interFoam in parallel crashes (again)
Old   January 3, 2017, 13:05
Default interFoam in parallel crashes (again)
Filipe Direito
filipedireito is on a distinguished road
Hi! (And happy new year)
New year, old question. I was running a case with interFoam in parallel with 4 processors. It was fine. Then I decided to refine the mesh and the problem started. The simulations start running but at apparently random moment they stop in one of the these status (some old threads in this forum describe similar behavior):
- segmentation fault
- floating point exception (sometimes, but not always, with extremely high residuals)
- total pc freeze (have to reboot).
I then decided to test this on the damBreak case, to confirm the problem was not somewhere in my case. Running damBreak with 4 processors and 31k or 123k cells is apparently flawless. However, at 277k cells, the freezing/floating/segmentation problem appears.
I have read several webpages (most of them in CFD Online) and tried things like changing the MPI min Buffer. But I did not manage to solve the problem...
My system:
OF 4.1, systemOpenMPI
ubuntu 16.04
4720HQ, 16 gb ram, 16 gb swap
How I run:
setFields
decomposePar
mpirun -np 4 interFoam -parallel > log &
filipedireito is offline   Reply With Quote
crash, interfoam, mpirun, parallel
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 11:58
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 18:45
interFoam in parallel gooya_kabir OpenFOAM Running, Solving & CFD 0 December 9, 2013 05:09
Parallel runs with sonicDyMFoam crashes (works fine with sonicFoam) jnilsson OpenFOAM Running, Solving & CFD 0 March 9, 2012 06:45
Moving mesh crashes in parallel (1.5-dev) jploz OpenFOAM Programming & Development 8 October 21, 2009 17:22
