April 20, 2016, 21:18 |
K-Epsilon failing for otherwise working case
Rep Power: 10 |
I have flow over a cylinder, simple case to play with BCs and turbulence models. Everything is good for laminar and solving turbulence with SpalartAllmaras but trying to implement K-Epsilon diverges when trying to solve for epsilon. At the first time step it diverges and I get a floating point exception. Is there an issue with my boundary conditions for epsilon?
Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 1e-05 field U tolerance 1e-05 field nuTilda tolerance 1e-05 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 -0.33; sigmak 1; sigmaEps 1.3; } No MRF models present No finite volume options present Starting time loop Time = 0.001 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 5.8534e-09, No Iterations 50 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 9.37619e-09, No Iterations 44 GAMG: Solving for p, Initial residual = 1, Final residual = 0.0899236, No Iterations 7 GAMG: Solving for p, Initial residual = 0.098076, Final residual = 0.00642081, No Iterations 1 time step continuity errors : sum local = 0.00354511, global = -1.46424e-05, cumulative = -1.46424e-05 smoothSolver: Solving for epsilon, Initial residual = 0.995688, Final residual = nan, No Iterations 1000 smoothSolver: Solving for k, Initial residual = nan, Final residual = nan, No Iterations 1000 ExecutionTime = 1.83 s ClockTime = 2 s Time = 0.002 smoothSolver: Solving for Ux, Initial residual = nan, Final residual = nan, No Iterations 1000 smoothSolver: Solving for Uy, Initial residual = nan, Final residual = nan, No Iterations 1000 GAMG: Solving for p, Initial residual = nan, Final residual = nan, No Iterations 1000 GAMG: Solving for p, Initial residual = nan, Final residual = nan, No Iterations 1000 --> FOAM FATAL IO ERROR: wrong token type - expected Scalar, found on line 0 the word 'nan' file: /home/scott/OpenFOAM/scott-v3.0+/run/tutorials/incompressible/simpleFoam/cylinder/system/data.solverPerformance.p at line 0. From function Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::doubleScalar&) in file lnInclude/Scalar.C at line 93. FOAM exiting Code:
FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object k; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0.008; boundaryField { frontback { type empty; } inlet { type fixedValue; value uniform 0.008; } outlet { type zeroGradient; } topbottom { type zeroGradient; } walls { type kqRWallFunction; value uniform 0.008; } } // ************************************************************************* // Code:
FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object epsilon; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -3 0 0 0 0]; internalField uniform 0.5; boundaryField { frontback { type empty; } inlet { type fixedValue; value uniform 0.5; } outlet { type zeroGradient; } topbottom { type zeroGradient; } walls { type epsilonWallFunction; value uniform 0.5; } } // ************************************************************************* // |
successful time step for 2D problem failing for 3D case of same problem. | mandman | Main CFD Forum | 6 | March 10, 2015 19:01 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
Adaptation failing in // Fluent case? | Riaan | FLUENT | 0 | February 3, 2006 14:57 |
Working with compressed case and data files | Darrell Anthony Egarr | FLUENT | 0 | December 15, 2002 07:05 |
