Volume Cells
Old   March 4, 2016, 06:19
Default Volume Cells
Robert R.
chefkoch89 is on a distinguished road
Dear Community,
this is my first thread and I'm still new with OpenFOAM.
I'm working on multiphase solver wich is based on InterFoam with some enhancements.
Right now I want to implement a porosity criteria funtion based on Darcys law into the code.
For these computations I need a loop, which is checking, if the temperatur in each cell and the cells within ten times the diameter of that cell are in a critical stage of solidification (this value is given by a temperature range).
My problem is, that I don't know how I can identify one cell and check if the temperatures of the surrounding cells are below the given temperature range. Finally I want to add their volumes to a new value.
I hope you are able to understand the problem. I image that the needed code is quite simple and not a big problem
Thank you!
chefkoch89 is offline   Reply With Quote
[ICEM] Problem with prism cells sidharath ANSYS Meshing & Geometry 0 September 1, 2015 07:09
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
