Error using simpleFoam : Foam::error::printStack(Foam::Ostream&) at |
Kim Le
Rep Power: 10 ![]() |
I got this error message unsing simpleFoam but I can't understand where the error says it is from... Can you help me please ? Thanks ! Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.1 Exec : simpleFoam Date : May 16 2017 Time : 14:52:58 Host : "abc1b7de1187" PID : 827 Case : /home/openfoam/run/22-bassinTestmixerVessel2D nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: no convergence criteria found. Calculations will run for 500 steps. Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon bounding k, min: 0 max: 1 average: 1 bounding epsilon, min: 0 max: 0 average: 0 kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 -0.33; sigmak 1; sigmaEps 1.3; } Creating MRF zone list from MRFProperties creating MRF zone: MRF1Agitateur1 creating MRF zone: MRF2Agitateur2 No finite volume options present #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> cons t&) at ??:? #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::opera tor/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatc hField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::vol Mesh> const&) at ??:? #5 Foam::RASModels::kEpsilon<Foam::IncompressibleTurbulenceModel<Foam::transportModel> >:: correctNut() at ??:? #6 ? at ??:? #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #8 ? at ??:? |
Rana
Rep Power: 9 ![]() |
im getting divergence problem what does it mean. during cfd simulation.
power
Rep Power: 12 ![]() |
Kim Le
Maybe this could help :
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { agitateur1 { type noSlip; } agitateur2 { type noSlip; } bassin_wall { type noSlip; } bassin_bottom { type noSlip; } bassin_top { type pressureInletOutletVelocity; value uniform (0 0 0); } } Code:
object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { agitateur1 { type zeroGradient; } agitateur2 { type zeroGradient; } bassin_wall { type zeroGradient; } bassin_bottom { type zeroGradient; } bassin_top { type totalPressure; p0 uniform 0; } } Code:
object k; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 1; boundaryField { agitateur1 { type kqRWallFunction; value uniform 0; } agitateur2 { type kqRWallFunction; value uniform 0; } bassin_wall { type kqRWallFunction; value uniform 0; } bassin_bottom { type kqRWallFunction; value uniform 0; } bassin_top { type calculated; value uniform 0; } } Code:
object epsilon; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -3 0 0 0 0]; internalField uniform 0; boundaryField { agitateur1 { type epsilonWallFunction; value uniform 0; } agitateur2 { type epsilonWallFunction; value uniform 0; } bassin_wall { type epsilonWallFunction; value uniform 0; } bassin_bottom { type epsilonWallFunction; value uniform 0; } bassin_top { type calculated; value uniform 0; } } Code:
object nut; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { agitateur1 { type nutkWallFunction; value uniform 0; } agitateur2 { type nutkWallFunction; value uniform 0; } bassin_wall { type nutkWallFunction; value uniform 0; } bassin_bottom { type nutkWallFunction; value uniform 0; } bassin_top { type calculated; value uniform 0; } } |
power
At a fast look it seems you put everywhere 0 values. So what do you need to calculate if everywhere each variable is 0?
What are your real boundary conditions? And what about the real case you want to simulate? Geometry? |
Kim Le
I am trying to simulate a tank full of water with some agitation at the bottom. In MFRProperties, I set two agitators.
MRF1Agitateur1 { cellZone agitateur1; active yes; // Fixed patches (by default they 'move' with the MRF zone) nonRotatingPatches ("(bassin_top|bassin_bottom)"); origin (1 0 0); axis (0 0 1); omega 12.32; } MRF2Agitateur2 { cellZone agitateur2; active yes; // Fixed patches (by default they 'move' with the MRF zone) nonRotatingPatches ("(bassin_top|bassin_bottom)"); origin (-1 0 0); axis (0 0 1); omega 12.32; } I guess that my "bassin_top" BC is not good (?) Because in reality, it would be a free surface at an atmospheric pressure. I wanted to do a steady-state and single phase simulation. I supposed that the tank is not filled during that time. In fine, this is what I would like to observe but for now I just made a simple cylinder. https://drive.google.com/open?id=0B7...kZaY0FzUjBIaE0 Last edited by lethu; May 17, 2017 at 08:25. Reason: Image not working |
power
Sorry,
I can't help more. Wait for a more expert foamer! |
interFoam vs. simpleFoam channel flow comparison | DanM | OpenFOAM Running, Solving & CFD | 12 | January 31, 2020 15:26 |
MPI error with simpleFoam | blaise | OpenFOAM Running, Solving & CFD | 0 | November 7, 2015 14:01 |
simpleFoam parallel solver & Fluent polyhedral mesh | Zlatko | OpenFOAM Running, Solving & CFD | 3 | September 26, 2014 06:53 |
Laminar simpleFoam and inviscid simpleFoam | herenger | OpenFOAM Running, Solving & CFD | 7 | July 11, 2013 06:27 |
Trying to run a benchmark case with simpleFoam | spsb | OpenFOAM | 3 | February 24, 2012 09:07 |
