residual = nan on iteration 1 with rhoSimpleFoam
Old   September 23, 2015, 23:46
Default residual = nan on iteration 1 with rhoSimpleFoam
me3840 is on a distinguished road
Hello folks,
First try using rhoSimpleFoam here. Haven't really done much compressible flow in OpenFOAM before. I have a very simple case of a sphere in a tube. The mesh is about 500k cells and passes all meshCheck just fine.
My BCs are all very simple (trying to keep it that way the first time). I have:
Inlet (U fixed value, T fixed value, zero grad else)
Outlet (p fixed value, zero grad else)
and the walls (walls and sphere) which are all set to 0/zeroGradient.
However, it seems on my first iteration, all of the residuals are nan's and it crashes very quickly:
Time = 1
GAMG: Solving for Ux, Initial residual = nan, Final residual = nan, No Iterations 1000
GAMG: Solving for Uy, Initial residual = nan, Final residual = nan, No Iterations 1000
GAMG: Solving for Uz, Initial residual = nan, Final residual = nan, No Iterations 1000
smoothSolver: Solving for e, Initial residual = nan, Final residual = nan, No Iterations 1000
GAMG: Solving for p, Initial residual = nan, Final residual = nan, No Iterations 1000
time step continuity errors : sum local = nan, global = nan, cumulative = nan
rho max/min : 0.025 0.025
GAMG: Solving for omega, Initial residual = nan, Final residual = nan, No Iterations 1000
GAMG: Solving for k, Initial residual = nan, Final residual = nan, No Iterations 1000
ExecutionTime = 389.481 s ClockTime = 389 s
I can't seem to figure out why. Did I miss something in my BCs?
I set pRefValue manually to be 101325 Pa, so my other BCs and initial condition pressure should be gauge to that.
It says that the rho max/min is 0.025 - but the min and max limiter is 0.5 and 1.5, how did it get that low? This is almost STP...
There is a defaultFaces patch, but this is just left over from blockMesh and has zero faces, so I shouldn't need to worry about it, right?
Here's some of my files:
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (20 0 0);
boundaryField
    defaultFaces
        type            fixedValue;
        value           uniform (0 0 0);
	inlet
        type            fixedValue;
        value           uniform (20 0 0);
	outlet
        type            zeroGradient;
	wall
        type            fixedValue;
	sphere
        type            fixedValue;
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    defaultFaces
        type            zeroGradient;
	 inlet
        type            zeroGradient;
	 outlet
        type            fixedValue;
		value			uniform 0;
	wall
        type            zeroGradient;
	sphere
        type            zeroGradient;
FoamFile
    version     2.0;
    format      ascii;
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 300;
boundaryField
    defaultFaces
        type            zeroGradient;
	 inlet
        type            fixedValue;
        value           uniform 300;
	 outlet
        type            zeroGradient;
	wall
        type            zeroGradient;
	sphere
        type            zeroGradient;
dimensions      [ 0 2 -2 0 0 0 0 ];
internalField   uniform 22.815;
boundaryField
    defaultFaces
        type            compressible::kqRWallFunction;
        value           uniform 0;
	inlet
        type            fixedValue;
        value           uniform 22.815;
	outlet
        type            fixedValue;
	wall
        value           uniform 0;
	sphere
        value           uniform 0;
dimensions      [ 0 0 -1 0 0 0 0 ];
internalField   uniform 477.26;
boundaryField
    defaultFaces
        type            compressible::omegaWallFunction;
        value           uniform 0;
	inlet
        type            fixedValue;
        value           uniform 477.76;
	outlet
        type            fixedValue;
	wall
        value           uniform 0;
	 sphere
        value           uniform 0;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      bounded Gauss linearUpwindV Gauss linear;
    div((muEff*dev2(T(grad(U))))) Gauss linear Gauss linear;
    div(phi,omega) bounded Gauss linearUpwind Gauss linear;
    div(phi,k)      bounded Gauss linearUpwind Gauss linear;
    div(phi,Ekp)    bounded Gauss linearUpwind Gauss linear;
	div(phi,e)    bounded Gauss linearUpwind Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p
        solver          GAMG;
        tolerance       1e-08;
        relTol          0.05;
        smoother        GaussSeidel;
        cacheAgglomeration on;
        nCellsInCoarsestLevel 20;
        agglomerator    faceAreaPair;
        mergeLevels     1;
    U
        solver          GAMG;
        tolerance       1e-08;
        relTol          0.05;
        mergeLevels     1;
    e
        solver          smoothSolver;
        tolerance       1e-06;
        relTol          0.1;
    "(k|omega)"
        $U;
        tolerance       1e-07;
        relTol          0.1;
SIMPLE
    nNonOrthogonalCorrectors 0;
    rhoMin          rhoMin [ 1 -3 0 0 0 ] 0.5;
    rhoMax          rhoMax [ 1 -3 0 0 0 ] 1.5;
	pRefPoint (-4.9 0 0);
	pRefValue 101325;
    residualControl
        p               1e-2;
        U               1e-4;
        e               1e-3;
        // possibly check turbulence fields
        "(k|epsilon|omega)" 1e-3;
relaxationFactors
    fields
        p               0.3;
        rho             0.05;
    equations
        U               0.7;
        "(k|omega)"   0.7;
        e               0.5;
me3840 is offline   Reply With Quote
Old   September 25, 2015, 10:55
Nobody with any clues? Hm. I was going to try and see if I can get it to run in just a pipe.
Old   September 27, 2015, 21:25
Joseph Urich
jurich is on a distinguished road
I've always run rhoSimpleFoam using absolute pressures.
I don't think pRefValue works the way you describe using it. See this thread http://www.cfd-online.com/Forums/ope...prefvalue.html, section 4.5.3.1 of the user guide, and src/finiteVolume/fvMatrices/fvMatrix/fvMatrix.C; it seems to set the pressure level in one cell only.
jurich is offline   Reply With Quote
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 02:20
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 08:35
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
