Looking for a simple example with fvOption in OpenFOAM |
September 24, 2015, 00:55 |
Bibin K.S
Rep Power: 11 |
Can any body explain the use of fvOptions in OpenFOAM with a simple example..
September 25, 2015, 04:37 |
Rep Power: 16 |
please be more specific. It really depends on what you're trying to achieve. The fvOptions functionality can be used to add source terms to the differential equations at run time and is therefore pretty powerful. It can be used to model many different things, from semipermeable materials to rotating systems. I'd suggest to have a look at the article http://www.sourceflux.de/blog/adding...ons-fvoptions/ that explains the usage within at 2D mixer vessel. You can also look into the other tutorial cases. You can find cases using fvOptions using the find (used to find files) and tut (changes into the OpenFOAM tutorials directory, when installed correctly) commands. Here are the results on my machine: Code:
user:~$ tut user:/opt/OpenFOAM/OpenFOAM-2.4.0/tutorials$ find . -name fvOptions ./incompressible/pimpleFoam/channel395/system/fvOptions ./incompressible/simpleFoam/turbineSiting/system/fvOptions ./incompressible/simpleFoam/mixerVessel2D/system/fvOptions ./lagrangian/simpleReactingParcelFoam/verticalChannel/system/fvOptions ./lagrangian/coalChemistryFoam/simplifiedSiwek/system/fvOptions ./lagrangian/reactingParcelFoam/filter/system/fvOptions ./lagrangian/reactingParcelFoam/verticalChannel/system/fvOptions ./lagrangian/LTSReactingParcelFoam/counterFlowFlame2D/system/fvOptions ./lagrangian/LTSReactingParcelFoam/verticalChannel/system/fvOptions ./compressible/rhoSimpleFoam/angledDuctExplicitFixedCoeff/system/fvOptions ./compressible/rhoPimpleFoam/ras/angledDuct/system/fvOptions ./compressible/rhoPimpleFoam/ras/mixerVessel2D/system/fvOptions ./compressible/rhoPorousSimpleFoam/angledDuctImplicit/system/fvOptions ./compressible/rhoLTSPimpleFoam/angledDuct/system/fvOptions ./compressible/rhoPimplecFoam/angledDuct/system/fvOptions ./heatTransfer/chtMultiRegionSimpleFoam/heatExchanger/system/air/fvOptions ./heatTransfer/chtMultiRegionSimpleFoam/heatExchanger/system/porous/fvOptions ./multiphase/twoPhaseEulerFoam/laminar/injection/constant/fvOptions ./multiphase/driftFluxFoam/ras/mixerVessel2D/constant/fvOptions ./multiphase/multiphaseInterFoam/laminar/mixerVessel2D/constant/fvOptions ./multiphase/interFoam/laminar/mixerVessel2D/constant/fvOptions ./multiphase/interFoam/ras/angledDuct/system/fvOptions |
OpenFOAM Foundation Releases OpenFOAM v2.3.0 | opencfd | OpenFOAM Announcements from OpenFOAM Foundation | 3 | December 23, 2014 03:43 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 09:04 |
How to setup a simple OpenFOAM cluster? | TommiPLaiho | OpenFOAM Installation | 3 | October 27, 2013 15:15 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
OpenFOAM Training and Workshop Zagreb 2628Jan2006 | hjasak | OpenFOAM | 1 | February 2, 2006 21:07 |
