bounding error for k and epsilon
Old   July 23, 2016, 04:00
Default bounding error for k and epsilon
CFD_Lovers
sinatahmooresi is on a distinguished road
Hi Foamres!
i'm dealing with k-e model and RSM (LRR and SSG) in a case. i faced with the problem of bounding error for k and epsilon in my runs. the main point i want to ask is that how sensitive to initial and boundary conditions is the case in solvers like pisoFoam???
actually i mean when i use fixedValue BS for inlet in k and epsilon files, i face with this problem ( bounding error) and when i put them in zeroGradient , i have no problem!
also with same boundary conditions ( zeroGradient for inlet of k, e) when i change the mesh of my geometry i face with that error again!
so does anyone have an experience about sensibility of cases in incompressible solver(particular in pisoFoam) to such boundary conditions and mesh changing as i mentioned above??
regards
bests
sinatahmooresi is offline   Reply With Quote
Old   July 27, 2016, 06:57
teuk is on a distinguished road
Hi sinatahmooresi,
in my experience it depends on your bounding. If the bounded values are above but close to zero this is not a problem. It's more a problem of calculation precision.
for example: If your k-value is something like 1e-24 the bounding will set the value to 0. Because if you run in normal precission mode your pressicion is something like 1e-12 if I remeber correct.
But if your k-value is below 0 this is really a problem. In most cases it depends on your mesh or your timstep size.
regards,
teuk
teuk is offline   Reply With Quote
Old   July 27, 2016, 10:25
CFD_Lovers
Originally Posted by teuk View Post
Hi sinatahmooresi,
regards,
teuk
Hi teuk
thank u for your reply, I should say that in may case value are going to be negative and then crash the solution by exploding Courant. so I fined something in other threads in openfoam forum. and some people had proposed to changing the scheme of div(phi,k) from higher order to first order method like e.g. :
gauss limitedLinear 1 ... change to gauss upwind
I didi it and it is working now!
so i didn't verify the results yet
so my research is continued !
and the thing: I'm dubious that grid generation could be the source of this problem and still i'm working on it
thank u again for your reply
regards
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 08:30
Bounding k and epsilon & coldEngineFoam sasanghomi OpenFOAM 1 September 13, 2013 12:12
epsilon and K blowing up. sivakumar OpenFOAM Running, Solving & CFD 1 October 25, 2012 04:50
MRFSimpleFOAM goes divergenced! renyun0511 OpenFOAM Running, Solving & CFD 0 November 19, 2009 02:11
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 20:21
