Cameron
Rep Power: 13 ![]() |
Hi All,
I'm simulating a helicopter blade using SRFSimplefoam. At the moment it converges, but it takes a very long time for the startup vortices to convect out of the domain (around 3000 iterations). Is there any way to speed this up? The problem is I don't have a velocity defined on the inlet, the flow is driven by the rotation of the reference frame driving air over the blades. This is why I'm guessing potentialFoam crashes for me when I try to use it. I also currently use the addSwirlAndRotation tool I found somewhere to start the simulation with the appropriate Urel field, which sped things up considerably, but these vortices still take a long time to convect out. |
Anton Kidess
Rep Power: 30 ![]() |
Perhaps run the simulation on a coarse mesh, then map the results to your original case.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
convergence, rotor, rotor blade, srfsimplefoam, vortices |
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
In the case of convergence | aja1345 | FLUENT | 1 | July 31, 2015 03:58 |
CFX overwhelming Fluent in mass convergence of boundary layer separation case | Pierre1 | FLUENT | 7 | March 26, 2015 21:43 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
