Problems with InterFoam!!
Old   October 5, 2015, 07:44
Default Problems with InterFoam!!
Berat Loshi
Berati26 is on a distinguished road
Hallo,
im simulating with InterFoam and now after running InterFoam i have this Error. Seems like not gut.
have anybody an idea what ist the Problem now? i have used the folder: multiphase/InterFoam/ras/ weirOverflow.
Thanks a lot!
Berati26 is offline   Reply With Quote
Old   October 5, 2015, 08:02
Pablo Higuera
Phicau is on a distinguished road
Hi Berat,
it appears that there is no water in your domain, have you performed setFields?
Best,
Pablo
Phicau is offline   Reply With Quote
Old   October 13, 2015, 09:19
Default set FieldsDict
Berat Loshi
my setFieldsDict look like this,
i think alpha.water 1 means like its Watter in the domain or?
Old   October 13, 2015, 09:21
Berat Loshi
sorry i forget to Attach the pic. Here it is!
Old   October 15, 2015, 05:25
Knut Erik T. Giljarhus
eric will become famous soon enough
I agree with Pablo, it looks like the water phase is not set correctly. What is the size of your domain? Did you remember to run "setFields" before starting the simulation?
eric is offline   Reply With Quote
Old   October 15, 2015, 07:04
Berat Loshi
ok i have uplode my blockMeshdict ... The dimensions are 5.3/8.4/0.9 m
and i have only inlet and outlet patches of the Domain.
Then the Geometry is an Pool like in the Picture. I model it with Sketchup, and i separate export the .stl fils, Inlet Outlet and Walls.
So i have 2 times the patch name Inlet and Outlet...
i think i make something wrong
And no, after i finished snappyHexMesh i direktli run InterFoam. the setFieldsDict i dont run.
Old   October 15, 2015, 07:05
Berat Loshi
| \\ / O peration | Version: 2.3.1 |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(-0.1 -0.05 -0.1)
(8.4 -0.05 -0.1)
(8.4 0.9 -0.1)
(-0.1 0.9 -0.1)
(-0.1 -0.05 5.3)
(8.4 -0.05 5.3)
(8.4 0.9 5.3)
(-0.1 0.9 5.3)
blocks
hex (0 1 2 3 4 5 6 7) (10 10 20) simpleGrading (1 1 1)
edges
boundary
inlet
type patch;
faces
(0 4 7 3)
outlet
type patch;
faces
(1 2 6 5)
mergePatchPairs
Old   October 15, 2015, 07:23
TobM is on a distinguished road
The coordinates of the box from your setFieldsDict have to be inside your domain.
Anyway, you should check if setFields worked correctly with paraview.
TobM is offline   Reply With Quote
Old   October 15, 2015, 07:25
Berat Loshi
and now after running my sefFields i get thiss error
Have somebody an Idea what can i do to fix all this problems?
Old   October 15, 2015, 07:41
The error tells you exactly what to do, you have to supply pRefCell or pRefPoint in your fvSolution file. Just look into an interfoam tutorial case.
Old   October 15, 2015, 07:56
I think you are trying to solve too many problems at once, without understanding the basics. I suggest looking at the damBreak tutorial for interFoam. Understand how the mesh is set up, and how the setFields utility works.
Then you can move to your case. Copy the fvSchemes and fvSolution files from the damBreak tutorial to use as a starting point. You also need to fix the setFieldsDict to match where you actually want water in your domain. Before trying to run interFoam, verify that you have the correct water field in Paraview.
Old   October 15, 2015, 08:01
Berat Loshi
Hallo TobM,
i have lookt in the weirOverflow turorial, but in the fvSolutuion file is no pRefCell or pRefPoint, Where should I keep my mind in order to insert correctly?
Old   October 15, 2015, 08:09
Berat Loshi
HAllo Eric, im using wairoverflow tutorial, but in all thes tutorial they have only a geometrie from blockMesh . I have the file I created from blockmesh and then my geometry, so i cant not realy compare the tutorial with my case.
Old   October 15, 2015, 08:16
One very useful command is grep, use it like this:
grep -R pRefCell *
in tutorials/multiphase/interfoam and you will get a list with all files with occurrences of pRefCell within the interfoam tutorials.
When you don't find something in one tutorial look into another and always google your problem.
Benchmarking interFOAM -- problems... einatlev OpenFOAM Running, Solving & CFD 6 March 19, 2015 10:16
interFoam simulation yields inconsistent results for alpha1 surface Ralinus OpenFOAM Running, Solving & CFD 8 January 13, 2014 08:54
Pressure convergence problems with sloped bottom in interFoam gradylemoine OpenFOAM Running, Solving & CFD 0 November 18, 2013 18:33
Problems with interFoam usage vrecha OpenFOAM Running, Solving & CFD 4 January 5, 2008 03:34
Problems starting new case interFoam billy OpenFOAM Running, Solving & CFD 3 June 21, 2006 10:18
