airfoil 2D: how to validate results?
Old   March 28, 2016, 19:20
Default airfoil 2D: how to validate results?
giammy92 is on a distinguished road
Hi foamers, my case case sists in a airfoil 2D with a chord lenght of 0.5459 m. I have found this formula in this site for mixing lenght http://www.cfd-online.com/Wiki/Turbulence_length_scale
Do you think it is correct for my case?
giammy92 is offline   Reply With Quote
Old   March 28, 2016, 19:42
Hi foamers, my case consists in airfoil 2D with a chord lenght 0.5459 m in a flow of air with a U=41.511 m/s, M=0.12, Re=1.5e6, turbulent intensity(%)=0.1, turbulent viscosity ratio=0.1 and angle of attack=13°. My model of turbulence is k-omega SST. Report my 0 directory:
EPSILON
dimensions      [0 2 -3 0 0 0 0];
internalField   uniform 0.397998;
boundaryField
    FAR_FIELD
        type            turbulentMixingLengthDissipationRateInlet;
        mixingLength    5.42e-5;
        value           uniform 0.397998;
    TRAILING_EDGE
        type            epsilonWallFunction;
    SUCTION_SIDE
    PRESSURE_SIDE
    frontAndBackPlanes
        type            empty;
K
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0.0025847;
boundaryField
    FAR_FIELD
        type            turbulentIntensityKineticEnergyInlet;
        intensity       0.001;
        value           uniform 0.0025847;
    TRAILING_EDGE
        type            kqRWallFunction;
    SUCTION_SIDE
    PRESSURE_SIDE
    frontAndBackPlanes
        type            empty;
NUT
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 1.51e-6;
boundaryField
    FAR_FIELD
        type            freestream;
        freestreamValue uniform 1.51e-6;
    TRAILING_EDGE
        type            nutkWallFunction;
        value           uniform 0;
    SUCTION_SIDE
        value           uniform 0;
    PRESSURE_SIDE
        value           uniform 0;
    frontAndBackPlanes
        type            empty;
OMEGA
dimensions      [0 0 -1 0 0 0 0];
internalField   uniform 1710.91;
boundaryField
    FAR_FIELD
        type            turbulentMixingLengthFrequencyInlet;
        value           uniform 1710.91;
    TRAILING_EDGE
        type            omegaWallFunction;
    SUCTION_SIDE
   PRESSURE_SIDE
     frontAndBackPlanes
        type            empty;
P
internalField   uniform 0;
boundaryField
    FAR_FIELD
        type            freestreamPressure;
    TRAILING_EDGE
        type            zeroGradient;
    SUCTION_SIDE
        type            zeroGradient;
    PRESSURE_SIDE
        type            zeroGradient;
    frontAndBackPlanes
        type            empty;
U
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (40.447 9.338 0);
boundaryField
    FAR_FIELD
        type            freestream;
        freestreamValue uniform (40.447 9.338 0);
    TRAILING_EDGE
        type            fixedValue;
        value           uniform (0 0 0);
    SUCTION_SIDE
        type            fixedValue;
    PRESSURE_SIDE
        type            fixedValue;
    frontAndBackPlanes
        type            empty;
So, how do you valutate my data and boundary conditions?
Last edited by wyldckat; April 2, 2016 at 11:53. Reason: Added [CODE][/CODE] markers
Old   March 29, 2016, 11:53
I would especially confirmations for nut and for mixing lenght
Old   March 29, 2016, 16:50
my problem is I can't obtain Cl of about 1.2-1.3, that is the right value comparing with experimental results, instead i obtain Cl of about 1.5. What could be cause of this?
Old   March 29, 2016, 16:59
Ruggero Poletto
rupole1185 is on a distinguished road
There are many things that could influence your result ..what is your y+ around the airfoil?
___________________________
President of CONSELF, the new CFD company with a great cloud solution. Try for free it here!
rupole1185 is offline   Reply With Quote
Old   March 29, 2016, 17:06
this is a good question i don't know this because i'm using a mesh created by another student that rans this case with fluent. Can i occur y+ for example with a checkmesh?
Old   March 29, 2016, 17:16
Ruggero Poletto
Y+ is something you can calculate once you have completed the simulation. Depending on your openfoam version you may run yPlus or yPlusRas
Old   March 29, 2016, 17:42
Good i have ran yPlus and it has created field yPlus for every time directory. Now which value of yPlus i have to read? That in directory 0, min, max or average?
Old   March 29, 2016, 17:44
Smile
taxalian is on a distinguished road
Send a message via Skype™ to taxalian
Having a look at you boundary conditions and the Cl value you are getting seems to be normal. Obviously if you need to compare your results with the experiments.
Prior to that you need to make sure that you have done grid independent study and secondly make sure that if you want to use the wallfunction approach, as you are, the yPlus value should be within a range of 30-150 or if you use a very good mesh that resolves till the airfoil surface then you should have average yPlus of about 1.
Another important thing to check is the "fvSchemes" and "fvSolution" dicitionaries.
That if you are using 1st order or 2nd order schemes this could also cause an overprediction of Cl.
If you experimental pressure coefficient plot, then its worth comparing with it too.
best of luck.
taxalian is offline   Reply With Quote
Ruggero Poletto
Since you are using komegasst it is recommended to maintain y+ between 1 and 5 let's say ...
Old   March 29, 2016, 17:53
after running yPlus i have this for time 0:
Create mesh for time = 0
Time = 0
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kOmegaSST
Selecting patchDistMethod meshWave
kOmegaSSTCoeffs
alphaK1 0.85;
alphaK2 1;
alphaOmega1 0.5;
alphaOmega2 0.856;
gamma1 0.555556;
gamma2 0.44;
beta1 0.075;
beta2 0.0828;
betaStar 0.09;
a1 0.31;
b1 1;
c1 10;
F3 false;
Patch 0 named TRAILING_EDGE, wall-function nutkWallFunction, y+ : min: 0.00457196 max: 0.00551105 average: 0.00492616
Patch 1 named SUCTION_SIDE, wall-function nutkWallFunction, y+ : min: 0.00260361 max: 0.0120975 average: 0.00588652
Patch 3 named PRESSURE_SIDE, wall-function nutkWallFunction, y+ : min: 0.00260361 max: 0.0120977 average: 0.00609504
Writing yPlus to field yPlus
Old   March 29, 2016, 18:11
Ruggero Poletto
First run the simulation and then calculate yPlus in the last time directory
Old   March 29, 2016, 18:17
here the last time directory of yplus:
Time = 6500
Reading field U
kOmegaSSTCoeffs
alphaK1 0.85;
alphaK2 1;
alphaOmega1 0.5;
alphaOmega2 0.856;
gamma1 0.555556;
gamma2 0.44;
beta1 0.075;
beta2 0.0828;
betaStar 0.09;
a1 0.31;
b1 1;
c1 10;
F3 false;
Patch 0 named TRAILING_EDGE, wall-function nutkWallFunction, y+ : min: 0.000309772 max: 0.00849312 average: 0.00144718
Patch 1 named SUCTION_SIDE, wall-function nutkWallFunction, y+ : min: 9.736e-05 max: 0.122311 average: 0.0236659
Patch 3 named PRESSURE_SIDE, wall-function nutkWallFunction, y+ : min: 0.000192994 max: 0.117785 average: 0.0205445
End
Old   March 29, 2016, 18:49
I have this doubt: for M=0.12, Re=1.5e6 e p=101325 Pa I have calculated a rho=1.1854 and mu=1.7908e-5 considering p=rho*R*T with T=298K.
But, i don't understand because in the precedent study with fluent with same parameters is been used rho=1.225 and mu=1.7894e-5.
Old   March 29, 2016, 19:06
another confirm that i have to ask: in file forces_coeff is right to consider both lref and Aref 0.5459, value of chord lenght?
Old   April 2, 2016, 09:16
these are my fvschemes and mu fv solution:
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) bounded Gauss linearUpwind grad(U);
div(phi,k) bounded Gauss upwind;
div(phi,omega) bounded Gauss upwind;
div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
wallDist
method meshWave;
solvers
p
solver GAMG;
tolerance 1e-06;
relTol 0.1;
smoother GaussSeidel;
nPreSweeps 0;
nPostSweeps 2;
cacheAgglomeration true;
nCellsInCoarsestLevel 10;
agglomerator faceAreaPair;
mergeLevels 1;
U
solver smoothSolver;
nSweeps 2;
tolerance 1e-08;
relTol 0.1;
k
tolerance 1e-8;
relTol 0.1;
nSweeps 1;
omega
tolerance 1e-8;
relTol 0.1;
nSweeps 1;
SIMPLE
nNonOrthogonalCorrectors 0;
pRefCell 0;
pRefValue 0;
residualControl
p 1e-5;
U 1e-5;
k 1e-5;
omega 1e-5;
relaxationFactors
fields
p 0.3;
equations
U 0.7;
k 0.7;
omega 0.7;
Old   April 2, 2016, 09:33
I want use k omega SST for high value of reynold even if my y+ around airfoil is <1 because i want a flux turbulent fully developed. So which BC for wall should use?
now i'm using:
k kqRWallFunction
value uniform internalfield
nut nutkwallfunction
value uniform 0
omega omegawallfunction
Old   April 7, 2016, 11:42
Angry
  #18
My results of Cl, for every BC's that i have tried, still remain about 1.5, but Cl must be about 1.25. How is possible that? I have a mesh very fine with y+ less than 1. I've found a discussion http://www.cfd-online.com/Forums/ope...estigated.html in which is suggested to use follow bc's for wall:
-k, fixed value very small
-nut, calculated
-omega, omegawallfunction
For patch FAR_FIELD i've use:
-k, turbulentIntensityKineticEnergyInlet with value uniform calculated: 1.5(U*I)^2
-nut, calculated with value uniform 0;
-omega, turbulentMixingLengthFrequencyInlet with value uniform: 1/mu*rho*k*(mut/mu)^-1
and mixinglenght calculated from this formula http://www.cfd-online.com/Wiki/Turbulence_length_scale
My angle of attack is 13° so:
liftDir (-0.22495 0.97437 0);
dragDir (0.97437 0.22495 0);
Questions:
1) Do you validate these bc's and formula for my case?
2)Why did i have about same results of Cl with different bc's like nutkwallfunction, nutuspaldingwallfunction, nutlowre for nut and kqrwallfunction for k?
3)Could be the cause in fvschemes or fvsolution?
Please, help me, i have wasted a lot of time for this problem, i can't imagine what else i have to change!!
Old   April 8, 2016, 10:40
Mahdi Hosseinali
anishtain4 is on a distinguished road
I'm not an expert in airfoils but knowing from LES simulations upwind is over diffusive (induces higher viscosity, hence higher coefficients might be expected). You might want to try to run your case with
divSchemes
default none;
div(phi,U) Gauss linear;
div(phi,k) Gauss limitedLinear 1;
anishtain4 is offline   Reply With Quote
Old   April 8, 2016, 11:24
now i'm trying with this:
ddtSchemes
gradSchemes
grad(U) cellLimited Gauss linear 1;
divSchemes
default none;
div(phi,U) bounded Gauss linear;
div(phi,k) bounded Gauss limitedLinear 1;
div(phi,omega) bounded Gauss limitedLinear 1;
div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 12:42
CFD validation on Eppler 473 airfoil and getting incorrect results Willemsj FLUENT 4 April 5, 2015 16:59
Unphysical Results of Low-Re Airfoil Simulations ericthefatguy SU2 2 February 2, 2015 05:07
Airfoil moving inside a fluid - Results discussion GM_XIII STAR-CCM+ 6 July 18, 2013 22:29
[FloWorks] Request advice for an airfoil calculation problem Bogey Jammer Main CFD Forum 0 September 29, 2009 17:06
