August 8, 2017, 17:00 |
probably a simple error
Adam Katz
Rep Power: 9 |
Hi all,
I am trying to simulate heavy gas flow into my domain. The problem is I don't get any in flow velocity?! I suspect it is either wrong boundary conditions or wrong mesh/patches. Please help, I have no idea how to advance. Thanks, Adam I am using rhoReactiveBuoyantFoam Here are my /0 files: U Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { gasInlet { type fixedValue; value uniform (0 -1 0); } gasOutlet { type pressureInletOutletVelocity; value $internalField; // phi phi; } frontAndBack { type empty; } Code:
dimensions [1 -1 -2 0 0 0 0]; internalField uniform 1e5; boundaryField { gasInlet { type zeroGradient; } gasOutlet { type totalPressure; p0 $internalField; U U; phi phi; rho rho; psi none; gamma 0; value $internalField; } frontAndBack { type empty; } Code:
dimensions [0 0 0 0 0 0 0]; internalField uniform 0.5; boundaryField { gasInlet { type fixedValue; value uniform 0.0; } gasOutlet { type inletOutlet; inletValue uniform 1.0; value uniform 1.0; } frontAndBack { type empty; } Code:
dimensions [0 0 0 0 0 0 0]; internalField uniform 0.5; boundaryField { gasInlet { type fixedValue; value uniform 1.0; } gasOutlet { type inletOutlet; inletValue uniform 0.0; value uniform 0.0; } frontAndBack { type empty; } Perhaps it has something to do with the geometry so I attached a picture of the domain. blockMeshDict: Code:
convertToMeters 1; vertices ( // bottom box (0.0 -0.1 -0.01) //0 (0.2 -0.1 -0.01) //1 (0.2 0.1 -0.01) //2 (0.0 0.1 -0.01) //3 (0.0 -0.1 0.01) //4 (0.2 -0.1 0.01) //5 (0.2 0.1 0.01) //6 (0.0 0.1 0.01)// 7 // top part //center (0.09 0.1 -0.01) //8 (0.11 0.1 -0.01) //9 (0.11 0.16 -0.01) //10 (0.09 0.16 -0.01) //11 (0.09 0.1 0.01) //12 (0.11 0.1 0.01) //13 (0.11 0.16 0.01) //14 (0.09 0.16 0.01) //15 // corners (0 0.16 -0.01) //16 (0.2 0.16 -0.01) //17 (0 0.16 0.01) //18 (0.2 0.16 0.01) //19 ); blocks ( hex (0 1 2 3 4 5 6 7) (100 100 1) simpleGrading (1 1 1) //bottom box hex (8 9 10 11 12 13 14 15) (10 30 1) simpleGrading (1 1 1) //center top box hex (3 8 11 16 7 12 15 18) (45 30 1) simpleGrading (1 1 1) //left top box hex (9 2 17 10 13 6 19 14) (45 30 1) simpleGrading (1 1 1) //right top box); ); edges ( ); boundary ( gasInlet { type patch; faces ( (10 11 14 15) ); } gasOutlet { type patch; faces ( (4 7 3 0) (7 18 16 3) (1 2 6 5) (2 17 19 6) (0 1 5 4) (17 10 14 19) (11 16 18 15) ); } frontAndBack { type empty; faces ( (4 5 6 7) (13 6 19 14) (12 13 14 15) (7 12 15 18) (0 3 2 1) (10 17 2 9) (11 10 9 8) (16 11 8 3) ); } ); mergePatchPairs ( ); |
August 9, 2017, 04:09 |
Kevin van As
Rep Power: 20 |
I'm guessing that having an inlet and an outlet directly adjacent to each other like that is a bad thing numerically.
I know from interFoam that in order to have an inlet next to a wall in the same geometry that you are using, I require to add some sort of tube or nozzle-like geometry on top of the inlet, such that the inlet is not directly adjacent to the wall, e.g.: Code:
inlet __ | | ___| |___ |
August 9, 2017, 04:20 |
Thanks, will try and update
Adam Katz
Rep Power: 9 |
Thanks man!
I'll try and update. |
August 10, 2017, 00:17 |
Kirk Jarvis
Rep Power: 17 |
The mesh has some empty faces on the inside specifically (7 3 8 12) (12 8 9 13) (13 9 2 6). Try the below block mesh.
convertToMeters 1; vertices ( (0 -0.1 -0.01) //0 (0.09 -0.1 -0.01) //1 (0.09 0.16 -0.01) //2 (0 0.16 -0.01) //3 (0 -0.1 0.01) //4 (0.09 -0.1 0.01) //5 (0.09 0.16 0.01) //6 (0 0.16 0.01) //7 (0.11 -0.1 -0.01) //8 (0.11 0.16 -0.01) //9 (0.11 0.16 0.01) //10 (0.11 -0.1 0.01) //11 (0.2 -0.1 -0.01) //12 (0.2 0.16 -0.01) //13 (0.2 0.16 0.01) //14 (0.2 -0.1 0.01) //15 ); blocks ( hex (0 1 2 3 4 5 6 7) (45 130 1) simpleGrading (1 1 1) hex (1 8 9 2 5 11 10 6) (10 130 1) simpleGrading (1 1 1) hex (8 12 13 9 11 15 14 10) (45 130 1) simpleGrading (1 1 1) ); boundary ( gasInlet { type patch; faces ( (2 6 10 9) ); } gasOutlet { type patch; faces ( (9 10 14 13) (12 13 14 15) (8 12 15 11) (1 8 11 5) (0 1 5 4) (0 4 7 3) (3 7 6 2) ); } frontAndBack { type empty; faces ( (4 5 6 7) (5 11 10 6) (11 15 14 10) (8 9 13 12) (1 2 9 8) (0 3 2 1) ); } ); edges ( ); |
August 10, 2017, 04:38 |
Adam Katz
Rep Power: 9 |
Dear Kirk,
The mesh you propose is much more elegant than mine, yet I don't understand why these empty faces pose a problem? Also, if I take Floquation's advice I will have this kind of "empty face" (8 12 13 9) in the nozzle-chamber interface (see figure). Could you please explain? Thanks BTW I found an awesome way to display the blocks and vertices using Code:
paraFoam -block |
August 10, 2017, 10:57 |
Kirk Jarvis
Rep Power: 17 |
On the mesh I provided you could add the four point above (2 6 10 9 ) and make a new Hex for the nozzle.
Sent from my SM-N920V using CFD Online Forum mobile app |
August 10, 2017, 11:22 |
Kirk Jarvis
Rep Power: 17 |
See how the hexs share points. There are ways to mesh the faces or extrude the faces however off the top of my head this is easier and doesn't require extra steps and in my opinion is a fundamental you should learn if plan on using openfoam.
August 10, 2017, 11:35 |
Kirk Jarvis
Rep Power: 17 |
Look up mergePatchPairs in the user-guide. That might do it also if I remember right. You would define the two faces that you are connecting. In the blockMeshDict.
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
POSDAT problem | piotka | STAR-CD | 4 | June 12, 2009 08:43 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
