Floating Point Errors using RhoCentralFoam for Shock Tube
Old   May 31, 2016, 21:00
Default Floating Point Errors using RhoCentralFoam for Shock Tube
Matthew Shorter
matthewshorter is on a distinguished road
I am trying to simulate an axisymmetric shock tube with a 150:1 pressure ratio across the driver and driven regions. Currently, I can run the simulation with a lower 15:1 pressure ratio and get the expected results for that case but I run into floating point errors almost immediately under the actual conditions (after <1e-6 seconds). The simulation uses room temperature helium with a driven section initial pressure of 0.1atm. The driver and driven sections are of unequal radii, with the driver being about twice the diameter of the driven section. All parameters are using the physical dimensions in the relevant SI base units except for the inviscid assumption. For BCs, I am using a fixedValue noslip condition for the wall velocity (slip was tried but with no effect), zeroGradient for wall pressure, and wedge for the front and back faces. What type of approach should I take to resolving this issue? I have rhoCentralFoam set up with the same solver configuration as the shockTube tutorial.
matthewshorter is offline   Reply With Quote
Old   June 9, 2016, 09:07
Matthew Shorter
Update: using blockMesh instead of GMSH (hex instead of tets) seems to help. I think the infinitesimally thin shock wave is messed up when the nodes are all jumbled with a tet mess, introducing errors that eventually blow up the solver. Hex mesh looks much, much better.
icoFoam - Floating point exception (core dumped) File OpenFOAM Running, Solving & CFD 26 March 6, 2021 04:26
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 02:50
Temperature floating point exception ayckrom FLUENT 1 May 13, 2015 09:02
Floating point error and divergence detected aannjj FLUENT 0 July 2, 2013 03:44
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
