Trouble with simpleFoam
Old   June 7, 2017, 20:07
Default Trouble with simpleFoam
kinbean is on a distinguished road
Hi, I'm trying to run simpleFoam on OpenFoam 4.1 using:
foamJob simpleFoam
and I receive:
Application : simpleFoam
Executing: /opt/openfoam4/platforms/linux64GccDPInt32Opt/bin/simpleFoam > log 2>&1 &
and when I check top command nothing is running.
I have no idea where to begin to solve this error, if anyone has any insight I would very much appreciate it.
I have modified the motorBike tutorial
Forgive me as I am new to CFD and OpenFOAM.
Thank you
kinbean is offline   Reply With Quote
Old   June 7, 2017, 21:14
hokhay is on a distinguished road
It looks to me that foamJob is running simpleFoam in the background and put the process log in a log file. Try to look for the log file.
You can run the case using only simpleFoam. Your command window should show you all the process
Sent from my LG-H818 using CFD Online Forum mobile app
hokhay is offline   Reply With Quote
Old   June 7, 2017, 21:21
Thanks for the reply.
The command window shows me nothing it just stays on
and if i click enter again i get
[1] 18928
Sorry if I am not explaining this properly I am quite new to CFD and OpenFoam.
Old   June 7, 2017, 21:26
Sorry I didn't explain clearly. What I mean is instead of typing " foamJob simpleFoam", you should use only "simpleFoam" to run your case. Try it
Old   June 8, 2017, 06:07
Ah thanks, oh a whole bunch of warnings appeared. I guess I should start going through these and fixing them.
Thank you for your help
Old   June 8, 2017, 07:15
I've managed to fix some of the errors, but I'm left with this. Does anyone know how to approach this?
forces forceCoeffs1:
    Not including porosity effects
forceCoeffs forceCoeffs1:
--> FOAM Warning :
    From function void Foam::timeControl::read(const Foam::dictionary&)
    in file db/functionObjects/timeControl/timeControl.C at line 89
    Reading "/home/kizbiz/OpenFOAM/kizbiz-4.1/run/tutorials/pipe/system/controlDict.functions.forces1" from line 11 to line 26
    Using deprecated 'outputControl'
    Please use 'writeControl' with 'writeInterval'
forces forces1:
--> FOAM FATAL IO ERROR:
keyword cumulative is undefined in dictionary "/home/kizbiz/OpenFOAM/kizbiz-4.1/run/tutorials/pipe/system/controlDict.functions.forces1.binData"
file: /home/kizbiz/OpenFOAM/kizbiz-4.1/run/tutorials/pipe/system/controlDict.functions.forces1.binData from line 23 to line 26.
    From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 441.
Old   June 9, 2017, 07:03
Ricky
kera is on a distinguished road
--> FOAM Warning :
forces forces1:
Hello
you are missing "cumulative" within subDict binData in your foceCoeffs functionObject. It should look something like this:
forceCoeffs1
    type        forceCoeffs;
    functionObjectLibs ( "libforces.so" );
    outputControl   timeStep;
    timeInterval    1;
    log         yes;
    patches     ( motorBikeGroup );
    rhoName     rhoInf;      // Indicates incompressible
    rhoInf      1;           // Redundant for incompressible
    liftDir     (0 0 1);
    dragDir     (1 0 0);
    CofR        (0.72 0 0);  // Axle midpoint on ground
    pitchAxis   (0 1 0);
    magUInf     20;
    lRef        1.42;        // Wheelbase length
    Aref        0.75;        // Estimated
    binData
        nBin        20;          // output data into 20 bins
        direction   (1 0 0);     // bin direction
        cumulative  yes;
Regards,
Ricky
If it is easy, then something is fishy!
kera is offline   Reply With Quote
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 15:26
having trouble using simpleFoam and moving reference frame (MRF) joyw OpenFOAM 5 June 24, 2018 15:23
simpleFoam parallel solver & Fluent polyhedral mesh Zlatko OpenFOAM Running, Solving & CFD 3 September 26, 2014 06:53
Trying to run a benchmark case with simpleFoam spsb OpenFOAM 3 February 24, 2012 09:07
Small speed simpleFoam trouble milos OpenFOAM Post-Processing 0 November 17, 2009 08:00
