Advice about turbulence models?
Like Tree1Likes
  • 1 Post By AnasCFD
Old   April 18, 2016, 09:52
Default Advice about turbulence models?
mqsim is on a distinguished road
Hi everyone!
I am looking for advice about turbulence models in OpenFoam. I have tried three turbulence models (k-omega SST, k-epsilon, Spalart-Allmaras) for the same case (study of the wind load on a building). At the beginning, I used the k-omega SST model but results were not enough accurate. So I tried the k-epsilon model but the calculation did not seem to converge. With the Spalart-Allmaras, model results are ridiculous. The stagnation pressure is approximately 50% higher than expected.
The geometry is complex so it is really difficult to create a good mesh using snappyHexMesh. I know that differences between turbulence models could be due to the mesh, but it seems I cannot improve the quality of the mesh with snappyHexMesh. I cannot show the mesh or the geometry, it is for an industrial case.
Regards,
mqsim
mqsim is offline   Reply With Quote
Old   April 25, 2016, 18:24
anas
AnasCFD is on a distinguished road
Hi mqsim,
You are comparing 3 different turbulence models. k-omega is accurate but requirs yplus ~ 1. The standard k-epsilon is not that accurate but usually it converge easier. On the other hand Spalart-Allmaras is not that accurate since it is a one equation model.
I suggest to check your yplus. Then compare the results obatined with k-omega (with yplus ~1) with that obtained by realizableKE model.
All the best and success.
AnasCFD is offline   Reply With Quote
Old   April 26, 2016, 04:10
Hi anas,
Thank you for your answer. I am not sure to understand what means "yplus". Is it the size of the mesh in the y direction?
mqsim
Old   April 26, 2016, 12:55
anas
Please take a look to this wiki
http://www.cfd-online.com/Wiki/Dimen...e_%28y_plus%29
mqsim likes this.
Old   April 27, 2016, 04:36
Thank you Anas! Hopefully it will help me to improve my models.
Old   April 27, 2016, 07:02
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
I just want to mention that
kEpsilon vs kOmega:
kEpsilon is more accurate far away from walls
kOmega is more accurate at walls
Therefore the kOmega-SST model was introduced which at least blends both models
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   April 27, 2016, 07:50
Thank you Tobi for your answer, it is really useful to me!
PANS turbulence models HelioVillanueva OpenFOAM Programming & Development 38 August 4, 2023 01:58
Only two turbulence options available in CFX Pre Jack001 CFX 5 March 30, 2016 02:47
Y plus for various turbulence models taram CFX 8 December 16, 2013 11:44
Are there more FLUENT Turbulence Models? Travis FLUENT 3 December 30, 2008 01:45
Turbulence models become invalid at Re=2000~5000? liweif FLUENT 9 August 27, 2007 11:55
