Heat source term in EEqn
Old   December 16, 2016, 09:13
Default Heat source term in EEqn
JoeFriend is on a distinguished road
I was trying to model the heat transfer through a membrane using chtMultiRegionFoam. Water evaporates on one side of the membrane, goes through it, and condenses on the other side. By now I'm not interested in the mass transfer, only heat. As a simplification, I'm treating the membrane as a solid region.
My question:
Is it possible to add a heat source term at the boundaries between the solid (membrane) and fluid regions (fluid channels)? This source would represent the latent heat due to the evaporation/condensation of water.
Where should I look to put the equations associated with this source term?
I would really appreaciate any help!
JoeFriend is offline   Reply With Quote
Source Term due to evaporation in energy transport equation styleworker OpenFOAM Programming & Development 3 September 7, 2022 03:09
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 17:34
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error FerdiFuchs OpenFOAM Community Contributions 27 April 16, 2014 15:14
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 13:14
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
