can OpenFoam model a pole in Cylindrical mesh??
Old   October 26, 2014, 20:03
Default can OpenFoam model a pole in Cylindrical mesh??
Daniel
Dan1788 is on a distinguished road
I am making a 3D cylindrical mesh for LES computations of premixed flames.
I would like to know if OpenFoam can correctly model singularities or poles at the origin (as shown in the attached figure) correctly, or would I have to mesh my geometry in a different manner.
Would really appreciate any help on this topic. Thanks!
Dan1788 is offline   Reply With Quote
Old   October 27, 2014, 16:17
Chris Sears
ChristoBeers is on a distinguished road
I had previously tested this with rhoPimpleFoam, and did notice abnormal action along the cylinder axis (center of the "pie slices") where the cell skewness gets really large. I then tried rounding out one square hex, but this introduced abnormalities where the corners were stretched out (probably for the same reason). I then meshed a square in the center of the circle which simulated properly.
I honestly didn't spend too much effort trying to see if there were more advanced solver options to account for skewedness, I just changed the mesh. Somebody else with more experience may speak to your exact question.
Good luck!
ChristoBeers is offline   Reply With Quote
Old   October 28, 2014, 04:05
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
I am wondering: why..? I mean, people use o-grids for this normally. I didn't really question this up to now, because I thought this is pretty common. Can you explain, why you prefer this way of meshing?
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   October 28, 2014, 12:11
Chris Sears
You are absolutely right, people use o-grids. It may have been my specific mesh/configuration/BC, but there were false temp/density iso's which protruded down the cylinder axis which should not have been the case. I was merely warning the OP that it is possible if he's not careful. As I said, I didn't play with it too much because it was simple enough for me to change the grid.
To keep an o-grid in my system I had calculated an excessively dense mesh in the center to keep the skewness down (increasing #/meter of "onion shells" around the axis where the "pie slice" tips narrow to zero @ the center). I have very little experience in CFD, but in my simulation, the denser mesh & running >3 nonOrthogonalCorrectors will slow me down, and I guessed a nice cubic in the center may help the solver converge more rapidly...? I wanted to spend the mesh density near the walls where there's something more interesting going on. Am I way off?
Old   October 28, 2014, 13:14
Daniel
Even I am modeling my mesh using an O-grid but was wondering if OpenFoam could model poles because for an axisymmetric grid it is able to take into account pole formation.
Anyways thanks for your reply Chris!
Old   May 30, 2017, 22:03
chun is on a distinguished road
Although it might be late for you, but I do have what you want.
You can change the length and radius from the .m4 file.
Using the following command, you can get the blockMeshDict from the .m4 file.
m4 circle.m4 > blockMeshDict
chun is offline   Reply With Quote
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
Frozen Rotor 1:1 Mesh Connection pharley CFX 5 January 31, 2013 16:15
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
Converting Starccm+ mesh Ladnam OpenFOAM 0 September 14, 2011 06:30
salome, openfoam and moving mesh prhlava OpenFOAM Running, Solving & CFD 8 November 9, 2009 08:59
