reading transportProperties of multiphaseInterFoam Error
Like Tree1Likes
  • 1 Post By AbbasRahimi
Old   February 3, 2016, 16:08
Default reading transportProperties of multiphaseInterFoam Error
Abbas Rahimi
AbbasRahimi is on a distinguished road
Hello everyone,
I'm trying to run multiphaseInterFoam for a case and I get this error. I wonder if anyone here can help me to overcome this error?
Thank you.
Create mesh for time = 0
Reading field p_rgh
Reading field U
Selecting incompressible transport model Newtonian
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 in "/lib64/libc.so.6"
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
#5 Foam::multiphaseMixture::multiphaseMixture(Foam::G eometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:?
at ??:?
#7 __libc_start_main in "/lib64/libc.so.6"
at /usr/src/packages/BUILD/glibc-2.11.3/csu/../sysdeps/x86_64/elf/start.S:116
Floating exception
shincoast likes this.
AbbasRahimi is offline   Reply With Quote
Old   February 4, 2016, 04:27
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Answering your question: use correct initial conditions (or properties, maybe you have made a mistake there).
More detailed answer would be:
If you look at the error, you can find key word "divide":
In general this error happens when you try to divide something by 0. Error happened during construction of the mixture, so you go to $FOAM_APP/solvers/multiphase/multiphaseInterFoam/multiphaseMixture/multiphaseMixture.C and look into constructor of the class, the first division is here:
    const volVectorField& U,
    const surfaceScalarField& phi
    nu_
        IOobject
            "nu",
            mesh_.time().timeName(),
            mesh_
        mu()/rho()
and it means somewhere density is zero, so if you take a look at rho method:
Foam::tmp<Foam::volScalarField>
Foam::multiphaseMixture::rho() const
    PtrDictionary<phase>::const_iterator iter = phases_.begin();
    tmp<volScalarField> trho = iter()*iter().rho();
    for (++iter; iter != phases_.end(); ++iter)
        trho() += iter()*iter().rho();
    return trho;
iter() is alpha.phase_name volume field, tier().rho() is density of the phase, you have put into transportProperties. Which one is zero? I can only guess, yet you can try to find it in your case files.
alexeym is offline   Reply With Quote
Old   February 4, 2016, 04:41
Abbas Rahimi
Alexey,
Thank you for response. Your answer totally make sense but I double checked my transportProperties and couldn't find any rho=0 anywhere.
| \\ / O peration | Version: 2.3.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object transportProperties;
phases
air
transportModel Newtonian;
nu nu [ 0 2 -1 0 0 0 0 ] 29.522;
rho rho [ 1 -3 0 0 0 0 0 ] 1129;
BirdCarreauCoeffs
nu0 nu0 [ 0 2 -1 0 0 0 0 ] 378.7336;
nuInf nuInf [ 0 2 -1 0 0 0 0 ] 8.9686e-07;
k k [ 0 0 1 0 0 0 0 ] 10;
n n [ 0 0 0 0 0 0 0 ] 0.2407;
base
nu nu [ 0 2 -1 0 0 0 0 ] 295.22;
BirdCarreauCoeffs
nu0 nu0 [ 0 2 -1 0 0 0 0 ] 262.65;
nuInf nuInf [ 0 2 -1 0 0 0 0 ] 0.000886;
n n [ 0 0 0 0 0 0 0 ] 0.3005;
tcap
BirdCarreauCoeffs
bcap
BirdCarreauCoeffs
skirt
BirdCarreauCoeffs
refPhase tcap;
sigmas
(air tcap) 0.0
(air bcap) 0.0
(air skirt) 0.0
(air base) 0.0
(tcap bcap) 0.0
(tcap skirt) 0.0
(tcap base) 0.0
(bcap base) 0.0
(bcap skirt) 0.0
(base skirt) 0.0
Old   February 4, 2016, 04:49
Alexey Matveichev
OK. You did not find it in transportProperties, search in 0/alpha.* files. Since you did not post your case, other people can only GUESS what is wrong. And, in general, guessing game is rather annoying.
multi phase flow, multiphaseinterfoam, transportproperties
[OpenFOAM] an error in Calculator's equation immortality ParaView 12 June 29, 2021 00:10
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
