Flow past a porous cylindrical shell in 2D
Old   October 13, 2015, 05:24
Default Flow past a porous cylindrical shell in 2D
LP
larspkar is on a distinguished road
Hi. Not sure if I posted this in the correct place, but I want to do a project on flow past a porous geometry, e.g. a cylinder or square, with wall thickness close to 0. The inside of the geometry should have the same fluid properties as the outside. I was hoping to be able to calculate the forces upon such a geometry, to compare it with my own computations using potential theory. Is it doable?
Thanks in advance
Lars
larspkar is offline   Reply With Quote
porous shell
Strange behaviour: Ethanol solution flow on channel with interface to porous domain khariel CFX 6 December 11, 2014 17:08
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 10:34
unexpected flow speeds within porous zones MasterCooler OpenFOAM 11 May 2, 2012 07:48
compressible flow through porous media Chirag2302 FLUENT 0 March 2, 2012 23:13
Porous media flow with diffusion albertinho OpenFOAM 0 March 31, 2010 17:14
