May 27, 2017, 11:46 |
Troubleshooting errors with pimpleDyMFoam
Jeremy
Rep Power: 10 |
I am attempting to run a pimpleDyMFoam using displacementLaplacian. I have had success using velocityLaplacian, but it is very sensitive, and either prone to blowing up or the change is too small to be noticed. My case requires a specific % change, so displacementLaplacian seems natural. Here is my mesh: My goal is to expand outward the outside walls of the circular sac on the right I am stuck with a float point exception, which occurs in the first pressure update (I think). The log file is here: Code:
Create time Create mesh for time = 0 Selecting dynamicFvMesh dynamicMotionSolverFvMesh Selecting motion solver: displacementLaplacian Selecting motion diffusion: quadratic Selecting motion diffusion: inverseDistance PIMPLE: no residual control data found. Calculations will employ 2 corrector loops Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type laminar No MRF models present Reading/calculating face velocity Uf No finite volume options present Courant Number mean: 0 max: 0 Starting time loop Courant Number mean: 0 max: 0 Time = 1e-05 DICPCG: Solving for cellDisplacementx, Initial residual = 1, Final residual = 0.000870402, No Iterations 10 DICPCG: Solving for cellDisplacementy, Initial residual = 0, Final residual = 0, No Iterations 0 GAMG: Solving for pcorr, Initial residual = 1, Final residual = 9.83755e-05, No Iterations 63 GAMG: Solving for pcorr, Initial residual = 0.999308, Final residual = 9.47909e-05, No Iterations 55 GAMG: Solving for pcorr, Initial residual = 0.999823, Final residual = 9.44465e-05, No Iterations 38 time step continuity errors : sum local = -23977.2, global = 49.658, cumulative = 49.658 PIMPLE: iteration 1 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0937035, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0848355, No Iterations 5 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:? #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:? #8 ? at ??:? #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 ? at ??:? My full case is attached. Please help! This is for my thesis and it is the last step. The results are acceptable with velocityLaplacian, but as I mentioned, it either blows up or the change is hardly visible (though flow is clearly occuring). |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
