Advice for waveFoam, using exported stl meshes
Old   March 31, 2016, 00:03
Default Advice for waveFoam, using exported stl meshes
Chia
chia87 is on a distinguished road
All is fine and running, BUT, when I double check my wave elevation results, the wave elevation results are fishy, and when I went to look at paraFoam, i found out that the wave doesn't move an inch.
Commands used
1) blockMesh
2) surfaceFeatureExtract
3) snappyHexMesh -overwrite
4) setWaveParameters
5) setWaveField
6) waveGaugesNProbes (to set wave probes)
7) decomposePar
8) nohup mpirun -np 60 waveFoam -parallel 2>&1 | tee log.waveFoam
Wavesproperties.input
seaLevel -24.0;
relaxationNames ( inlet outlet );
initializationName outlet;
inletCoeffs
waveType stokesFifth;
stokesDrift 0.0;
Tsoft 15;
depth 336;
period 15.56;
direction ( 1 0 0 );
phi 0;
height 30;
waveNumber (0.01574 0 0);
omega 0.4038;
relaxationZone
relaxationScheme Spatial;
relaxationShape Rectangular;
beachType Empty;
relaxType INLET;
startX (-800 -168 -360);
endX (-400 168 120 );
orientation ( 1 0 0 );
outletCoeffs
stokesDrift 0.0;
Tsoft 15;
depth 336;
period 15.56;
phi 0;
height 30;
omega 0.4038;
relaxationZone
beachType Empty;
relaxType OUTLET;
startX (400 -168 -360 );
endX (800 168 120 );
Any help is appreciated! thanks!
chia87 is offline   Reply With Quote
Old   March 31, 2016, 22:08
Default ask for help
Maoyanjun
Maoyanjun is on a distinguished road
Hello Chia:
sorry for can't help you.But I have a question ask for you.I change the default seaLevel 0.0 to 1.0. But it goes wrong.the error information is"keyword seaLevelAsReference is undefined in dictionary "/home/maozhuxi/OpenFOAM/maozhuxi-2.4.0/applications/utilities/waves2Foam/tutorials/waveFoam/wavestationstructure/constant/waveProperties". The second problem is when I use snappyHexMesh to create a 2D mesh, I create the stl model in negtive axis,but when I view it in paraFoam,It always in the positive axis. so if I set the seaLevel 0.0. I can't put the model in the water.
Have you ever meet these problems.or could you give me some suggestions.
Thanks
Maoyanjun is offline   Reply With Quote
Old   April 3, 2016, 22:16
Chia
Dear Mao,
Initially when i used starccm mesh to export to OpenFOAM, I have similar problems
The mesh in starCCM has different x,y,z orientation,
In my case, StarCCM mesh was set gravity at z level, and my default settings for openfoam, gravity was at y level, so the waves was in a wrong direction,
I would suggest going into paraFoam and look at the coordinates of the wave tank boundaries and as well as your stl mesh coordinates.. did you change your water depth accordingly when you change seaLevel?
P.S - Im a beginner in OpenFOAM , sorry if i cant help much
Old   April 3, 2016, 22:18
Chia
Dear all,
After seeking some external help, its found that, my snappyHexMesh could have been not well defined,
Hence, guess I will have to redo my snappy.. if I could have some additional guidance, I would greatly appreciate it much! Thanks
Old   April 12, 2016, 22:48
Maoyanjun
Originally Posted by chia87 View Post
Dear Mao,
Dear Chia,
sorry for reply you late,thanks for your advice.After reading the src.I find in my dev 2.4.0 of Foam.It needs to define a referenceSeaLevel coefficient behind the seaLevel. So after defining it .It works well when I change the seaLevel,Hope that will be useful for other beginners, and hope we can keep in touch and exchange our experience.
Old   April 13, 2016, 01:23
Chia
Welcomed! I also managed to solve my problem as well, seems that there is problem with my snappyhexmesh dict,
[ICEM] Using STL Data with ICEM CFD/AI-Environment Shawn Givler ANSYS Meshing & Geometry 18 March 11, 2019 13:03
[snappyHexMesh] orthogonality problem with raw STL file tellico OpenFOAM Meshing & Mesh Conversion 1 April 16, 2013 03:18
Hex and Tet meshes - simplefoam comparison danvica OpenFOAM Running, Solving & CFD 10 January 4, 2013 01:18
Meshing complex white-light/GOM based STL models jola Main CFD Forum 13 January 30, 2012 01:35
[snappyHexMesh] SnappyHexMesh meshes inside and outside of an STL geometry villier OpenFOAM Meshing & Mesh Conversion 17 June 15, 2010 19:51
