chtMultiRegionSimpleFoam: inconsistency between BCs and results
Old   February 21, 2017, 09:28
Default chtMultiRegionSimpleFoam: inconsistency between BCs and results
Andrea Di Ronco
Diro7 is on a distinguished road
Hello to everyone,
I'm trying to simulate conjugate heat transfer with the chtMultiRegionSimpleFoam solver.
My case consists in 2 fluid channels that exchange heat in counterflow through a solid matrix (you can see a section view of the solid region in the first picture).
The channels are small in section (diameter is about 2-3 mm) but very long (2.5 m).
The inlet and outlet BCs for the fluids are quite straightforward to assess, as well as the ones for the 2 fluid/solid coupling surfaces.
Regarding temperature in the solid region, since the heat exchanger is supposed to consist in a very large number of channels, I set zeroGradient BCs on the left/right faces (due to pattern symmetry) and cyclicAMI BCs on the top/bottom faces (due to the pattern periodicity).
The only "arbitrary" choice is the BC on the front/back solid faces (i.e. the ones where the fluid inlets and outlets lie). I couldn't find any reasonable boundary condition (from the physical modelling viewpoint), so I decided to use zeroGradient also here.
The simulation after 1500/2000 steps seems to reach convergence (residuals are very low for each quantity) and most of the results seem to be in agreement with predictions (fluid T differences, total heat transfer rates), but something is not convincing:
1) In the second picture you can find a T plot over an axial line in the solid region (at the exact center of the section; you can see the point in the first picture): the temperature derivative along the axial direction at the surfaces is not 0, in contrast with the zeroGradient BCs!
I tried different meshes (I use the Sweep method of the Fluent meshing tool) with different axial refinements but, as far as I know, the results are always quite the same.
2) Also, as you can see, the four corners show temperature values that are quite probably wrong (much higher/lower than the rest of the section).
Did anyone experience the same issues, or does know a possible explanation?
Should I use different BCs, or try to improve the mesh?
Thank you very much in advance for the help.
Andrea
PS: if you are wondering, the temperature field in the first picture is taken from a section exactly at half the channel length.
EDIT1: I added a picture of the mesh over the face.
EDIT2: it seems that the strange values at the corners were only a matter of visualisation in ParaView. I'm not an expert on how it works, but I realised that when plotting the original Cell Field rather than the interpolated (or smoothed, I don't know how to say it) Point Field the corner values are ok. Probably - and reasonably - in order to show correct values ParaView should account for the cyclic-ness of the boundary conditions, but it can not and some plotting error occurs.
Diro7 is offline   Reply With Quote
Old   March 2, 2017, 04:36
Andrea Di Ronco
No hints?
chtmultiregionsimplefoam
The effects of BCs and the initial conditions on the final results mrji8011 Main CFD Forum 7 February 3, 2021 17:10
BCs compatibility modified simpleFoam Tensian OpenFOAM Running, Solving & CFD 3 September 26, 2013 06:18
The effects of BCs and initial condition on final results mrji8011 FLUENT 0 August 27, 2013 22:16
Dealing with BC's in OF 1.6 vkrastev OpenFOAM Running, Solving & CFD 5 September 4, 2012 11:58
bc's of a komegaSST case Zymon OpenFOAM 11 July 25, 2010 09:36
