simplefoam error
Like Tree1Likes
  • 1 Post By sergiopb91
Old   August 1, 2016, 10:18
Default simplefoam error
Sergio
sergiopb91 is on a distinguished road
Hi, everyone.
I'm new using OpenFoam, I have been trying to run a 2D case, it's a pipe with a reduction. But when I use simpleFoam, throw me this error:
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/opt/openfoam30/platforms/linuxGccDPInt32Opt/lib/libOpenFOAM.so"
#3 void Foam::multiply<Foam::Tensor<double> >(Foam::Field<Foam::Tensor<double> >&, Foam::UList<double> const&, Foam::UList<Foam::Tensor<double> > const&) at ??:?
#4 Foam::tmp<Foam::GeometricField<Foam::Tensor<double >, Foam::fvPatchField, Foam::volMesh> > Foam:perator*<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<Foam::Tensor<double >, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
#5 Foam::linearViscousStress<Foam::RASModel<Foam::Inc ompressibleTurbulenceModel<Foam::transportModel> > >::divDevRhoReff(Foam::GeometricField<Foam::Vector <double>, Foam::fvPatchField, Foam::volMesh>&) const at ??:?
#6 Foam::IncompressibleTurbulenceModel<Foam::transpor tModel>::divDevReff(Foam::GeometricField<Foam::Vec tor<double>, Foam::fvPatchField, Foam::volMesh>&) const at ??:?
#7 ? at ??:?
#8 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
#9 ? at ??:?
Excepción de coma flotante (`core' generado)
I check the mesh several times and use checkmesh, also I have changed the initials properties (p, U, k, epsilon) and controlDict files but the error continue.
This is blockMesh information:
convertToMeters 0.001;
vertices
(0 0 0)
(60 0 0)
(60 9.65 0)
(130 9.65 0)
(130 22.35 0)
(60 22.35 0)
(60 32 0)
(0 32 0)
(0 0 1)
(60 0 1)
(60 9.65 1)
(130 9.65 1)
(130 22.35 1)
(60 22.35 1)
(60 32 1)
(0 32 1)
blocks
hex (0 1 6 7 8 9 14 15) (200 60 1) simpleGrading (2 1 1)
hex (2 3 4 5 10 11 12 13) (200 60 1) simpleGrading (2 1 1)
edges
boundary
inlet
type patch;
faces
(0 8 15 7)
outlet
type patch;
faces
(3 4 12 11)
upperWall
type wall;
faces
(6 7 15 14)
(4 5 13 12)
lowerWall
type wall;
faces
(0 1 9 8)
(2 3 11 10)
frontAndBack
type empty;
faces
(0 1 6 7)
(2 3 4 5)
(8 15 14 9)
(10 13 12 11)
mergePatchPairs
If someone can help me, I'd appreciate it.
sergiopb91 is offline   Reply With Quote
Old   August 19, 2016, 07:17
Carla
cvillescas is on a distinguished road
Hi Sergio,
The "back faces" after the pipe reduction are not assigned to any patch.
Carla
cvillescas is offline   Reply With Quote
Old   August 19, 2016, 12:01
Sergio
Hi Carla.
You are right, I forget to define those faces.
Thank you very much.
cvillescas likes this.
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
