twoPhaseEulerFoam (very) high pressure when using kinetic theory
Like Tree2Likes
  • 1 Post By rdbisme
  • 1 Post By rdbisme
Old   May 13, 2016, 03:58
Thumbs up twoPhaseEulerFoam (very) high pressure when using kinetic theory
rdbisme's Avatar
Ruben Di Battista
rdbisme is on a distinguished road
Hello everybody,
I'm basically simulating a slurry flow with solid particles in a liquid carrier. I managed to run simulation with different turbulent models for the liquid carrier (basically k-w SST and std. k-epsilon) getting reasonable velocity profiles and pressure drops.
In most of the papers I'm trying to emulate (i.e. CFD modeling for pipeline flow of fine particles at high concentration - Kaushal et al.) they use kinetic-theory for granular flow.
I tried to enable it but I get a practically laminar profile for the solid phase.
Here an image that compares the two velocity profiles with same volume fraction (13%), inlet velocity (1.5), particle diameter (1.3mm), k-w for carrier and in the red profile I used the kinetic-theory for granular flows with equilibrium hypothesis.
GEOMETRY DETAILS
Pipe Diameter: 15e-3 [m]
Pipe Length: 0.6 [m]
Gravity: [0 0 -9.81]
Position of the sample line: 0.4 [m] from the inlet
Boundary Conditions:
  • inlet:
    • U.carrier: 1.5 [m/s]
    • U.dispersed: 1.5 [m/s]
    • k: Intensity 0.005 U.carrier (turbulentIntensityKineticEnergyInlet)
    • omega.carrier: FixedValue 1
    • alpha.carrier = FixedValue 0.13
    • p = calculated
    • p_rgh = zeroGradient
    • Theta.dispersed = FixedValue 0
    • nut for both: calculated
  • outlet:
    • U.carrier: zeroGradient
    • U.dispersed: zeroGradient
    • k: zeroGradient
    • p = calculated
  • walls
    • U.* = no-slip
    • k = LowReWallFunction/Std Wall Function (depends from the mesh)
    • omega = Wall Function
    • p = calculated
    • Theta = zeroGradient
    • nut: calculated
  • symmetryPlane:
    • symmetry for all
PHASES INFORMATIONS
Liquid Carrier Density: 870 [Kg/m³]
Liquid Carrier Viscosity: 0.292E-3 [Pa s]
Dispersed Phase Density: 1026 [Kg/m³]
Dispersed Phase Viscosity: 0.292E-3 [Pa s]
(Case naming system: 15_13_kw_keq:
  • 15 = 1.5 m/s inlet velocity
  • 13 = 1.3mm particle diameter
  • kw = k-omega sst turbulence for carrier
  • keq = kinetic theory with equilibrium )
Seems to be related to viscosity provided by the model: it's basically a laminar profile so I would say that there is not enough viscosity.
An help would be very appreciated, thanks...
OpenFOAM 3.0.1
Here is my case too:
cfd-online.tar.gz
HPE likes this.
rdbisme is offline   Reply With Quote
Old   April 13, 2020, 11:00
Masoud Kahnooji
masoudbme90 is on a distinguished road
Hello Ruben (tidusuper91)
I am simulating slurry flow by twophaseeulerfoam, and I study your case. I am surprised because of your refine mesh (very small). I read that "The cell size is chosen to be roughly about 30 times the particle diameter of the solid phase, and If a finer mesh should be used, it is important that the size of the control volumes is not smaller than the diameter of the particle. In a control volume smaller than the particle diameter, the particle would fill the entire control volume (αp = 1) and not allow for e.g., particle-particle interactions.", but the minimum volume size of your mesh is smaller than particle volume. What is your idea about the size of the mesh when we use twophaseeulerfoam for slurry flow?
I know that your question was in 2016, but could you tell me how did your problem solve?
Sincerely yours
masoudbme90 is offline   Reply With Quote
Old   April 13, 2020, 12:16
rdbisme's Avatar
Ruben Di Battista
Hello Masoud,
it was indeed long time ago. Where did you read that? Can you provide a reference?
masoudbme90 likes this.
Old   April 13, 2020, 12:41
Masoud Kahnooji
Hello Ruben
Thank you for your kind response . I read a tutorial about twophaseeulerfoam at Chalmers university was written by Busch:
https://www.google.com/url?sa=t&rct=...j7gVliLiYwiVsf
Old   April 13, 2020, 15:18
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
It has been a while that I haven't read a well prepared question such as this one in this forum.
Thanks.
HPE is offline   Reply With Quote
Old   April 13, 2020, 15:48
rdbisme's Avatar
Ruben Di Battista
Originally Posted by masoudbme90 View Post
Hello Ruben
Well, as I said, it was long time ago. But I don't think there's a limitation on that ratio numerically speaking. The question would then be if the results are physically sound. I was able, at the end, to extract useful profiles from this configuration.
This question was related to my M.Sc. thesis that you can find here. I hope that would help you!
Old   April 13, 2020, 15:54
rdbisme's Avatar
Ruben Di Battista
Thanks.
Ahahah, thanks. It was long time ago and... yet nobody answered.
Old   April 15, 2020, 12:38
Masoud Kahnooji
Hello Ruben
Thank you for your response.
Old   July 3, 2020, 03:52
kimy
qi.yang@polimi.it is on a distinguished road
Send a message via ICQ to qi.yang@polimi.it Send a message via AIM to qi.yang@polimi.it Send a message via Yahoo to qi.yang@polimi.it
Hi Masoud, did you simulate slurry flow without problem? I am also doing this research.
Hello Ruben
qi.yang@polimi.it is offline   Reply With Quote
Old   July 3, 2020, 03:54
kimy
Thanks for your post. I found in Fvsolution file, you used under relaxation factor. However, during the simulation, it was neglected no matter how you changed the coefficient. Also, the issue of time step is significant.
Originally Posted by rdbisme View Post
Hello everybody,
GEOMETRY DETAILS
  • inlet:
    • p = calculated
  • outlet:
    • k: zeroGradient
    • p = calculated
  • walls
    • U.* = no-slip
    • p = calculated
    • nut: calculated
  • symmetryPlane:
    • symmetry for all
PHASES INFORMATIONS
OpenFOAM 3.0.1
Attachment 47417
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 17:16
About kinetic Theory in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Programming & Development 3 April 8, 2016 16:32
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC Endel OpenFOAM Running, Solving & CFD 3 September 11, 2014 16:29
high pressure simulation mahi FLUENT 0 November 7, 2008 01:30
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
