Fail to set swirl flow by four pipe
Old   February 14, 2017, 12:43
Default Fail to set swirl flow by four pipe
TeiGyou
zxzx is on a distinguished road
Hello, everyone
I have tried to ask some questions about how to realize the swirl flow in inlet. But until now I still can not get the proper answer. So I plan to create a physical model to help to realize the swirl flow in inlet. As you can see in the picture, I set four pipes in the top of the cylinder. But when I ran it, the flow through small pipe enters into cylinder and become straight line no matter how much the speed of flow. I am very confused for it. Could anyone here help me? Is there anything wrong in my setting. Thank you very much.
File Type: jpg Screenshot from 2017-02-16 03-30-46.jpg (150.1 KB, 5 views)
zxzx is offline   Reply With Quote
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) florian_krause OpenFOAM 22 June 13, 2013 21:25
swirl flow rvndr FLUENT 10 May 30, 2012 02:53
How to set the model for Fluid-solid flow in pipe Fishburn FLUENT 0 May 11, 2012 13:02
how to set BC for compressible flow target mass flow rate foolboy007 FLUENT 1 April 4, 2012 03:24
steam flow in a pipe driven by a pressure gradient between inlet and outlet SalvoCalvo COMSOL 0 March 11, 2010 06:52
