MULES with axial symmetry (wedge+empty BC)
Old   August 14, 2015, 11:05
Default MULES with axial symmetry (wedge+empty BC)
Robert Sawko
AlmostSurelyRob will become famous soon enough
Dear OpenFOAM users and developers,
I am trying to run a simple pipe with constriction and axial symmetry. Something fairly similar to the geometry posted here [1]. The solver I am using is twoPhaseEulerFoam but I observed similar behavior in interFoam too.
My inlet condition is uniform for all quantities and for alpha I am setting something 0.015. The wedge and empty BC are applied on the the sides and at the centre line respectively e.g. my alpha BC looks like this
boundaryField
    outlet
        type               inletOutlet;
        inletValue      uniform 0;
    walls
        type               zeroGradient;
    inlet
        type               fixedValue;
        value             uniform 0.02;
    front
        type            wedge;
    back
        type            wedge;
    axis
       type      empty;
The problem is that almost immediately the centreline is beginning to produce additional mass. And my alpha distribution begins to look like this
After this all sort of evil begins to occur. Viscosity there goes up, velocity develops a completely different profile than in the 3D case and Co number increases gradually.
I checked the case several times now and a 3D equivalent works. Single phase solvers work with this setup too so my guess is that multiphase solver is the culprit. My guess is that MULES is causing the problem here, but I cannot be sure.
Please let me know if you have any suggestions on how to fix it. Can post a more detailed setup.
[1] http://openfoamwiki.net/index.php/Contrib/MakeAxialMesh
AlmostSurelyRob is offline   Reply With Quote
Free Surface Ship Flow timfranke OpenFOAM Running, Solving & CFD 322 March 3, 2021 09:04
[snappyHexMesh] sHM quality of multi-region aminem OpenFOAM Meshing & Mesh Conversion 0 April 16, 2015 11:38
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 02:53
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
