December 20, 2016, 11:03 |
Steady State scalarTransportFoam Problem
Rep Power: 10 |
Hello to all,
during the run of my case in steady stade cindition this message continues to appear Code:
--> FOAM Warning : From function gaussConvectionScheme in file finiteVolume/convectionSchemes/gaussConvectionScheme/gaussConvectionScheme.H at line 123 Reading "/home/roby/Scrivania/Ultimate/Scalar/system/fvSchemes.divSchemes.div(phi,T)" at line 31 Unbounded 'Gauss' div scheme used in steady-state solver, use 'bounded Gauss' to ensure boundedness. To remove this warning switch off 'boundedGauss' in "/home/roby/OpenFOAM/OpenFOAM-2.3.0/etc/controlDict" ^C Maybe i have to also change the solver (?) Any idea? Thanks for help, Roberto |
December 21, 2016, 04:38 |
Robert
Rep Power: 12 |
Take a look at your fvSchemes file (case/system/...)
Change your div(phi,T) entry from "unbounded Gauss" to "bounded Gauss" or "Gauss [...]". Should fix your problem. Anyhow your current message is just a warning and not an error. To further establish which entry you want, try to gain an understanding about what it means if a solution is bounded or unbounded. Regards, Robert |
December 21, 2016, 07:07 |
Rep Power: 10 |
Hi Robert, thanks for your reply.
I've just change the scheme in "bounded Gauss limitedLinear 1". The case runs however what i noticed is the simulation runs very slowly respect to the unsteady simulation. Maybe could the problem be the solver which in this case is set to PBiCG? Furthermore the residual stops decrasing around 10^(-3) while in the unsteady simulation around 10^(-11) Best Regards, Roberto |
The difference between steady state and transient | JuPa | CFX | 36 | December 9, 2019 22:50 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Convergence problem using simpleFoam steady state | vvqf | OpenFOAM Running, Solving & CFD | 12 | May 18, 2011 07:51 |
Monitor point values in a steady state simulation | Kushagra | CFX | 2 | July 13, 2008 20:03 |
steady state PISO problem | denizen | Siemens | 0 | December 20, 2006 02:55 |
