Dummy turbulence model for OpenFoam 3 Simple FOAM
Like Tree1Likes
  • 1 Post By vabishek
Old   January 7, 2016, 11:27
Default Dummy turbulence model for OpenFoam 3 Simple FOAM
nusivares is on a distinguished road
So, I have upgraded my OpenFOAM to 3.0.0 and I cannot find any way how to set the dummy turbulent model whilst using the simple loop (using one of the heat transfer apps). Any ideas how to do it? Current turbulenceProperties file is as:
| \\ / O peration | Version: 2.4.0 |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object RASProperties;
simulationType laminar;
RAS
// Tested with kEpsilon, realizableKE, kOmega, kOmegaSST, v2f,
// ShihQuadraticKE, LienCubicKE.
RASModel laminar;
turbulence on;
printCoeffs on;
All I am getting is a big fat error.
nusivares is offline   Reply With Quote
Old   January 28, 2016, 12:39
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
This is what I'm searching, too.
Why there is no laminar dummy model!?
It doesn't even react to elimination of the "simulationType" keyword.
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
Old   January 29, 2016, 09:02
VA
vabishek is on a distinguished road
I believe it was a bug in the code that was causing this issue. I had reported it, and it was fixed in OpenFOAM-3.0.x. You may have to download 3.0.x version or fix the bug in the current 3.0.0 version. It is a simple fix anyway.
http://www.openfoam.org/mantisbt/view.php?id=1951
lav likes this.
vabishek is offline   Reply With Quote
Old   March 10, 2016, 22:28
lav
Lavanya
lav is on a distinguished road
In the new version openfoam3.0.1, I tried,
simulationType RAS;
RAS
RASModel laminar;
turbulence on;
printCoeffs on;
but its not working. Instead, " simulationType laminar; " is working !!!!
Thank you
lav is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
SIMPLE algorithm and k-eps turbulence model zqnwpu Main CFD Forum 11 May 28, 2012 04:08
question about turbulence model selection and sensitivity karananand Main CFD Forum 1 February 26, 2010 04:41
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
