co-efficient of drag and lift
Old   August 3, 2016, 06:30
Default co-efficient of drag and lift
subhankar
SUBHANKAR is on a distinguished road
Hi everyone,
I have started using openFoam since last two months.
I am studying flow past a cylinder kept between two infinitely large plates. Reynolds no. is 500 and strouhal no. is 0.18.I want to get the co-efficient of drag and lift. How can i get the values?Also can you suggest appropriate boundary conditions.
Thanks in advance.
regards
Subhankar
SUBHANKAR is offline   Reply With Quote
Old   August 4, 2016, 10:43
T.D. is on a distinguished road
You can get them by forces functions to place inside system/controDict.
For example, if you look to /tutorials/compressible/sonicFoam/ras/nacaAirfoil/system/controlDict
you will fine the following:
functions
    forces
        type            forceCoeffs;
        libs ( "libforces.so" );
        writeControl   timeStep;
        writeInterval  1;
        patches
            WALL10
        log         true;
        rhoInf      1;
        CofR        (0 0 0);
        liftDir     (-0.239733 0.970839 0);
        dragDir     (0.970839 0.239733 0);
        pitchAxis   (0 0 1);
        magUInf     618.022;
        lRef        1;
        Aref        1;
Good Luck !
Regards,
T.D.
T.D. is offline   Reply With Quote
How to calculate lift, drag and lift distribution in Star CCM+? israelcasillas94 STAR-CCM+ 4 November 6, 2020 08:35
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 05:18
[OpenFOAM] Display lift and Drag in paraview SamerAli ParaView 1 May 16, 2013 12:51
Lift and Drag Monitor Point Values Converging to Zero Josh CFX 24 May 9, 2011 10:38
Correct lift but wrong pressure drag - possible? zx Main CFD Forum 4 July 27, 2007 23:38
