Attempt to cast type wall to type lduInterface |
March 14, 2016, 10:37 |
Mohsen
Rep Power: 13 |
I'm trying to run a test case using PisoFoam but i faced with this error . can any one help me? Code:
FOAM FATAL ERROR: Attempt to cast type wall to type lduInterface From function refCast<To>(From&) in file /home/opencfd/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/typeInfo.H at line 114. FOAM aborting |
July 8, 2016, 04:36 |
Thomas
Rep Power: 10 |
Hi Mohsen,
Did you find the cause of the error? Thanks |
July 8, 2016, 13:47 |
Hesam
Rep Power: 11 |
Hi Mohsen,
Check your boundary condition and boundary file in polymesh. definition of your patches in 0 and polyMesh should be same. |
April 21, 2021, 01:09 |
Johnson Liu
Rep Power: 5 |
But the same face might have different boundary conditions in the 0 directory. For example, inlet might be set as freestream in k but zeroGradient in p. In this case, what should be the type for the inlet in the boundary file in polymesh?
April 21, 2021, 03:38 |
#5 | |
Yann
Rep Power: 26 |
Have a look at the user guide and use tutorials as examples. https://cfd.direct/openfoam/user-gui...#x25-1770005.2 |
May 15, 2021, 08:41 |
#6 | |
Johnson Liu
Rep Power: 5 |
March 10, 2023, 06:55 |
Mohammad Reza
Rep Power: 10 |
Hello All,
Does anybody know the source of this error for groovyBC boundary condition? -------------------------------------------------------------------------------------- --> FOAM FATAL ERROR: Attempt to cast type groovyBC to type fixedValue From function refCast<To>(From&) in file /home/mbanaker/foam/foam-extend-4.1/src/foam/lnInclude/typeInfo.H at line 114. FOAM aborting -------------------------------------------------------------- There are some solutions online for similar cases (not groovyBC) that is resolved by changing the type of boundary from wall to patch in polymesh/boundary file, but not a solution for this case apparently. Thanks in advance for sharing your experience with me. |
aborting, fatal error, wall |
foamToTecplot360 | thomasduerr | OpenFOAM Post-Processing | 121 | June 11, 2021 10:05 |
time step continuity problem in VAWT simulation | lpz_michele | OpenFOAM Running, Solving & CFD | 5 | February 22, 2018 19:50 |
Simulation of Radial Fan with simpleFoam MRF | nash | OpenFOAM Running, Solving & CFD | 2 | November 5, 2015 10:12 |
Divergent temperature in chtMultiRegion(Simple)Foam | akrasemann | OpenFOAM Running, Solving & CFD | 13 | March 24, 2014 02:54 |
