April 7, 2017, 10:57 |
abnormal velocity profile
Mohamed Elghorab
Rep Power: 10 |
Dear Foamer,
Just, I'm trying to run the normal channel395 tutorial with pimpleFoam solver but I changed the inlet to be turbulentInlet and the outlet to be zeroGradient in 0/U file and the 0/p as well. but the problem that I got the attached velocity profile , it's supposed to be parabolic shape as I know but here it's not like that. Could you please if you know where is the problem can you tell me? ThanksvelocityProfile.png |
April 10, 2017, 05:25 |
Agustín Villa
Rep Power: 15 |
what were the initial BC at the inlet and outlet? Normally, if you want to have a developed profile, or you use a very long channel, or you use cyclic BC |
April 10, 2017, 13:50 |
Mohamed Elghorab
Rep Power: 10 |
Hi Agustin,
my intial B.C as I wrote before for the inlet (turbulent inlet with velocity of 0.1335m/s and zeroGradient for pressure) and at the outlet (waveTransmissive for pressure and zeroGradient for velocity) both sides are cyclic. On the other hand I need just to study the transition so no need for developed flow. B.R |
April 11, 2017, 03:07 |
Agustín Villa
Rep Power: 15 |
Hi
you would see transition after a while, at a certain distance from your inlet. Maybe your domain is not long enough, and you dont see the desired profile |
April 11, 2017, 04:48 |
Mohamed Elghorab
Rep Power: 10 |
I think, I didn't show my problem well. The problem with me the velocity profile in the start of the laminar region at the start of the channel not after transition as I showed in the 1st . On the other hand, my channel Dimensions are taken from previous DNS study. Thanks |
Plot velocity profile along longitudinal axis of pipe | jorgelmilan | EnSight | 8 | July 7, 2018 14:30 |
Velocity profile reading in Fluent | mkpm | FLUENT | 0 | July 28, 2016 02:12 |
InterFoam - Validation for velocity profile in simple channel | me.ouda | OpenFOAM Running, Solving & CFD | 0 | October 19, 2015 06:42 |
[boundary condition] logarithmic velocity profile | cfdworker | FLUENT | 2 | April 17, 2009 23:36 |
Prescribed inflow velocity profile - how to? | Alan | Main CFD Forum | 10 | October 28, 2005 12:14 |
