How to add and select solver in Helyx
Old   August 24, 2016, 06:05
Default How to add and select solver in Helyx
Alex_Han
han0459 is on a distinguished road
Dear Foamers:
I am now using Helyx to conduct OpenFoam tutorials. I wonder how to add or modify the solver in the Helyx. Because even the application in controlDict is modified, it will not reflect in the GUI of Helyx.
Moreover, after I performed one tutorial through Helyx, I checked the controlDict file. There is no application command. Does anyone explain this for me?
Thank you in advance!
Best,
Alex
han0459 is offline   Reply With Quote
Old   April 18, 2017, 14:46
Joshua
Joshua14 is on a distinguished road
han0459,
HELYX-OS only allows users to use a small group of solvers inside the GUI. If you want to use other solvers or setting form OpenFOAM, one must do these outside the GUI. You can still use HELYX-OS to create your geometry and mesh, but all of your boundary conditions and setting must then be done by hand via the text files.
Joshua
Joshua14 is offline   Reply With Quote
New solver for two-phase flows with phase-change heat transfer liquidspoon OpenFOAM Programming & Development 41 July 1, 2022 11:11
How to select some variables not to be written into files? ripperjack OpenFOAM Programming & Development 12 August 7, 2020 11:15
CFX SOLVER parallel error Manol CFX 10 July 5, 2016 11:43
Cfd to ansys thermal to ansys structural interface ssixr ANSYS 17 July 31, 2015 15:18
[snappyHexMesh] Add additional boundary layers to complex stl surface tobijingles OpenFOAM Meshing & Mesh Conversion 1 October 26, 2011 10:45
