Smearing interface for capillary flows using interfoam
Old   March 12, 2016, 12:47
Default Smearing interface for capillary flows using interfoam
m.b. is on a distinguished road
Dear Foamers,
I’m completely new at OpenFoam and also new in this Forum, so first I want to say hello to everyone!
I’m working on capillary flows in nano structures and for this I am using the InterFoam solver.
Unfortunately I get strange results for my liquid-Air interface and for this reason I would like to ask for some explanations or hints for this.
My simulation case is describing a 2D rectangular horizontal capillary tube with a T-junction in it and also with different contact angles at the top and bottom wall. Unfortunately my liquid interface is smearing with the time so I am not able to detect the position of the “real” interface.
I have tried different discretization schemes to getting better results but as before the result is not satisfying.
It would be very nice if someone take a look at my case and give me some helpful hints to fix this.
I will post my simulation files below this message and also in this link:
https://www.dropbox.com/sh/swneqv0un...RRPWqyP4a?dl=0
Regards,
M.
My initial conditions:
For p:
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 0;
boundaryField
Inlet
type fixedValue;
value uniform 0;
Outlet
type fixedValue;
value uniform 0;
bottom
type fixedFluxPressure;
top
Front
type empty;
Back
type empty;
For u:
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
Inlet
type pressureInletOutletVelocity;
value uniform (0 0 0);
Outlet
type zeroGradient;
bottom
type fixedValue;
top
type fixedValue;
Front
type empty;
Back
type empty;
For alpha:
dimensions [0 0 0 0 0 0 0];
boundaryField
Inlet
type inletOutlet;
value uniform 1;
inletValue uniform 1;
bottom
type constantAlphaContactAngle;
theta0 50;
limit gradient;
value uniform 0;
top
theta0 35;
limit gradient;
value uniform 0;
Outlet
type zeroGradient;
Front
type empty;
Back
type empty;
My fvSchemes file:
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
divSchemes
div(rhoPhi,U) Gauss vanLeer;
div(phi,alpha) Gauss vanLeer01;
div(phirb,alpha) Gauss interfaceCompression;
div((muEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p_rgh;
pcorr;
alpha.water;
My fvSolution file:
solvers
alpha.water
nAlphaCorr 3;
nAlphaSubCycles 3;
cAlpha 1;
pcorr
solver PCG;
preconditioner DIC;
tolerance 1e-12;
relTol 0;
p_rgh
solver PCG;
preconditioner DIC;
tolerance 1e-12;
relTol 0.05;
p_rghFinal
$p_rgh;
tolerance 1e-12;
relTol 0;
U
solver smoothSolver;
smoother symGaussSeidel;
tolerance 1e-12;
relTol 0;
PIMPLE
momentumPredictor no;
nCorrectors 7;
nNonOrthogonalCorrectors 0;
m.b. is offline   Reply With Quote
Old   March 14, 2016, 15:05
Does somebody have any idea?
Old   April 19, 2017, 13:29
rasoul
rasool_soofi is on a distinguished road
Hi m.b
I have this problem, too and I cant solve it yet.
As far as I know, this problem refers to two factors:
1- the version of OpenFOAM or Foam-ext software.
2- the size of your channel and meshes.
rasool_soofi is offline   Reply With Quote
capillary flow, interfoam
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Implementing a stress on a portion of interface when using interFoam Kleiber OpenFOAM Programming & Development 0 May 18, 2014 00:55
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Smoothing interface of two-phase flows aiqch Main CFD Forum 0 June 18, 2009 13:31
Smoothing interface of two-phase flows aiqch Main CFD Forum 0 June 18, 2009 13:26
