Inlet boundary condition of swirl angle
Like Tree1Likes
  • 1 Post By TobM
Old   June 30, 2016, 16:01
Default Inlet boundary condition of swirl angle
Peng Liang
tjliang is on a distinguished road
Dear Openfoamers,
I want to simulate a jet flow which has a swirl angle of 45 degree at inlet. How can i define this bc?
Best regards ,
Peng
tjliang is offline   Reply With Quote
Old   July 1, 2016, 04:01
TobM is on a distinguished road
What about this bc here:
swirlFlowRateInletVelocity
http://openfoam.github.io/Documentat...ml/a02600.html
this should do what you want. You have to calculate the flow rate and rpm so that you get a 45 degree swirl angle.
gio3 likes this.
TobM is offline   Reply With Quote
Old   July 1, 2016, 05:06
Peng Liang
Thanks, but could you please tell me more about the relation between rpm and swirl angle?
Old   July 1, 2016, 05:56
"This boundary condition provides a volumetric- OR mass-flow normal vector boundary condition by its magnitude as an integral over its area with a swirl component determined by the angular speed, given in revolutions per minute (RPM)"
As I understand it:
Mass or volumetric flow define the normal velocity component and rpm the rotational. You have to calculate the exact values you need according to your problem.
UDF fluent:Change boundary condition. determination inlet and outlet boundary in "t" gzamiri@gmail.com FLUENT 0 September 27, 2015 05:32
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
How to set up the inlet boundary condition for a low pressure case? beastieboys6 FLUENT 3 April 10, 2012 22:46
Velocity inlet boundary condition for porous medium Chander CFX 3 March 11, 2012 21:18
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
