] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver6VcycleERKNS_7 PtrListINS_9lduMatrix8smootherEEERNS_5FieldIdEERKS 8_S9_S9_S9_RNS1_IS8_EESD_h+0xaaa) [0x7ff95094d79a]
[PC:08115] [ 6] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5solveERNS_5Fi eldIdEERKS2_h+0x4c3) [0x7ff95094ec23]
[PC:08115] [ 7] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE5solveERKNS _10dictionaryE+0x137) [0x7ff95154c307]
[PC:08115] [ 8] copFoam() [0x428e6a]
[PC:08115] [ 9] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7ff94f8f576d]
[PC:08115] [10] copFoam() [0x42b45d]
[PC:08115] *** End of error message ***
[PC:08117] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7fcdf53a64a0]
[PC:08117] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7fcdf53a6425]
[-PC:08117] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7fcdf53a64a0]
[PC:08117] [ 3] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam3PCG5solveERNS_5FieldIdEER KS2_h+0xd0d) [0x7fcdf63d859d]
[PC:08117] [ 4] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver18solveCoarses tLevelERNS_5FieldIdEERKS2_+0x4ab) [0x7fcdf63e7f5b]
[PC:08117] [ 5] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver6VcycleERKNS_7 PtrListINS_9lduMatrix8smootherEEERNS_5FieldIdEERKS 8_S9_S9_S9_RNS1_IS8_EESD_h+0xaaa) [0x7fcdf63e979a]
[PC:08117] [ 6] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5solveERNS_5Fi eldIdEERKS2_h+0x4c3) [0x7fcdf63eac23]
[PC:08117] [ 7] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE5solveERKNS _10dictionaryE+0x137) [0x7fcdf6fe8307]
[PC:08117] [ 8] copFoam() [0x428e6a]
[-PC:08117] [ 9] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7fcdf539176d]
[PC:08117] [10] copFoam() [0x42b45d]
[PC:08117] *** End of error message ***
[PC:08114] *** Process received signal ***
[PC:08114] Signal: Floating point exception (8)
[PC:08114] Signal code: (-6)
[PC:08114] Failing at address: 0x3e800001fb2
[PC:08114] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7f79e219e4a0]
[PC:08114] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7f79e219e425]
[PC:08114] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7f79e219e4a0]
[PC:08114] [ 3] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam3PCG5solveERNS_5FieldIdEER KS2_h+0xd0d) [0x7f79e31d059d]
[PC:08114] [ 4] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver18solveCoarses tLevelERNS_5FieldIdEERKS2_+0x4ab) [0x7f79e31dff5b]
[PC:08114] [ 5] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver6VcycleERKNS_7 PtrListINS_9lduMatrix8smootherEEERNS_5FieldIdEERKS 8_S9_S9_S9_RNS1_IS8_EESD_h+0xaaa) [0x7f79e31e179a]
[PC:08114] [ 6] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5solveERNS_5Fi eldIdEERKS2_h+0x4c3) [0x7f79e31e2c23]
[PC:08114] [ 7] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE5solveERKNS _10dictionaryE+0x137) [0x7f79e3de0307]
[PC:08114] [ 8] copFoam() [0x428e6a]
[PC:08114] [ 9] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f79e218976d]
[PC:08114] [10] copFoam() [0x42b45d]
[PC:08114] *** End of error message ***
mpirun noticed that process rank 2 with PID 8116 on node PC exited on signal 8 (Floating point exception).
I could not find where is the problem
Any help or suggestion is greatly appreciated.
rou is offline   Reply With Quote
Old   July 28, 2015, 14:21
Saideep
Saideep is on a distinguished road
hi;
could you run the simulation on 1 node?
If that works then this shall work normal else there is some interesting problem. Else there could be some error in the code or case keywords.
Saideep
Saideep is offline   Reply With Quote
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
