Cab
Rep Power: 10 ![]() |
Hello
I'm having problems simulating a simple case using AMI conditions. This is a deposit with input and output, and a rotating member inside . I try to simulate this case in 2D AMI and i have not any problem, so i think that my problem is in the definition of the boundary conditions or on the geometry. Attached files. If anyone can help my I'll be very grateful. In the terminal i see this message. Create time Create mesh for time = 0 Selecting dynamicFvMesh solidBodyMotionFvMesh Selecting solid-body motion function rotatingMotion Applying solid body motion to cellZone rotator #0 Foam::error: ![]() #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::globalIndexAndTransform::matchTransform(Foam ::List<Foam::vectorTensorTransform> const&, int&, Foam::vectorTensorTransform const&, double, bool) const at ??:? #4 Foam::globalIndexAndTransform::determineTransforms () at ??:? #5 Foam::globalIndexAndTransform::globalIndexAndTrans form(Foam: ![]() #6 Foam::globalMeshData::globalTransforms() const at ??:? #7 void Foam::globalMeshData::syncPointData<bool, Foam: ![]() ![]() #8 Foam::solidBodyMotionFvMesh::solidBodyMotionFvMesh (Foam::IOobject const&) at ??:? #9 Foam::dynamicFvMesh::addIOobjectConstructorToTable <Foam::solidBodyMotionFvMesh>::New(Foam::IOobjec t const&) at ??:? #10 Foam::dynamicFvMesh::New(Foam::IOobject const&) at ??:? #11 ? at ??:? #12 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #13 ? at ??:? Floating point exception (core dumped) 0.tar.gz system.tar.gz boundary.tar.gz |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
