October 16, 2015, 12:16 |
Reynolds stress pimpleFoam
Marta
Rep Power: 10 |
Hi everyone,
I'm running the case of turbulent flow around a square cylinder , with LES model. The solver is pimpleFoam. Does anyone know how I can extract instantaneous Reynolds stress ? Thanks a lot Marta |
October 16, 2015, 12:35 |
Mike Lob
Rep Power: 10 |
October 17, 2015, 04:49 |
Rep Power: 16 |
I tried the R utility for pimpleFoam and it didn't work with the error that it is only valid turbulence models RASModel or laminar.
Are you running LES? You can get the resolved Reynolds stresses by using the functions probes or fieldsAverage + UPrime2Mean in the controlDict file. |
October 17, 2015, 05:44 |
Marta
Rep Power: 10 |
Thanks Bazinga,
I also tried the R utility with the same result. And I just checking what came out using UPrime2Mean in the controlDict, setting outputControl: timeStep. I would need instantaneous Re stress without no averaging.. Marta |
October 17, 2015, 05:47 |
Marta
Rep Power: 10 |
Thanks Ipz_michele,
the better way for a while seems to run it again using the functions in the controlDirect. Marta |
October 17, 2015, 05:50 |
Rep Power: 16 |
The only option i am aware of to get the instantaneous values of the Reynolds stresses is to use probes for the velocity. You need to define them before you start the simulation for each point where you wanna obtain the stresses. From the time history of the velocity you can get the stresses.
October 17, 2015, 06:07 |
Marta
Rep Power: 10 |
Thanks for your help.
Actually I'm trying to find out a way to have the stresses for each point of the grid. (I need them as source for the acoustic field) |
October 17, 2015, 06:09 |
Rep Power: 16 |
Keep us updated if you find a good solution
October 21, 2015, 04:17 |
#9 |
Marta
Rep Power: 10 |
so far to get the instantaneous Re stress I tried to add two functions in the controlDict: turbulenceFields (that should store R on the mesh) and writeRegisteredObject. I need to verify what came out. I obtained a symmetric tensor for each time, on each point of the grid. I also should say that I'm very new on openFoam, so I easily go wrong. |
"Error in subroutine GETCORE": simulation of an turbine and reynolds stress models | nikn | CFX | 8 | October 30, 2019 15:32 |
[ANSYS Meshing] Error in Workbench "Unable to attach to geometry file" | Jeremie84 | ANSYS Meshing & Geometry | 70 | October 25, 2017 16:03 |
New implemented algebraic Reynolds stress model | volker | OpenFOAM | 13 | October 21, 2013 00:01 |
Reynolds Stress Models | Jade M | Main CFD Forum | 0 | April 21, 2010 16:38 |
Reynolds Stress Boundary Conditions | tstorm | FLUENT | 0 | July 27, 2009 14:44 |
