LES and pimpleFoam: Is it wrong to do many Pimple/inner Loops?
Old   May 11, 2017, 02:23
Default LES and pimpleFoam: Is it wrong to do many Pimple/inner Loops?
Lukas Lebovitz
lukas.lebo is on a distinguished road
Hi
I'm currently doing a mesh-study to prove grid independency for a case of turbulent flow around a cube.
It is extremely hard to reach small yPlus and I can only do it with an O-Grid to stay at reasonable cell count. The problem with the O-Grid is it is very unstable at the edges and corners.
The simulation will only run if I do multiple inner Loops. If I set nOuterCorrectors to 50 it takes 15 loops to converge (pressure residual criterion is 10^-7). But I tried 5 nOuterCorrectors and the simulation is still able to run. Maybe I could reduce it further, but haven't tested it yet.
Is it bad practice to do multiple inner loops if you are interested in the velocity and pressure fluctuations at the object? I'm afraid it could dampen the fluctuations?
Thank you!
Lukas
Picture of the O-Grid: http://imgur.com/a/yfPUo
lukas.lebo is offline   Reply With Quote
Old   February 27, 2020, 08:47
Gang Wang
Gang Wang is on a distinguished road
Hi!
I also did the similar topics with you, have you got the answer to this?
Best,
Gang
Gang Wang is offline   Reply With Quote
question regarding LES of pipe flow - pimpleFoam Dan1788 OpenFOAM Running, Solving & CFD 37 December 26, 2017 14:42
Large residuals for a LES using pimpleFoam fgarita OpenFOAM Running, Solving & CFD 0 October 10, 2016 05:31
Discussion: LES SGSmodels and solvers gggiulio OpenFOAM Running, Solving & CFD 0 September 7, 2016 06:43
pimpleFoam LES y+ and wall functions Pj. OpenFOAM Running, Solving & CFD 3 January 16, 2014 11:31
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 11:35
