October 24, 2015, 10:20 |
bounding max k, epsilon and omega values
Matej Muller
Rep Power: 14 |
Hi!
Is there a way to bound the maximal k, epsilon and omega values in openfoam without recompiling a new solver (due to my lack in programming knowledge)? I would think openfoam has this already built-in as it is a common thing to do (perhaps one can define it in a dictionary like RASProperties or fvSchemes?). Thanks, Matej |
October 24, 2015, 12:22 |
Take a look at User Guide - 4.4.1.1 Schemes for strictly bounded scalar fields, http://cfd.direct/openfoam/user-guid...20-1080004.4.1. Unfortunately in RASProperties you can set only lower limit for k, epsilon, and omega. Also you can try (though you have mentioned lack of programming skills) to use temperatureLimitConstraint fvOption as a base for turbulentFieldsLimitConstraint fvOption. |
Bounding epsilon or bounding omega | Stylianos | OpenFOAM | 8 | February 23, 2018 13:41 |
epsilon and omega free stream BC's | immortality | OpenFOAM Running, Solving & CFD | 13 | September 10, 2013 03:38 |
problem from k epsilon to k omega | NJG | OpenFOAM Running, Solving & CFD | 0 | April 15, 2013 08:24 |
[snappyHexMesh] complex camber and bounding epsilon | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | September 25, 2012 05:31 |
why omega instead of epsilon in turbulence modeling | pgoyal10 | Main CFD Forum | 1 | May 5, 2012 11:02 |
