time step restriction for implicit icoFoam???
Old   June 29, 2016, 03:29
Default time step restriction for implicit icoFoam???
K.C. is on a distinguished road
Dear Foamers,
during my research I noticed, that there is a time step restriction for the momentum predictor. I tested different meshsizes and timesteps in the cavity case of icoFoam found then following restrictions:
1.) Co = u_wall*dt/dx < 1 (as usuall)
2.) nu*dt/dx² < 0.25
The last restriction seems strange, because icoFoam uses an implicit scheme.
Why do we have this restriction, where van-Neumann-stability-analysis predicts unconditional stabilyty for the implicit diffusive term in momentum equation? Do you observe the same restriction? Do you know how to overcome this problem?
Thanks for your help,
K.C.
K.C. is offline   Reply With Quote
Old   July 6, 2016, 03:51
Does anybody have an idea?
By the way an increase in corrector loops seems to soften the last restriction, but nevertheless a reson for this restriction is missing.
Old   July 12, 2016, 04:06
Please,
could anybody just confirm my observation and try the icoFoam-cavity case with nu*dt/dx² > 0.25?
Every literature tells me that implicit treatment of viscous stresses should avoid this time step restriction, but my icoFoam has this restriction.
Thanks to you.
Old   August 1, 2016, 10:39
This restriction is a huge problem for me and I dont understand, that every literature (e.g. Ferzinger) writes that solving the momentum predictor should be unconditional stable.
Old   February 23, 2017, 18:19
Default same problem
longhui zhang
zzzlllhh is on a distinguished road
Dear K.C.
Did you find the answer to this problem? I tested with icoFoam and found the same restriction on time step. Could you please tell me what produces this restriction if you already got the answer? Thank you very much!
Zhang
zzzlllhh is offline   Reply With Quote
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 00:01
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 10:08
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 02:34
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 07:56
