Floating point exception error
Like Tree2Likes
Old   October 15, 2015, 04:25
Default Floating point exception error
Mike Lob
lpz_michele is on a distinguished road
Hi everyone! I'm tring to simulate the flowfield on a stationary VAWT for some debugging. In the complete simulation (VAWT rotating) iterations start, but do not make sense. So I'm trying the same dictionaries with no rotations. Using pimpleFoam unstead of pimpleDyMFoam.
After running the first iteration for U, this appears:
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2   in "/lib64/libc.so.6"
#3  double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4  Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#5  Foam::GAMGSolver::solveCoarsestLevel(Foam::Field<double>&, Foam::Field<double> const&) const at ??:?
#6  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
#7  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#8  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
#9  Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
 at ??:?
#11  __libc_start_main in "/lib64/libc.so.6"
#12
 at /home/abuild/rpmbuild/BUILD/glibc-2.19/csu/../sysdeps/x86_64/start.S:125
How can I fix it?
lpz_michele is offline   Reply With Quote
Old   October 15, 2015, 04:40
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
We need more information.
1) How does the rest of the log file look like?
2) Boundary conditions
3) fvSchemes
4) fvSolution
Cheers,
Philipp.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   October 15, 2015, 05:19
Mike Lob
tesisti@ime042:~/OpenFOAM/tesisti-2.3.1/run/LOPEZ_tent./flussoOltreOstacolo_tent1_laminare> of231
tesisti@ime042:~/OpenFOAM/tesisti-2.3.1/run/LOPEZ_tent./flussoOltreOstacolo_tent1_laminare> pimpleFoam
|  \\    /   O peration     | Version:  2.3.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.3.1-262087cdf8db
Exec   : pimpleFoam
Date   : Oct 15 2015
Time   : 11:26:00
Host   : "ime042"
PID    : 27789
Case   : /home/tesisti/OpenFOAM/tesisti-2.3.1/run/LOPEZ_tent./flussoOltreOstacolo_tent1_laminare
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RASModel
Selecting RAS turbulence model kOmegaSST
kOmegaSSTCoeffs
    alphaK1         0.85;
    alphaK2         1;
    alphaOmega1     0.5;
    alphaOmega2     0.856;
    gamma1          0.555556;
    gamma2          0.44;
    beta1           0.075;
    beta2           0.0828;
    betaStar        0.09;
    a1              0.31;
    b1              1;
    c1              10;
    F3              false;
No finite volume options present
PIMPLE: max iterations = 100
    field "(p|U|k|omega)"       : relTol 0, tolerance 0.01
Starting time loop
forces forces:
    Not including porosity effects
Courant Number mean: 2.72708e-09 max: 2.97915e-07
Time = 1.09083e-05
PIMPLE: iteration 1
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 8.13576e-14, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 6.4221e-14, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 6.59122e-14, No Iterations 1
...ETC...
fvSchemes
|  \\    /   O peration     | Version:  2.3.0                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
    grad(U)        Gauss linear 1;
divSchemes
    default         none;
    div(phi,U)      Gauss linearUpwind grad(U);
    div(phi,k)      Gauss upwind;
    div(phi,omega) Gauss upwind;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
    interpolate(HbyA) linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
    pcorr           ;
fvSolution
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    pcorr
        solver GAMG;
    smoother GaussSeidel;
    nPreSweeps 0;
    nPostSweeps 2;
    cacheAgglomeration off;
    agglomerator faceAreaPair;
    nCellsInCoarsestLevel 10;
    mergeLevels 1;
    tolerance 0.02;
    relTol 0;
    p
    $pcorr;
    tolerance 1e-07;
    relTol 0.01;
    pFinal
        $p;
    tolerance     1e-07;
        relTol          0;
    U
    solver        smoothSolver;
    tolerance    1e-8;
    relTol        0.1;
    UFinal
    tolerance    1e-8;
    relTol        0.1;
    "(k|omega)"
        tolerance       1e-7;
        relTol          0.1;
    "(k|omega)Final"
        $U;
    tolerance     1e-7;
        relTol          0;
PIMPLE
    nNonOrthogonalCorrectors 0;
    correctPhi        no;
    nOuterCorrectors    100;
    nCorrectors         2;
    pRefCell         0;
    pRefValue        0;
residualControl
    "(p|U|k|omega)"
      tolerance 1e-2;
      relTol 0;
relaxationFactors
    fields
    equations
    "p.*"        0.3;
    "U.*"        0.7;
    "k.*"        0.7;
    "omega.*"        0.7;
Old   October 15, 2015, 05:22
Mike Lob
boundary
FoamFile
    version     2.0;
    format      ascii;
    class       polyBoundaryMesh;
    location    "constant/polyMesh";
    object      boundary;
15
    cubodx
        type patch;
        nFaces 592;
        startFace 7406234;
    cubosopra
        type patch;
        nFaces 588;
        startFace 7406826;
    cubosotto
        type patch;
        nFaces 588;
        startFace 7407414;
    cubosx
        type patch;
        nFaces 590;
        startFace 7408002;
    inlet
        type patch;
        nFaces 478;
        startFace 7408592;
    outlet
        type patch;
        nFaces 476;
        startFace 7409070;
    pala1
        type wall;
        nFaces 9506;
        startFace 7409546;
    pala1sopra
        type wall;
        nFaces 301;
        startFace 7419052;
    pala1sotto
        type wall;
        nFaces 301;
        startFace 7419353;
    pala2
        type wall;
        nFaces 9506;
        startFace 7419654;
    pala2sopra
        type wall;
        nFaces 301;
        startFace 7429160;
    pala2sotto
        type wall;
        nFaces 301;
        startFace 7429461;
    pala3
        type wall;
        nFaces 9506;
        startFace 7429762;
    pala3sopra
        type wall;
        nFaces 301;
        startFace 7439268;
    pala3sotto
        type wall;
        nFaces 301;
        startFace 7439569;
k
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      k;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0.375;
boundaryField
    cubodx
        type            zeroGradient;
    cubosopra
        type            zeroGradient;
    cubosotto
        type            zeroGradient;
    cubosx
        type            zeroGradient;
    inlet
        type            turbulentIntensityKineticEnergyInlet;
        intensity       0.05;
        value           uniform 0.375;
    outlet
        type            inletOutlet;
        inletValue      uniform 0.375;
    pala1
        type            kqRWallFunction;
    pala1sopra
    pala1sotto
    pala2
    pala2sopra
    pala2sotto
    pala3
    pala3sopra
    pala3sotto
omega
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      omega;
dimensions      [0 0 -1 0 0 0 0];
internalField   uniform 1118.03;
boundaryField
    cubodx
        type            zeroGradient;
    cubosopra
        type            zeroGradient;
    cubosotto
        type            zeroGradient;
    cubosx
        type            zeroGradient;
    inlet
        type            fixedValue;
        value           uniform 1118.03;
    outlet
        type            inletOutlet;
        inletValue      uniform 1118.03;
    pala1
        type            omegaWallFunction;
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        beta1           0.075;
    pala1sopra
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        beta1           0.075;
    pala1sotto
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        beta1           0.075;
    pala2
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        beta1           0.075;
    pala2sopra
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        beta1           0.075;
    pala2sotto
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        beta1           0.075;
    pala3
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        beta1           0.075;
    pala3sopra
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        beta1           0.075;
    pala3sotto
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        beta1           0.075;
p
FoamFile
    version     2.0;
    format      ascii;
    object      p;
internalField   uniform 0;
boundaryField
    cubodx
        type zeroGradient;
    cubosopra
        type zeroGradient;
    cubosotto
        type zeroGradient;
    cubosx
        type zeroGradient;
    inlet
        type zeroGradient;
    outlet
        type fixedValue;
    value $internalField;
    pala1
        type zeroGradient;
    pala1sopra
        type zeroGradient;
    pala1sotto
    type zeroGradient;
    pala2
        type zeroGradient;
    pala2sopra
       type    zeroGradient;
    pala2sotto
       type  zeroGradient;
    pala3
        type    zeroGradient;
    pala3sopra
        type zeroGradient;
    pala3sotto
     type zeroGradient;
U
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    cubodx
        type slip;
    cubosopra
        type slip;
    cubosotto
        type slip;
    cubosx
        type slip;
    inlet
        type fixedValue;
    value uniform (10.0 0 0);
    outlet
        type zeroGradient;
    pala1
        type fixedValue;
    pala1sopra
        type fixedValue;
    pala1sotto
    type fixedValue;
    pala2
        type fixedValue;
    pala2sopra
       type    fixedValue;
    pala2sotto
       type  fixedValue;
    pala3
        type    fixedValue ;
    pala3sopra
        type fixedValue;
    pala3sotto
     type fixedValue;
Old   October 15, 2015, 05:30
Philipp
Michele, you use a wrong syntax for the relaxation factors in your fvSolution file.
Firstly, "p" must be written under "fields" instead of "equations" as far as I know. Thus, I guess your pressure field is not under-relaxated at all.
Secondly, using the ".*" notation relaxes all iterations, also the last one, as someone stated to one of my posts here:
http://www.cfd-online.com/Forums/ope...tml#post481037
So you should not use the ".*".
I will write some more things if you have posted the rest of the log file.
lpz_michele likes this.
Old   October 15, 2015, 05:32
Mike Lob
I have already posted the rest of the log file.
Thank you for the help.
Old   October 15, 2015, 06:11
Philipp
Great, didn't see it.
The pressure solver doesn't work. Could you try to run it with some other setting? If the error remains we need to search somewhere else...
    "(p|pFinal)"
        solver           GAMG;
        tolerance        1e-12;
        relTol           0.1;
        maxIter         20;
        smoother         DIC;
        nPreSweeps       1;
        nPostSweeps      1;
        nFinestSweeps    2;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 1000;
        mergeLevels      1;
Old   October 15, 2015, 06:38
Mike Lob
I've replaced the code you pasted in the precedent post with the precedent one. And changed all the settings in relaxation factors. My fvSolution file now looks like:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
      "(p|pFinal)"
        solver           GAMG;
        tolerance        1e-12;
        relTol           0.1;
        maxIter         20;
        smoother         DIC;
        nPreSweeps       1;
        nPostSweeps      1;
        nFinestSweeps    2;
        mergeLevels      1;
    p
    $pcorr;
    tolerance 1e-07;
    relTol 0.01;
    pFinal
        $p;
    tolerance     1e-07;
        relTol          0;
    U
    tolerance    1e-8;
    relTol        0.1;
    UFinal
    tolerance    1e-8;
    relTol        0.1;
    "(k|omega)"
        tolerance       1e-7;
        relTol          0.1;
    "(k|omega)Final"
        $U;
    tolerance     1e-7;
        relTol          0;
PIMPLE
    correctPhi        no;
    nCorrectors         2;
    pRefCell         0;
    pRefValue        0;
residualControl
    "(p|U|k|omega)"
      tolerance 1e-2;
      relTol 0;
relaxationFactors
    fields
       p        0.3;
    equations
    U        0.7;
    k        0.7;
    omega        0.7;
Trying to launch but it gives me
 PIMPLE: iteration 1
--> FOAM FATAL IO ERROR:
keyword solver is undefined in dictionary "/home/tesisti/OpenFOAM/tesisti-2.3.1/run/LOPEZ_tent./tent_1_ostacolo_simple_forum/system/fvSolution.solvers.p"
file: /home/tesisti/OpenFOAM/tesisti-2.3.1/run/LOPEZ_tent./tent_1_ostacolo_simple_forum/system/fvSolution.solvers.p from line 46 to line 47.
    From function dictionary::lookupEntry(const word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 437.
FOAM exiting
Maybe a sytax error? Or just replaced the wrong part?
Old   October 15, 2015, 06:43
Philipp
Yes. You need to delete the two old entries "p{ ... }" and "pFinal{ ... }" directly below the new one. Otherwise "my" code is overwritten by your old entries and the solver keyword is missing.
Old   October 15, 2015, 08:53
Mike Lob
Well, this time it gets 7 iterations to create problems
error
[3] #1  Foam::sigFpe::sigHandler(int) at ??:?
[3] #2   in "/lib64/libc.so.6"
[3] #3  Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:?
[3] #4  Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
[3] #5  Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
[3] #6
[3]  at ??:?
[3] #7
[3]  at ??:?
[3] #8
[3]  at ??:?
[3] #9
[3]  at ??:?
[3] #10  __libc_start_main in "/lib64/libc.so.6"
[3] #11
[3]  at /home/abuild/rpmbuild/BUILD/glibc-2.19/csu/../sysdeps/x86_64/start.S:125
[ime042:32119] *** Process received signal ***
[ime042:32119] Signal: Floating point exception (8)
[ime042:32119] Signal code:  (-6)
[ime042:32119] Failing at address: 0x3e800007d77
[ime042:32119] [ 0] /lib64/libc.so.6(+0x35200) [0x7fe8b18e0200]
[ime042:32119] [ 1] /lib64/libc.so.6(gsignal+0x37) [0x7fe8b18e0187]
[ime042:32119] [ 2] /lib64/libc.so.6(+0x35200) [0x7fe8b18e0200]
[ime042:32119] [ 3] /home/tesisti/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam19GaussSeidelSmoother6smoothERKNS_4wordERNS_5FieldIdEERKNS_9lduMatrixERKS5_RKNS_10FieldFieldIS4_dEERKNS_8UPtrListIKNS_17lduInterfaceFieldEEEhi+0x369) [0x7fe8b2a17719]
[ime042:32119] [ 4] /home/tesisti/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam19GaussSeidelSmoother6smoothERNS_5FieldIdEERKS2_hi+0x2d) [0x7fe8b2a1795d]
[ime042:32119] [ 5] /home/tesisti/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam12smoothSolver5solveERNS_5FieldIdEERKS2_h+0x4e7) [0x7fe8b2a11397]
[ime042:32119] [ 6] pimpleFoam() [0x439c5a]
[ime042:32119] [ 7] pimpleFoam() [0x44e78f]
[ime042:32119] [ 8] pimpleFoam() [0x44ea7e]
[ime042:32119] [ 9] pimpleFoam() [0x42020d]
[ime042:32119] [10] /lib64/libc.so.6(__libc_start_main+0xf5) [0x7fe8b18ccb05]
[ime042:32119] [11] pimpleFoam() [0x421071]
[ime042:32119] *** End of error message ***
mpirun noticed that process rank 3 with PID 32119 on node ime042 exited on signal 8 (Floating point exception).
log file
Exec   : pimpleFoam -parallel
Date   : Oct 15 2015
Time   : 14:50:22
Host   : "ime042"
PID    : 32116
Case   : /home/tesisti/OpenFOAM/tesisti-2.3.1/run/LOPEZ_tent./tent_1_ostacolo_simple_forum
nProcs : 4
Slaves :
3
"ime042.32117"
"ime042.32118"
"ime042.32119"
Pstream initialized with:
    floatTransfer      : 0
    nProcsSimpleSum    : 0
    commsType          : nonBlocking
    polling iterations : 0
Create time
Reading field p
Reading field U
kOmegaSSTCoeffs
    alphaK1         0.85;
    alphaK2         1;
    alphaOmega1     0.5;
    alphaOmega2     0.856;
    gamma1          0.555556;
    gamma2          0.44;
    beta1           0.075;
    beta2           0.0828;
    betaStar        0.09;
    a1              0.31;
    b1              1;
    c1              10;
    F3              false;
Starting time loop
forces forces:
Time = 1.09083e-05
PIMPLE: iteration 1
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 8.10494e-14, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 6.42711e-14, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 6.55968e-14, No Iterations 1
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.0941324, No Iterations 6
time step continuity errors : sum local = 5.13413e-10, global = -6.965e-12, cumulative = -6.965e-12
GAMG:  Solving for p, Initial residual = 0.18443, Final residual = 0.0162853, No Iterations 2
time step continuity errors : sum local = 4.27511e-09, global = -4.4206e-10, cumulative = -4.49025e-10
PIMPLE: iteration 2
smoothSolver:  Solving for Ux, Initial residual = 0.551614, Final residual = 0.000245009, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.117547, Final residual = 6.71312e-05, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.130338, Final residual = 3.37683e-05, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.155643, Final residual = 0.0111007, No Iterations 3
time step continuity errors : sum local = 2.67407e-09, global = -1.67831e-10, cumulative = -6.16856e-10
GAMG:  Solving for p, Initial residual = 0.131887, Final residual = 0.00901081, No Iterations 2
time step continuity errors : sum local = 3.61971e-09, global = -3.24685e-10, cumulative = -9.41541e-10
PIMPLE: iteration 3
smoothSolver:  Solving for Ux, Initial residual = 0.293694, Final residual = 0.000130662, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.0586409, Final residual = 3.56826e-05, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.0660638, Final residual = 1.2281e-05, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.119831, Final residual = 0.00790474, No Iterations 2
time step continuity errors : sum local = 3.18576e-09, global = -2.72153e-10, cumulative = -1.21369e-09
GAMG:  Solving for p, Initial residual = 0.0971771, Final residual = 0.00894128, No Iterations 1
time step continuity errors : sum local = 4.45609e-09, global = -5.33984e-10, cumulative = -1.74768e-09
PIMPLE: iteration 4
smoothSolver:  Solving for Ux, Initial residual = 0.0963746, Final residual = 3.0991e-05, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.0294886, Final residual = 1.47947e-05, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.0324897, Final residual = 4.06102e-06, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.0889663, Final residual = 0.00849765, No Iterations 1
time step continuity errors : sum local = 4.15247e-09, global = -4.6771e-10, cumulative = -2.21539e-09
GAMG:  Solving for p, Initial residual = 0.0697397, Final residual = 0.00692439, No Iterations 1
time step continuity errors : sum local = 3.73189e-09, global = -4.04551e-10, cumulative = -2.61994e-09
PIMPLE: iteration 5
smoothSolver:  Solving for Ux, Initial residual = 0.0491208, Final residual = 3.19173e-05, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.0162711, Final residual = 1.53472e-05, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.0181073, Final residual = 4.73704e-06, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.0667263, Final residual = 0.00600909, No Iterations 1
time step continuity errors : sum local = 3.28066e-09, global = -3.66243e-10, cumulative = -2.98618e-09
GAMG:  Solving for p, Initial residual = 0.0517721, Final residual = 0.00505175, No Iterations 1
time step continuity errors : sum local = 2.93846e-09, global = -3.62277e-10, cumulative = -3.34846e-09
PIMPLE: iteration 6
smoothSolver:  Solving for Ux, Initial residual = 0.015568, Final residual = 0.000222185, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.00836338, Final residual = 4.93298e-05, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.0108277, Final residual = 7.2597e-05, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.0534809, Final residual = 0.00328122, No Iterations 3
time step continuity errors : sum local = 1.92493e-09, global = 6.20145e-11, cumulative = -3.28644e-09
GAMG:  Solving for p, Initial residual = 0.0597616, Final residual = 0.00585955, No Iterations 1
time step continuity errors : sum local = 3.77776e-09, global = -2.90223e-11, cumulative = -3.31547e-09
PIMPLE: iteration 7
Error must be somewhere else.
Old   October 15, 2015, 08:57
Philipp
Looks like it's the velocity solver this time, right?
I am not a solver expert, so I can't tell you why the smooth solver creates these problems. Usually, I use this setting:
solvers
        "(p|pFinal)"
        solver           GAMG;
        tolerance        1e-12;
        relTol           0.1;
        maxIter         20;
        smoother         DIC;
        nPreSweeps       1;
        nPostSweeps      1;
        nFinestSweeps    2;
        mergeLevels      1;
    "(U|k|epsilon|omega|UFinal|kFinal|epsilonFinal|omegaFinal)"
        solver           PBiCG;
        preconditioner   DILU;
        tolerance        1e-12;
        relTol           1.0e-2;
        maxIter         100;
Old   October 15, 2015, 08:59
Mike Lob
Ok, so actually my fvSolution looks like
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
      "(p|pFinal)"
        solver           GAMG;
        tolerance        1e-12;
        relTol           0.1;
        maxIter         20;
        smoother         DIC;
        nPreSweeps       1;
        nPostSweeps      1;
        nFinestSweeps    2;
        mergeLevels      1;
        solver           PBiCG;
        tolerance        1e-12;
        relTol           1.0e-2;
        maxIter         100;
PIMPLE
    correctPhi        no;
    nCorrectors         2;
    pRefCell         0;
    pRefValue        0;
residualControl
    "(p|U|k|omega)"
      tolerance 1e-2;
      relTol 0;
relaxationFactors
    fields
       p        0.3;
    equations
    U        0.7;
    k        0.7;
    omega        0.7;
Old   October 15, 2015, 09:02
Philipp
I would recommend a different residualControl setting. I usually use the relTol rather than the tolerance, because you don't have to concern yourself with the absolute values of the residuals. But maybe others think differently about that !?
Then, I would also lower the nOuterCorrectors to something like 20. If you can't get residuals down in 20 iterations, 100 won't work, too.
Old   October 15, 2015, 09:10
Mike Lob
Well, now it keeps going on.
First time step converged in 12 iterations. But numbers don't match with physics.
Second time step starts with a max Courant number of 76, further more time step continuity errors keep growing.
forces forces output:
    sum of forces:
        pressure : (3.20219e+13 6.22034e+11 -4.0116e+11)
        viscous  : (226981 3372.33 7927.69)
        porous   : (0 0 0)
    sum of moments:
        pressure : (-1.15048e+14 4.54921e+13 -3.75908e+14)
        viscous  : (-1.4342e+06 -2.72523e+06 -1.60083e+07)
        porous   : (0 0 0)
Courant Number mean: 4.59332e-07 max: 76.5398
Time = 2.18166e-05
PIMPLE: iteration 1
DILUPBiCG:  Solving for Ux, Initial residual = 0.866664, Final residual = 3.15156e-07, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.257985, Final residual = 6.31871e-06, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 0.25924, Final residual = 4.27647e-07, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.0638671, Final residual = 0.00387404, No Iterations 3
time step continuity errors : sum local = 2.82518e-09, global = 2.29057e-10, cumulative = -4.71539e-09
GAMG:  Solving for p, Initial residual = 0.0570386, Final residual = 0.00406766, No Iterations 3
time step continuity errors : sum local = 2.34492e-09, global = 2.2376e-10, cumulative = -4.49163e-09
PIMPLE: iteration 2
DILUPBiCG:  Solving for Ux, Initial residual = 0.260287, Final residual = 2.3509e-05, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.0472878, Final residual = 6.97051e-06, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 0.0472358, Final residual = 6.89489e-06, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.0639765, Final residual = 0.00506699, No Iterations 3
time step continuity errors : sum local = 2.88782e-09, global = 2.81694e-10, cumulative = -4.20994e-09
GAMG:  Solving for p, Initial residual = 0.0966392, Final residual = 0.00895581, No Iterations 2
time step continuity errors : sum local = 3.7894e-09, global = 4.5091e-10, cumulative = -3.75903e-09
PIMPLE: iteration 3
DILUPBiCG:  Solving for Ux, Initial residual = 0.0180231, Final residual = 4.31519e-05, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.00996661, Final residual = 1.28832e-05, No Iterations 3
DILUPBiCG:  Solving for Uz, Initial residual = 0.00989444, Final residual = 3.77719e-05, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.0819241, Final residual = 0.00574263, No Iterations 3
time step continuity errors : sum local = 2.42303e-09, global = 2.66958e-10, cumulative = -3.49207e-09
GAMG:  Solving for p, Initial residual = 0.132618, Final residual = 0.0101418, No Iterations 2
time step continuity errors : sum local = 3.15306e-09, global = 4.19991e-10, cumulative = -3.07208e-09
PIMPLE: iteration 4
DILUPBiCG:  Solving for Ux, Initial residual = 0.0849585, Final residual = 0.000508934, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.0167581, Final residual = 1.4555e-06, No Iterations 3
DILUPBiCG:  Solving for Uz, Initial residual = 0.0169335, Final residual = 8.71885e-05, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.115883, Final residual = 0.0115837, No Iterations 1
time step continuity errors : sum local = 3.59584e-09, global = 1.59479e-09, cumulative = -1.47728e-09
GAMG:  Solving for p, Initial residual = 0.0900661, Final residual = 0.00743689, No Iterations 3
time step continuity errors : sum local = 2.21426e-09, global = 2.69514e-10, cumulative = -1.20777e-09
PIMPLE: iteration 5
DILUPBiCG:  Solving for Ux, Initial residual = 0.078644, Final residual = 0.000613499, No Iterations 3
DILUPBiCG:  Solving for Uy, Initial residual = 0.0161631, Final residual = 0.00011581, No Iterations 3
DILUPBiCG:  Solving for Uz, Initial residual = 0.016418, Final residual = 2.26945e-05, No Iterations 3
GAMG:  Solving for p, Initial residual = 0.163533, Final residual = 0.015967, No Iterations 1
time step continuity errors : sum local = 3.72005e-09, global = 1.51401e-09, cumulative = 3.06234e-10
GAMG:  Solving for p, Initial residual = 0.0970837, Final residual = 0.00890793, No Iterations 3
time step continuity errors : sum local = 2.17655e-09, global = 3.06431e-10, cumulative = 6.12665e-10
PIMPLE: iteration 6
DILUPBiCG:  Solving for Ux, Initial residual = 0.0531039, Final residual = 2.68521e-05, No Iterations 4
DILUPBiCG:  Solving for Uy, Initial residual = 0.00897067, Final residual = 7.4357e-05, No Iterations 3
DILUPBiCG:  Solving for Uz, Initial residual = 0.0113846, Final residual = 2.54919e-05, No Iterations 3
GAMG:  Solving for p, Initial residual = 0.18581, Final residual = 0.0142419, No Iterations 1
time step continuity errors : sum local = 2.69513e-09, global = 9.0678e-10, cumulative = 1.51945e-09
GAMG:  Solving for p, Initial residual = 0.122813, Final residual = 0.0107259, No Iterations 2
time step continuity errors : sum local = 2.05469e-09, global = 5.09273e-10, cumulative = 2.02872e-09
PIMPLE: iteration 7
DILUPBiCG:  Solving for Ux, Initial residual = 0.0142203, Final residual = 1.11577e-05, No Iterations 3
DILUPBiCG:  Solving for Uy, Initial residual = 0.00513482, Final residual = 7.10856e-06, No Iterations 3
DILUPBiCG:  Solving for Uz, Initial residual = 0.00550852, Final residual = 5.4645e-05, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.155244, Final residual = 0.0127537, No Iterations 1
time step continuity errors : sum local = 2.21653e-09, global = 7.59961e-10, cumulative = 2.78868e-09
GAMG:  Solving for p, Initial residual = 0.105718, Final residual = 0.00990871, No Iterations 2
time step continuity errors : sum local = 1.74794e-09, global = 3.39822e-10, cumulative = 3.1285e-09
PIMPLE: iteration 8
DILUPBiCG:  Solving for Ux, Initial residual = 0.00490551, Final residual = 1.22639e-05, No Iterations 3
DILUPBiCG:  Solving for Uy, Initial residual = 0.00136004, Final residual = 7.06376e-07, No Iterations 3
DILUPBiCG:  Solving for Uz, Initial residual = 0.00267391, Final residual = 5.58931e-06, No Iterations 3
GAMG:  Solving for p, Initial residual = 0.142433, Final residual = 0.00811321, No Iterations 3
time step continuity errors : sum local = 1.27769e-09, global = 4.30803e-12, cumulative = 3.13281e-09
GAMG:  Solving for p, Initial residual = 0.169433, Final residual = 0.016526, No Iterations 2
time step continuity errors : sum local = 2.1341e-09, global = 2.21144e-10, cumulative = 3.35395e-09
PIMPLE: iteration 9
DILUPBiCG:  Solving for Ux, Initial residual = 0.00287841, Final residual = 1.57161e-05, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.000483634, Final residual = 4.30534e-06, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 0.00230007, Final residual = 1.06611e-06, No Iterations 3
GAMG:  Solving for p, Initial residual = 0.157906, Final residual = 0.0155495, No Iterations 3
time step continuity errors : sum local = 2.3094e-09, global = 5.37005e-10, cumulative = 3.89096e-09
GAMG:  Solving for p, Initial residual = 0.141294, Final residual = 0.0131548, No Iterations 4
time step continuity errors : sum local = 2.03133e-09, global = 4.90192e-10, cumulative = 4.38115e-09
PIMPLE: iteration 10
DILUPBiCG:  Solving for Ux, Initial residual = 0.000192267, Final residual = 2.26198e-07, No Iterations 4
DILUPBiCG:  Solving for Uy, Initial residual = 0.000125139, Final residual = 1.72955e-07, No Iterations 4
DILUPBiCG:  Solving for Uz, Initial residual = 0.000595267, Final residual = 2.00749e-06, No Iterations 3
GAMG:  Solving for p, Initial residual = 0.165359, Final residual = 0.0152966, No Iterations 4
time step continuity errors : sum local = 2.71149e-09, global = 3.18975e-11, cumulative = 4.41305e-09
GAMG:  Solving for p, Initial residual = 0.300512, Final residual = 0.0231589, No Iterations 3
time step continuity errors : sum local = 4.86893e-09, global = -7.42521e-11, cumulative = 4.3388e-09
PIMPLE: iteration 11
DILUPBiCG:  Solving for Ux, Initial residual = 0.000350208, Final residual = 1.94364e-06, No Iterations 3
DILUPBiCG:  Solving for Uy, Initial residual = 0.00032242, Final residual = 2.32274e-06, No Iterations 3
DILUPBiCG:  Solving for Uz, Initial residual = 0.00115122, Final residual = 2.25507e-06, No Iterations 4
GAMG:  Solving for p, Initial residual = 0.348331, Final residual = 0.0293308, No Iterations 4
time step continuity errors : sum local = 7.32133e-09, global = -2.00533e-10, cumulative = 4.13826e-09
GAMG:  Solving for p, Initial residual = 0.17185, Final residual = 0.0124721, No Iterations 3
time step continuity errors : sum local = 8.7529e-09, global = -1.76329e-10, cumulative = 3.96193e-09
PIMPLE: iteration 12
DILUPBiCG:  Solving for Ux, Initial residual = 0.000558672, Final residual = 4.85112e-06, No Iterations 3
DILUPBiCG:  Solving for Uy, Initial residual = 0.000562371, Final residual = 5.38573e-06, No Iterations 3
DILUPBiCG:  Solving for Uz, Initial residual = 0.00113069, Final residual = 6.76897e-06, No Iterations 4
GAMG:  Solving for p, Initial residual = 0.386677, Final residual = 0.034756, No Iterations 5
time step continuity errors : sum local = 1.65232e-08, global = 1.55496e-10, cumulative = 4.11743e-09
GAMG:  Solving for p, Initial residual = 0.0460313, Final residual = 0.00430096, No Iterations 2
time step continuity errors : sum local = 5.36873e-08, global = -5.97013e-10, cumulative = 3.52042e-09
PIMPLE: iteration 25
DILUPBiCG:  Solving for Ux, Initial residual = 0.45703, Final residual = 0.00364494, No Iterations 4
DILUPBiCG:  Solving for Uy, Initial residual = 0.466817, Final residual = 0.0032379, No Iterations 4
DILUPBiCG:  Solving for Uz, Initial residual = 0.448066, Final residual = 0.00264534, No Iterations 4
GAMG:  Solving for p, Initial residual = 4.89754e-07, Final residual = 4.45106e-08, No Iterations 17
time step continuity errors : sum local = 0.0126292, global = -0.000375018, cumulative = -0.000298839
GAMG:  Solving for p, Initial residual = 1.2146e-07, Final residual = 7.14817e-08, No Iterations 20
time step continuity errors : sum local = 0.128873, global = 0.00011411, cumulative = -0.00018473
PIMPLE: iteration 26
DILUPBiCG:  Solving for Ux, Initial residual = 0.488462, Final residual = 0.00410571, No Iterations 5
DILUPBiCG:  Solving for Uy, Initial residual = 0.489245, Final residual = 0.00398358, No Iterations 4
DILUPBiCG:  Solving for Uz, Initial residual = 0.468887, Final residual = 0.00105651, No Iterations 4
GAMG:  Solving for p, Initial residual = 1.55761e-07, Final residual = 1.28471e-08, No Iterations 6
time step continuity errors : sum local = 0.0261039, global = 0.000406571, cumulative = 0.000221841
GAMG:  Solving for p, Initial residual = 4.17219e-08, Final residual = 3.32099e-09, No Iterations 12
time step continuity errors : sum local = 0.0568839, global = -0.00190224, cumulative = -0.0016804
PIMPLE: iteration 27
DILUPBiCG:  Solving for Ux, Initial residual = 0.485182, Final residual = 0.00444568, No Iterations 5
DILUPBiCG:  Solving for Uy, Initial residual = 0.477219, Final residual = 0.00236323, No Iterations 4
DILUPBiCG:  Solving for Uz, Initial residual = 0.452158, Final residual = 0.000454943, No Iterations 5
GAMG:  Solving for p, Initial residual = 9.29377e-08, Final residual = 7.82375e-09, No Iterations 7
time step continuity errors : sum local = 0.08866, global = 0.00500549, cumulative = 0.00332509
GAMG:  Solving for p, Initial residual = 6.04943e-08, Final residual = 5.50121e-09, No Iterations 2
time step continuity errors : sum local = 0.142202, global = 0.00511167, cumulative = 0.00843676
PIMPLE: iteration 28
DILUPBiCG:  Solving for Ux, Initial residual = 0.5799, Final residual = 0.0032216, No Iterations 3
DILUPBiCG:  Solving for Uy, Initial residual = 0.56742, Final residual = 0.00354331, No Iterations 3
DILUPBiCG:  Solving for Uz, Initial residual = 0.464652, Final residual = 0.00279237, No Iterations 3
GAMG:  Solving for p, Initial residual = 1.15256e-07, Final residual = 1.73304e-08, No Iterations 20
time step continuity errors : sum local = 0.296138, global = -0.000460135, cumulative = 0.00797662
GAMG:  Solving for p, Initial residual = 1.43725e-08, Final residual = 1.9104e-08, No Iterations 20
time step continuity errors : sum local = 3.256, global = -4.9317e-05, cumulative = 0.0079273
PIMPLE: iteration 29
DILUPBiCG:  Solving for Ux, Initial residual = 0.475133, Final residual = 0.00420981, No Iterations 4
DILUPBiCG:  Solving for Uy, Initial residual = 0.514787, Final residual = 0.00477123, No Iterations 4
DILUPBiCG:  Solving for Uz, Initial residual = 0.387523, Final residual = 0.00241095, No Iterations 4
GAMG:  Solving for p, Initial residual = 7.66632e-08, Final residual = 4.95751e-09, No Iterations 5
time step continuity errors : sum local = 0.351647, global = 0.00446064, cumulative = 0.0123879
GAMG:  Solving for p, Initial residual = 1.11533e-08, Final residual = 8.46322e-10, No Iterations 4
time step continuity errors : sum local = 0.669685, global = -0.0141515, cumulative = -0.00176359
PIMPLE: iteration 30
DILUPBiCG:  Solving for Ux, Initial residual = 0.482939, Final residual = 0.00169732, No Iterations 4
DILUPBiCG:  Solving for Uy, Initial residual = 0.492853, Final residual = 0.00167008, No Iterations 4
DILUPBiCG:  Solving for Uz, Initial residual = 0.423742, Final residual = 0.0033366, No Iterations 3
GAMG:  Solving for p, Initial residual = 7.33705e-08, Final residual = 7.02836e-09, No Iterations 4
time step continuity errors : sum local = 1.208, global = 0.0817156, cumulative = 0.079952
GAMG:  Solving for p, Initial residual = 9.10694e-09, Final residual = 7.2643e-10, No Iterations 8
time step continuity errors : sum local = 1.11649, global = 0.0696683, cumulative = 0.14962
PIMPLE: iteration 31
DILUPBiCG:  Solving for Ux, Initial residual = 0.434401, Final residual = 0.00276104, No Iterations 4
DILUPBiCG:  Solving for Uy, Initial residual = 0.438609, Final residual = 0.0035577, No Iterations 4
DILUPBiCG:  Solving for Uz, Initial residual = 0.428942, Final residual = 0.00169325, No Iterations 5
GAMG:  Solving for p, Initial residual = 6.13821e-06, Final residual = 8.82587e-07, No Iterations 20
time step continuity errors : sum local = 3.98246, global = 0.277155, cumulative = 0.426775
GAMG:  Solving for p, Initial residual = 2.69328e-08, Final residual = 2.1687e-09, No Iterations 1
time step continuity errors : sum local = 4.15637, global = 0.0797123, cumulative = 0.506488
PIMPLE: iteration 32
DILUPBiCG:  Solving for Ux, Initial residual = 0.728414, Final residual = 0.00296967, No Iterations 3
DILUPBiCG:  Solving for Uy, Initial residual = 0.541076, Final residual = 0.00394594, No Iterations 3
DILUPBiCG:  Solving for Uz, Initial residual = 0.79722, Final residual = 0.00145519, No Iterations 3
GAMG:  Solving for p, Initial residual = 7.0245e-08, Final residual = 6.54451e-09, No Iterations 9
time step continuity errors : sum local = 5.78199, global = 0.245586, cumulative = 0.752073
GAMG:  Solving for p, Initial residual = 5.14576e-09, Final residual = 3.40823e-10, No Iterations 8
time step continuity errors : sum local = 8.29289, global = -0.468393, cumulative = 0.283681
PIMPLE: iteration 33
DILUPBiCG:  Solving for Ux, Initial residual = 0.431882, Final residual = 0.000428693, No Iterations 6
DILUPBiCG:  Solving for Uy, Initial residual = 0.451638, Final residual = 0.00125437, No Iterations 5
DILUPBiCG:  Solving for Uz, Initial residual = 0.500052, Final residual = 0.00311681, No Iterations 4
GAMG:  Solving for p, Initial residual = 9.34601e-08, Final residual = 1.17991e-08, No Iterations 20
time step continuity errors : sum local = 23.4012, global = -15.7156, cumulative = -15.4319
GAMG:  Solving for p, Initial residual = 4.27502e-08, Final residual = 1.25665e-08, No Iterations 20
time step continuity errors : sum local = 85.7935, global = -34.1987, cumulative = -49.6306
PIMPLE: iteration 34
DILUPBiCG:  Solving for Ux, Initial residual = 0.40978, Final residual = 0.00235957, No Iterations 4
DILUPBiCG:  Solving for Uy, Initial residual = 0.451869, Final residual = 0.001927, No Iterations 4
DILUPBiCG:  Solving for Uz, Initial residual = 0.419105, Final residual = 0.00210072, No Iterations 5
GAMG:  Solving for p, Initial residual = 1.92655e-06, Final residual = 8.91561e-07, No Iterations 20
time step continuity errors : sum local = 208.798, global = -51.2509, cumulative = -100.881
GAMG:  Solving for p, Initial residual = 7.43198e-07, Final residual = 2.23723e-06, No Iterations 20
time step continuity errors : sum local = 1943.26, global = 18.5426, cumulative = -82.3388
PIMPLE: iteration 35
DILUPBiCG:  Solving for Ux, Initial residual = 0.330767, Final residual = 0.0021958, No Iterations 3
DILUPBiCG:  Solving for Uy, Initial residual = 0.343671, Final residual = 0.00117926, No Iterations 4
DILUPBiCG:  Solving for Uz, Initial residual = 0.322184, Final residual = 0.00102286, No Iterations 4
GAMG:  Solving for p, Initial residual = 2.22497e-07, Final residual = 2.12035e-08, No Iterations 6
time step continuity errors : sum local = 118.654, global = -61.5736, cumulative = -143.912
GAMG:  Solving for p, Initial residual = 7.57818e-08, Final residual = 6.6613e-09, No Iterations 10
time step continuity errors : sum local = 186.871, global = 43.3242, cumulative = -100.588
PIMPLE: iteration 36
DILUPBiCG:  Solving for Ux, Initial residual = 0.557896, Final residual = 0.00349763, No Iterations 4
DILUPBiCG:  Solving for Uy, Initial residual = 0.566518, Final residual = 0.000803787, No Iterations 5
DILUPBiCG:  Solving for Uz, Initial residual = 0.484968, Final residual = 0.00214561, No Iterations 4
GAMG:  Solving for p, Initial residual = 3.62432e-07, Final residual = 3.45964e-08, No Iterations 13
time step continuity errors : sum local = 388.037, global = -4.52998, cumulative = -105.118
GAMG:  Solving for p, Initial residual = 5.9511e-08, Final residual = 1.23765e-08, No Iterations 20
time step continuity errors : sum local = 1321.47, global = -0.315589, cumulative = -105.434
PIMPLE: iteration 37
DILUPBiCG:  Solving for Ux, Initial residual = 0.486504, Final residual = 0.00191651, No Iterations 4
DILUPBiCG:  Solving for Uy, Initial residual = 0.48672, Final residual = 0.00204066, No Iterations 4
DILUPBiCG:  Solving for Uz, Initial residual = 0.427991, Final residual = 0.000811272, No Iterations 5
GAMG:  Solving for p, Initial residual = 4.65018e-08, Final residual = 4.45178e-09, No Iterations 20
time step continuity errors : sum local = 731.468, global = 198.436, cumulative = 93.0026
GAMG:  Solving for p, Initial residual = 9.32307e-09, Final residual = 4.49918e-09, No Iterations 20
time step continuity errors : sum local = 4870.59, global = -1325.02, cumulative = -1232.01
PIMPLE: iteration 38
DILUPBiCG:  Solving for Ux, Initial residual = 0.479185, Final residual = 0.00165469, No Iterations 5
DILUPBiCG:  Solving for Uy, Initial residual = 0.476365, Final residual = 0.000516798, No Iterations 5
DILUPBiCG:  Solving for Uz, Initial residual = 0.489416, Final residual = 0.00472329, No Iterations 3
GAMG:  Solving for p, Initial residual = 1.9266e-06, Final residual = 5.08132e-07, No Iterations 20
time step continuity errors : sum local = 7383.56, global = 3325.75, cumulative = 2093.74
GAMG:  Solving for p, Initial residual = 4.86745e-07, Final residual = 4.49227e-07, No Iterations 20
time step continuity errors : sum local = 57164.3, global = -1297.7, cumulative = 796.039
PIMPLE: iteration 39
DILUPBiCG:  Solving for Ux, Initial residual = 0.469658, Final residual = 0.00286888, No Iterations 4
DILUPBiCG:  Solving for Uy, Initial residual = 0.486166, Final residual = 0.000287571, No Iterations 6
DILUPBiCG:  Solving for Uz, Initial residual = 0.420831, Final residual = 0.00308034, No Iterations 3
Old   October 15, 2015, 09:11
Mike Lob
Trying different settings like you suggested. I'll write on it.
Old   October 15, 2015, 09:14
Philipp
Don't cut the log file, I miss the most intersting parts
What about the k and omaga solvers?
Old   October 15, 2015, 09:21
Mike Lob
this one, as you suggested, right?
        solver           PBiCG;
        tolerance        1e-12;
        relTol           1.0e-2;
        maxIter         100;
Old   October 15, 2015, 09:23
Philipp
No, I mean the log file is missing the information about the turbulence.
Old   October 15, 2015, 09:27
Mike Lob
As far as I remember, all the log files I've seen did not write nothing about k-omega. Did I forgot to write something?
Anyway, I tried with the following fvSolution
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
      "(p|pFinal)"
        solver           GAMG;
        tolerance        0;
        relTol           1e-5;
        maxIter         20;
        smoother         DIC;
        nPreSweeps       1;
        nPostSweeps      1;
        nFinestSweeps    2;
        mergeLevels      1;
        solver           PBiCG;
        tolerance        0;
        relTol           1.0e-5;
        maxIter         100;
PIMPLE
    correctPhi        no;
    nOuterCorrectors    20;
    nCorrectors         2;
    pRefCell         0;
    pRefValue        0;
residualControl
    "(p|U|k|omega)"
      tolerance 0;
      relTol 1e-5;
relaxationFactors
    fields
       p        0.3;
    equations
    U        0.7;
    k        0.7;
    omega        0.7;
log file
Create time
Reading field p
Reading field U
kOmegaSSTCoeffs
    alphaK1         0.85;
    alphaK2         1;
    alphaOmega1     0.5;
    alphaOmega2     0.856;
    gamma1          0.555556;
    gamma2          0.44;
    beta1           0.075;
    beta2           0.0828;
    betaStar        0.09;
    a1              0.31;
    b1              1;
    c1              10;
    F3              false;
PIMPLE: max iterations = 20
    field "(p|U|k|omega)"    : relTol 1e-05, tolerance 0
Starting time loop
forces forces:
Time = 1.09083e-05
PIMPLE: iteration 1
DILUPBiCG:  Solving for Ux, Initial residual = 1, Final residual = 5.38097e-17, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 1, Final residual = 2.19952e-16, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 1, Final residual = 8.98804e-17, No Iterations 1
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.000850538, No Iterations 20
time step continuity errors : sum local = 4.63897e-12, global = -2.99077e-14, cumulative = -2.99077e-14
GAMG:  Solving for p, Initial residual = 0.182951, Final residual = 1.48404e-05, No Iterations 20
time step continuity errors : sum local = 3.92995e-12, global = -4.25516e-14, cumulative = -7.24593e-14
PIMPLE: iteration 2
DILUPBiCG:  Solving for Ux, Initial residual = 0.575869, Final residual = 5.20509e-09, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.130436, Final residual = 5.97277e-10, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 0.130436, Final residual = 6.17317e-10, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.14681, Final residual = 1.26348e-05, No Iterations 20
time step continuity errors : sum local = 3.58e-12, global = -4.61894e-14, cumulative = -1.18649e-13
GAMG:  Solving for p, Initial residual = 0.123814, Final residual = 6.48693e-06, No Iterations 20
time step continuity errors : sum local = 2.91471e-12, global = -4.44487e-14, cumulative = -1.63097e-13
PIMPLE: iteration 3
DILUPBiCG:  Solving for Ux, Initial residual = 0.328115, Final residual = 2.9441e-09, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.0652315, Final residual = 2.92304e-10, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 0.0652764, Final residual = 3.10868e-10, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.113768, Final residual = 5.22568e-06, No Iterations 20
time step continuity errors : sum local = 2.41215e-12, global = -3.75052e-14, cumulative = -2.00603e-13
GAMG:  Solving for p, Initial residual = 0.091437, Final residual = 3.3779e-06, No Iterations 20
time step continuity errors : sum local = 1.89695e-12, global = -3.15321e-14, cumulative = -2.32135e-13
PIMPLE: iteration 4
DILUPBiCG:  Solving for Ux, Initial residual = 0.17629, Final residual = 1.56232e-09, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.0338782, Final residual = 1.51358e-10, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 0.0339012, Final residual = 1.6177e-10, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.0863256, Final residual = 2.64111e-06, No Iterations 20
time step continuity errors : sum local = 1.50007e-12, global = -2.45599e-14, cumulative = -2.56695e-13
GAMG:  Solving for p, Initial residual = 0.0670754, Final residual = 1.84298e-06, No Iterations 20
time step continuity errors : sum local = 1.15507e-12, global = -1.90806e-14, cumulative = -2.75775e-13
PIMPLE: iteration 5
DILUPBiCG:  Solving for Ux, Initial residual = 0.0931013, Final residual = 8.08966e-10, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.0182765, Final residual = 7.92359e-11, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 0.0182847, Final residual = 8.65505e-11, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.0635045, Final residual = 1.43359e-06, No Iterations 20
time step continuity errors : sum local = 9.02351e-13, global = -1.44497e-14, cumulative = -2.90225e-13
GAMG:  Solving for p, Initial residual = 0.048217, Final residual = 1.04543e-06, No Iterations 20
time step continuity errors : sum local = 6.94057e-13, global = -1.09189e-14, cumulative = -3.01144e-13
PIMPLE: iteration 6
DILUPBiCG:  Solving for Ux, Initial residual = 0.048723, Final residual = 4.10896e-10, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.0105615, Final residual = 4.24163e-11, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 0.0105538, Final residual = 4.84504e-11, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.0454965, Final residual = 8.2809e-07, No Iterations 20
time step continuity errors : sum local = 5.50428e-13, global = -8.40717e-15, cumulative = -3.09551e-13
GAMG:  Solving for p, Initial residual = 0.0339978, Final residual = 6.22983e-07, No Iterations 20
time step continuity errors : sum local = 4.26835e-13, global = -6.33486e-15, cumulative = -3.15886e-13
PIMPLE: iteration 7
DILUPBiCG:  Solving for Ux, Initial residual = 0.025365, Final residual = 2.14062e-10, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.00664658, Final residual = 2.96478e-11, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 0.00662996, Final residual = 2.91403e-11, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.0319445, Final residual = 5.04916e-07, No Iterations 20
time step continuity errors : sum local = 3.45932e-13, global = -4.91469e-15, cumulative = -3.208e-13
GAMG:  Solving for p, Initial residual = 0.0236159, Final residual = 3.87828e-07, No Iterations 20
time step continuity errors : sum local = 2.70513e-13, global = -3.69509e-15, cumulative = -3.24496e-13
PIMPLE: iteration 8
DILUPBiCG:  Solving for Ux, Initial residual = 0.0132529, Final residual = 3.12824e-10, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.00443574, Final residual = 1.94406e-11, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 0.00442741, Final residual = 2.19916e-11, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.0221197, Final residual = 3.17427e-07, No Iterations 20
time step continuity errors : sum local = 2.21317e-13, global = -2.41478e-15, cumulative = -3.2691e-13
GAMG:  Solving for p, Initial residual = 0.016238, Final residual = 2.47359e-07, No Iterations 20
time step continuity errors : sum local = 1.74362e-13, global = -1.75134e-15, cumulative = -3.28662e-13
PIMPLE: iteration 9
DILUPBiCG:  Solving for Ux, Initial residual = 0.00708739, Final residual = 1.48741e-10, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.00301968, Final residual = 8.01464e-09, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 0.0030182, Final residual = 1.53244e-10, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.0151832, Final residual = 2.32595e-07, No Iterations 20
time step continuity errors : sum local = 1.6388e-13, global = -6.4121e-16, cumulative = -3.29303e-13
GAMG:  Solving for p, Initial residual = 0.0110994, Final residual = 1.86506e-07, No Iterations 20
time step continuity errors : sum local = 1.32314e-13, global = -3.65334e-16, cumulative = -3.29668e-13
DILUPBiCG:  Solving for Ux, Initial residual = 0.00396473, Final residual = 9.72602e-12, No Iterations 3
DILUPBiCG:  Solving for Uy, Initial residual = 0.00205423, Final residual = 3.17736e-11, No Iterations 3
DILUPBiCG:  Solving for Uz, Initial residual = 0.00205473, Final residual = 2.35815e-09, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.0103786, Final residual = 2.70309e-07, No Iterations 20
time step continuity errors : sum local = 1.91695e-13, global = 6.29131e-17, cumulative = -3.29605e-13
GAMG:  Solving for p, Initial residual = 0.00757311, Final residual = 2.43872e-07, No Iterations 20
time step continuity errors : sum local = 1.73711e-13, global = 1.07779e-16, cumulative = -3.29498e-13
DILUPBiCG:  Solving for Ux, Initial residual = 0.00234174, Final residual = 2.28446e-09, No Iterations 3
DILUPBiCG:  Solving for Uy, Initial residual = 0.00138961, Final residual = 1.31493e-09, No Iterations 4
DILUPBiCG:  Solving for Uz, Initial residual = 0.00139063, Final residual = 2.06147e-09, No Iterations 3
GAMG:  Solving for p, Initial residual = 0.00709553, Final residual = 5.57821e-07, No Iterations 20
time step continuity errors : sum local = 3.97233e-13, global = 2.16375e-16, cumulative = -3.29281e-13
GAMG:  Solving for p, Initial residual = 0.00518617, Final residual = 5.17207e-07, No Iterations 20
time step continuity errors : sum local = 3.69376e-13, global = 1.81566e-16, cumulative = -3.291e-13
DILUPBiCG:  Solving for Ux, Initial residual = 0.001446, Final residual = 1.07055e-08, No Iterations 5
DILUPBiCG:  Solving for Uy, Initial residual = 0.000934765, Final residual = 2.94952e-09, No Iterations 6
DILUPBiCG:  Solving for Uz, Initial residual = 0.000936384, Final residual = 1.07785e-09, No Iterations 6
GAMG:  Solving for p, Initial residual = 0.00488315, Final residual = 1.22038e-06, No Iterations 20
time step continuity errors : sum local = 8.71415e-13, global = 3.63095e-17, cumulative = -3.29063e-13
GAMG:  Solving for p, Initial residual = 0.00361049, Final residual = 1.10981e-06, No Iterations 20
time step continuity errors : sum local = 7.93999e-13, global = 2.2947e-17, cumulative = -3.2904e-13
PIMPLE: iteration 13
DILUPBiCG:  Solving for Ux, Initial residual = 0.000913855, Final residual = 8.92874e-10, No Iterations 7
DILUPBiCG:  Solving for Uy, Initial residual = 0.000624009, Final residual = 6.93498e-10, No Iterations 6
DILUPBiCG:  Solving for Uz, Initial residual = 0.000628673, Final residual = 2.40093e-09, No Iterations 7
GAMG:  Solving for p, Initial residual = 0.00344592, Final residual = 2.92139e-06, No Iterations 20
time step continuity errors : sum local = 2.08991e-12, global = 1.37988e-17, cumulative = -3.29027e-13
GAMG:  Solving for p, Initial residual = 0.00265492, Final residual = 2.466e-06, No Iterations 20
time step continuity errors : sum local = 1.76652e-12, global = -4.18087e-18, cumulative = -3.29031e-13
PIMPLE: iteration 14
DILUPBiCG:  Solving for Ux, Initial residual = 0.000574472, Final residual = 2.83792e-09, No Iterations 7
DILUPBiCG:  Solving for Uy, Initial residual = 0.000391953, Final residual = 8.47879e-10, No Iterations 6
DILUPBiCG:  Solving for Uz, Initial residual = 0.000421002, Final residual = 1.50038e-09, No Iterations 8
GAMG:  Solving for p, Initial residual = 0.00263674, Final residual = 5.59006e-06, No Iterations 20
time step continuity errors : sum local = 4.00474e-12, global = 2.33869e-17, cumulative = -3.29007e-13
GAMG:  Solving for p, Initial residual = 0.00233292, Final residual = 3.80849e-06, No Iterations 20
time step continuity errors : sum local = 2.73149e-12, global = -1.58426e-17, cumulative = -3.29023e-13
PIMPLE: iteration 15
DILUPBiCG:  Solving for Ux, Initial residual = 0.000263722, Final residual = 4.01094e-10, No Iterations 8
DILUPBiCG:  Solving for Uy, Initial residual = 0.000157811, Final residual = 1.16427e-09, No Iterations 5
DILUPBiCG:  Solving for Uz, Initial residual = 0.000278886, Final residual = 2.53124e-09, No Iterations 5
GAMG:  Solving for p, Initial residual = 0.00328214, Final residual = 1.48079e-05, No Iterations 20
time step continuity errors : sum local = 1.06313e-11, global = 1.10572e-16, cumulative = -3.28913e-13
GAMG:  Solving for p, Initial residual = 0.00393972, Final residual = 1.76433e-05, No Iterations 20
time step continuity errors : sum local = 1.26889e-11, global = -9.98943e-17, cumulative = -3.29012e-13
PIMPLE: iteration 16
DILUPBiCG:  Solving for Ux, Initial residual = 3.70449e-05, Final residual = 3.67244e-10, No Iterations 8
DILUPBiCG:  Solving for Uy, Initial residual = 2.11178e-05, Final residual = 1.22973e-10, No Iterations 9
DILUPBiCG:  Solving for Uz, Initial residual = 0.0001729, Final residual = 8.05336e-10, No Iterations 8
GAMG:  Solving for p, Initial residual = 0.00536874, Final residual = 9.37444e-05, No Iterations 20
time step continuity errors : sum local = 6.75098e-11, global = -7.25852e-16, cumulative = -3.29738e-13
GAMG:  Solving for p, Initial residual = 0.0132991, Final residual = 0.000106057, No Iterations 20
time step continuity errors : sum local = 7.74716e-11, global = 9.05626e-16, cumulative = -3.28833e-13
PIMPLE: iteration 17
DILUPBiCG:  Solving for Ux, Initial residual = 0.000318289, Final residual = 3.27937e-10, No Iterations 12
DILUPBiCG:  Solving for Uy, Initial residual = 0.000168046, Final residual = 1.47304e-09, No Iterations 8
DILUPBiCG:  Solving for Uz, Initial residual = 2.59715e-05, Final residual = 8.5052e-11, No Iterations 10
GAMG:  Solving for p, Initial residual = 0.0187933, Final residual = 0.00361403, No Iterations 20
time step continuity errors : sum local = 2.62536e-09, global = -2.1167e-13, cumulative = -5.40503e-13
GAMG:  Solving for p, Initial residual = 0.0783631, Final residual = 0.00585178, No Iterations 20
time step continuity errors : sum local = 5.31193e-09, global = -4.36381e-13, cumulative = -9.76884e-13
PIMPLE: iteration 18
DILUPBiCG:  Solving for Ux, Initial residual = 0.000485379, Final residual = 1.97349e-09, No Iterations 10
DILUPBiCG:  Solving for Uy, Initial residual = 0.000632127, Final residual = 2.95446e-09, No Iterations 10
DILUPBiCG:  Solving for Uz, Initial residual = 0.000310312, Final residual = 1.76645e-09, No Iterations 9
GAMG:  Solving for p, Initial residual = 0.0984537, Final residual = 0.00645455, No Iterations 20
time step continuity errors : sum local = 4.64713e-09, global = 3.52369e-14, cumulative = -9.41647e-13
GAMG:  Solving for p, Initial residual = 0.0469483, Final residual = 0.00256194, No Iterations 20
time step continuity errors : sum local = 6.73626e-09, global = -8.1758e-14, cumulative = -1.02341e-12
PIMPLE: iteration 19
DILUPBiCG:  Solving for Ux, Initial residual = 0.000620827, Final residual = 1.78317e-09, No Iterations 11
DILUPBiCG:  Solving for Uy, Initial residual = 0.000546878, Final residual = 1.73103e-09, No Iterations 10
DILUPBiCG:  Solving for Uz, Initial residual = 0.000262496, Final residual = 6.11569e-10, No Iterations 11
GAMG:  Solving for p, Initial residual = 0.158795, Final residual = 0.0197291, No Iterations 20
time step continuity errors : sum local = 3.89702e-08, global = -5.62443e-13, cumulative = -1.58585e-12
GAMG:  Solving for p, Initial residual = 0.0769585, Final residual = 0.00629057, No Iterations 20
time step continuity errors : sum local = 4.59415e-08, global = -5.9324e-13, cumulative = -2.17909e-12
PIMPLE: iteration 20
DILUPBiCG:  Solving for Ux, Initial residual = 0.0033839, Final residual = 2.3056e-08, No Iterations 65
DILUPBiCG:  Solving for Uy, Initial residual = 0.00399156, Final residual = 2.71118e-08, No Iterations 56
DILUPBiCG:  Solving for Uz, Initial residual = 0.00267406, Final residual = 1.59844e-08, No Iterations 65
GAMG:  Solving for p, Initial residual = 0.191895, Final residual = 0.00318539, No Iterations 20
time step continuity errors : sum local = 3.28746e-08, global = -6.25726e-12, cumulative = -8.43635e-12
GAMG:  Solving for p, Initial residual = 0.0450605, Final residual = 0.00172445, No Iterations 20
time step continuity errors : sum local = 3.66081e-07, global = -5.65159e-11, cumulative = -6.49523e-11
DILUPBiCG:  Solving for omega, Initial residual = 0.0624003, Final residual = 4.45631e-07, No Iterations 49
DILUPBiCG:  Solving for k, Initial residual = 1, Final residual = 8.95703e-06, No Iterations 34
PIMPLE: not converged within 20 iterations
ExecutionTime = 374.04 s  ClockTime = 374 s
    sum of forces:
        pressure : (-2.28408e+17 5.32264e+17 6.93677e+17)
        viscous  : (-2.95957e+09 9.28817e+07 -1.33636e+10)
        porous   : (0 0 0)
    sum of moments:
        pressure : (4.85726e+20 2.13491e+20 1.42405e+19)
        viscous  : (2.56719e+11 2.87508e+11 1.30512e+11)
        porous   : (0 0 0)
Courant Number mean: 5.74294e-06 max: 1.27126e+06
Time = 2.18166e-05
PIMPLE: iteration 1
DILUPBiCG:  Solving for Ux, Initial residual = 0.0575416, Final residual = 2.68272e-07, No Iterations 10
DILUPBiCG:  Solving for Uy, Initial residual = 0.0395307, Final residual = 2.18704e-07, No Iterations 10
DILUPBiCG:  Solving for Uz, Initial residual = 0.0887286, Final residual = 6.59463e-07, No Iterations 11
GAMG:  Solving for p, Initial residual = 0.0210242, Final residual = 0.000440192, No Iterations 20
time step continuity errors : sum local = 6.20467e-07, global = -1.58818e-09, cumulative = -1.65313e-09
GAMG:  Solving for p, Initial residual = 0.00116681, Final residual = 1.03143e-05, No Iterations 20
time step continuity errors : sum local = 4.39509e-07, global = -2.29711e-10, cumulative = -1.88284e-09
PIMPLE: iteration 2
DILUPBiCG:  Solving for Ux, Initial residual = 0.104692, Final residual = 7.13485e-07, No Iterations 10
DILUPBiCG:  Solving for Uy, Initial residual = 0.293159, Final residual = 1.94508e-06, No Iterations 9
DILUPBiCG:  Solving for Uz, Initial residual = 0.0575179, Final residual = 1.97897e-07, No Iterations 10
GAMG:  Solving for p, Initial residual = 0.000959239, Final residual = 0.000823077, No Iterations 20
time step continuity errors : sum local = 3.69348e-05, global = -2.23494e-08, cumulative = -2.42322e-08
Old   October 15, 2015, 09:43
Philipp
Firstly, this is not the reason for your problems but: In my view the relTol of 1e-5 is insane. You see it in the later iterations that the linear solvers take 10 or even 65 iterations to converge. Also pressure takes all 20 iterations. In some ordinary simulations all solvers should take something like less than 5 iterations, often just 1 or two. And the outer algorithm still remains stable. There is no increase in overall accuracy by setting relTol to such a low value.
Now, to the actual problem. PIMPLE doesn't converge. You can see the residuals increasing after some initial decrease. You can try to use more stable numerics in the fvSchemes file. Use (1st order) upwind also for the velocity and uncorrected scheme for laplacian instead of corrected. Did you try to initialize the flow field with potentialFoam?
debug information, floating point exception
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 04:53
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 14:06
Floating point error and divergence detected aannjj FLUENT 0 July 2, 2013 03:44
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 02:27
